FixYa.com
Tags:
Vector VEC438 AM/FM/Weather Radio
Program Alert Function
posted by billopsmgr on Sep 20, 2007
I am unable to turn the Alert/Siren on. It indicates it is OFF. I have a desktop weather radio that receives the weekly test signal but the Vector does not due to being off.
Any ideas. I do not have an instruction manual.
Comment by billopsmgr, posted on Sep 21, 2007
Solution:
Turn the radio on and then press:
1. Menu button and scroll to Alert.
2. Press Channel/Snooze button to the right of the menu button which will display one of the following: Voice/Siren/or Off.
3. Then use the menu button to select between Voice/Siren/or Off.
3. After making your selection, press the Memory button to the left of the menu button. This completes the programming of the alert function.
Example: If "Siren" is displayed on the LCD screen and you push the Memory button to the left of the menu button, when a weather alert is broadcast the siren tone will sound and the appropriate yellow or red light will activate. If "OFF" is displayed on the LCD screen and the memory button is pushed, the alert will not activiate.
BJ
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Can you Help with these Personal Radios problems?
Alert Funnction inop
The Alert keeps showing the... Answer This...
Cannot adjust volume level...
I just got this thing a few... Answer This...
Personal Radios
manual for Audiovox AXR48 crank...
Audiovox AXR48-hand crank radio Answer This...
I have a 1500 watt
I have a 1500 watt vector power... Answer This...
Repair Service
Find Personal Radio Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
