Question about Samsung LA26R71BD 26 in. HD-Ready LCD TV
I have a samsung 32 inch lcd tv,it has a mind of its own,turns itself on and off,can't alter the volume,icons stay on the screen.when its on ha ha the picture is great..
These Samsung TVs are renowned for blowing capacitors, the on/off symptom is a usual indicator. If you're handy with a soldering iron the caps can be easily replaced in minutes and cheaply. There are many videos on You Tube showing exactly how its done. Blown caps are easily identifiable, I replaced 5 in my TV for a cost of $9.60 AUSD and I'm no technician.
Posted on May 23, 2011
    Novelist:
  • 210 Answers
Sounds like a button is stuck? Hide the remote and make sure it's not the problem... if it persists, check and jab the buttons on the TV itself...
If it turns off, it sounds like the on/off button is the problem... and if it's jammed 'on', then other buttons wouldn't work.
Posted on Apr 20, 2009
I have a 58 inch Sanyo flat screen TV, I turn it on everything works fine, shuts down in about 10 minutes! Sound stays on though. If I shut it off and turn it back on it does the same thing!
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the... the Sanyo DP47460 that I'm having an issue with. after ~ 40minutes of watching, if I attempt to change the channel or adjust the volume, the picture/screen freezes. ... After ~ 20 seconds, theTV will automatically shut off, then turn back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Hi, I've got a Samsung LED TV that switches off after20 seconds and remains off. .... after about couple of minutes, is this the same problem with the tv in the video? .... 10:32. How to repair a Samsung LCD TV with a flashing standby ...
TV Turns On, Backlight Inverter Immediately Turns Off TV ..
Dec 17, 2015 | Televison & Video
Volume keeps going down to zero
Emerson volume keeps going down Questions & Answers ...
www.fixya.com > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Emerson Flat Screen TV volume trouble? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Aug 10, 2011 - My Emerson 32 inch does similar things, volume just goes to 0-100 and stays there. ... Why is the volume on my Emerson flat screen TV not working and how could i fix it? Whats wrong with my Emerson Flat screen tv? Why is the volume on my Emerson flat screen TV not working ...
Jul 13, 2013
My son has an Emerson tv it keeps turning down by itself. Anyone ...
Aug 24, 2006
More results from answers.yahoo.com
Emerson TV problem ' Techlore
Dec 15, 2015 | Emerson Televison & Video
I have anew Samsung 55 inch model code ue55h6500akxxu but it will not store my settings as soon as i turn tv off an on again it goes back to custom settings
This is from an article I found online:
"It's likely that the television is in Shop Mode. The symptom would be that your settings are defaulted back to the out-of-box settings?
Try holding down the Menu button on the TV (Not remote) for 12 seconds.
OR
Try pushing the volume button up once, let go, and then hold down the MENU button for about 12 seconds.
You might see the screen flicker, and that's okay. Once you've done that, you should be able to program your settings and they should stay.
--HDTech"
Feb 02, 2015 | Samsung Un55c6400 55 Inch Led Hd Tv - Free...
I have a 32 inch Samsung LCD TV. For some unexplained reason it keeps turning the volume down by itself. I have tried the obvious, like taking the batteries out of the remotes and then turning the volume...
Warning! Pull out the cord first!!! Open the TV take the tester and check over the mini board with the buttons, there might be the Vol- button in shortcut, or get some water. If its short, must replace, if there are water/ liquid/ oxyds traces, take a toothbrush, put a little of alcohol, and gently clean the place, after that dry it with a hairdryer.
May 18, 2011 | Samsung LN-T3253H 32 in. LCD Television
Samsung lcd 32 inches screen. The volume turns down to zero by itself. The remote control looses control. Control through remote control keeps coming and going intermittently.volume can be turned up...
Try removing the batteries from the remote after you set the volume, just to determine if the remote is causing the problem or not. I have seen stuff spilled on remotes and they just go crazy.
Feb 13, 2018 | Samsung LTN226W 22 in. HD-Ready LCD...
Samsung le40r74bd problem
I just had this problem with my 3 year old 32" Samsung LCD. The volume would go up and down by itself, normally just constantly going up even when it reached 100%.
I thought it might have something to do with the volume buttons on the TV itself so seeing as it was out of warranty anyway I decided to unplug it and open it up.
I gave it a good clean and I disconnected the cable for the panel of buttons on the LCD itself (volume, menu, channel etc) seeing as I never use them anyway. I then put everything else back together and tested.
It seems to be working fine now. Previously (for the past 3 hours) ever time I turned it on the volume level would come on instantly and stay on until I turned the TV off. So I’m quietly confident the problem has been fixed. But I must admit it’s only been 10 minutes, so who knows, it might come back.
Dec 18, 2009 | Samsung LE40R74BDX 40 in. LCD Television
32 Inch Brand new Samsung 32" LCD showing subtitles / no volume??
I had a similar problem, checked all of the TV's control settings only to find out that my cable box had an independent "mute" function that automatically turned on the closed captions when activated. Once I found that and turned it off, all was fine.
Mar 18, 2009 | Samsung LN-R237W 23 in. LCD Television
Samsung LN32A550 32-Inch 1080p LCD HDTV
Best Buy Samsung LN32A550 32 in. 1080p LCD HDTV Free shipping Order Today! [Click Here!]
Samsung LE32B650T2 32-inch Widescreen Full HD 1080p
Save On "Best Buy Samsung LN32A550 32 in. 1080p LCD HDTV" You can Buy Samsung LN32A550 32 in. 1080p LCD HDTV In Stock. Low Prices Samsung LN32A550 32 in. 1080p LCD HDTV Shops & Purchase Online - Quick & Easy.
Discount "Best Buy Samsung LN32A550 32 in. 1080p LCD HDTV" Free Shipping & Pay No Sales Tax! You can Buy Samsung LN32A550 32 in. 1080p LCD HDTV In Stock Low Prices Samsung LN32A550 32 in. 1080p LCD HDTV Shops & Purchase Online - Quick & Easy.
Dec 10, 2008 | Samsung TXJ2879 28" TV
Samsung LA26R71BD 26 in. HD-Ready LCD TV Logo
492 people viewed this question
Jerry Greenberg
Jerry Greenberg
