My notebook fails to detect my ethernet connection due to Error:net.pp0 failed to start at boot up terminal. I'm using sabayon linux 3.5 I think all i need is a command to reset my net.pp0 since this problem only occurred recently
    Problem Solver:
  • 16 Answers
If I remember correctly the command would be eth0 up and eth0 down
ifconfig will display your Ethernet settings and configuration
Posted on Aug 04, 2009
I have an error message in my iRiver and unable to use it anymore. The error message I'm getting is: Boot Failure System file has an error. To solve the problem, connect the device to compute
If it is an older model like H10, it used a a micro hard drive which may have failed mechanically. Those old hard drive devices were susceptible to shock failure due to drops. In some cases you may be able to replace the failed hard drive with a compact flash card - I believe they used the same connectors and pin outs. If it is not a hard drive model, can you get it recognized by windows drive manager to try to reformat it. There's a linux based program G-Part Ed. It's an ISO file, burn to cd or put on USB and boot pc to the cd or usb to launch linux and the software then see if it will recognize and format it as an external drive. Gibson research used to make spin rite that was able to fix some hard drive problems, might work on flash memory too.
Jan 02, 2015 | iRiver Audio Players & Recorders
I was given an HP Mini 1120NR netbook as a gift. The system came with Linux OS installed. My system crashed due to a power failure while I was restoring my system and simulatneously charging my battery,...
first error is step on, never install OS with bad or dead battery
rule 1. so why not stop now and do step one right.
if battery is bad it must be removed and replaced.
as most are this old. ,never seen own old battery like this still good.
This LP stink, have one new parked in attic. hated it.
love Linux do but had the slug processor.
1.60 GHz Intel Atom Processor N270
see that processor, its not a real Intel top class processor
its toy grade.
this mini is setup to boot 2 ways
1 is ROM linux inside
and 2, vista?
mine has a rom imbedded Linux in it that runs using alt boot mode.
but is hard coded in the ROM.
called RESIDENT LINUX. (or techs call it Embedded)
is that failing? or the DVD OS failing?>
the note book can have
ROM LINUX (for ever, its in A CHIP, not HDD)
+ boot hdd linux. boot hdd, XP or Vista.
as you can see you could have 2 linux,
one in rom, and newer one in HDD.
but many linux made do not support the silly ATOM processor.
which OSs are you attempting.
why not buy the HP media kit installs.
https://support.hp.com/us-en/drivers/selfservice/hp-mini-1100-pc-series/3875650/model/3860343
here is the driver pages
the media kits are there too.
ask more questions, i played with mine awhile., before parking it.
the claim to fame on this unit
is hDD turned off
boot to rom LINUX and battery lasts 10 hours
can cruse web and read email, on ROM.
very crafty idea but processor is stinker.
maybe ill put in an SSD and see if it can run faster. next winter
Apr 09, 2017 | HP Mini 1120NR PC Notebook
For Atheros PCIE Ethernet Controller... check cable connection PXE-E63:error while initializing the NIC PXE-MOF:exiting intel PXE ROM No bootable device-insert boot disk and press eny key happened...
system is trying to boot to a network, this is most likely due to the hard disk drive not being detected, or the windows operating system is missing.
First reset the BIOS defaults, see if the system detects the HDD in the bios and will now boot.
Run diagnostics on the hard disk drive, which I suspect it will fail.
If diags on the drive pass, they try reinstalling Windows. But I expect you'll be replacing the drive.
Nov 15, 2010 | Computers & Internet
Linux 5 is not detecting my broadband modem
The connecting to internet is very easy in linux .
There are many steps but i am saying simple one
Initially configure the adsl router with ppoe over ethernet and enable dhcp address option.
Next plug the ethernet cable from router to the inteface of lan card.
Boot the redhat machine.
In the system-->Administration-->network options check whether lan card is detected and active .
If the lan card is not active activate and save
In lan card select option assign assig ip automatically
check whether ip is assigned by using command ifconfig .
Mar 11, 2010 | Red Hat Enterprise Linux ES Basic Edition
What is grub error 17? how to fix it?
Its GRand Unified Bootloader used in Linux OS.
Normally you get this error when GRUB is not able recognise the partition from which you are trying to boot the system. Make sure the boot partition on your system is recognisable by GRUB (such as EXT3).
You can try to restore the GRUB using the LIVE CD
  1. Boot From Live CD
  2. Open Terminal Window
  3. type >sudo grub
  4. then type : find /boot/grub/stage1
  5. you'll get something like: (hd0, 1)
  6. then type : >root (hd0, 1)
  7. type: > setup (hd0)
  8. >quit
  9. >exit
Remove the Live CD and reboot the system.
Please let me know if you need any further assistance.
Thank you for choosing Fixya
Oct 30, 2009 | Compaq Presario M2000 Notebook
I have a message that says , error message: PXE Media test failure chek cable
PXE or Pixie errors occur when the system tried to boot to the network connection and failed. This error usually occurs when the hard drive fails. If your system does boot to windows and you are just getting the error, then you can change the network card setting in BIOS to turn PXE boot off.
If the error occurs and the system doesn't boot to the hard drive, then the hard drive has most likely failed.
Sep 30, 2009 | Compaq Armada E500 Notebook
Acer one not finding any server
Check the wireless card connections physically. I received a Aspire one that had a wire disconnected from the card itself. if that is in tack find out what driver you are using for your card using "lsmod" see if there are alternatives. Try a live boot USB linux and see if your wireless card functions under that if it doesn't it is hardware if it does it is software. I would switch to another linux like sabayon or ubuntu eeepc versions they function better. I run Sabayon on both of my netbooks. Ubuntu ha sbetter support though.
Dec 25, 2008 | Acer Aspire One AOA150-1570 Notebook PC
Can't use my flash drive
You can try formatting the drive by using "HP USB drive format utility". Try first with FAT and then FAT32 do not format it in NTFS. It's free. Download it by Googling. You can even try in a different computer, sometimes due to driver problem also it happens. Best of luck.
Nov 04, 2008 | Kingston Technologies 512MB DataTraveler I...
Acer Aspire 4720 RHEL4 Installation
again install linux in between the installation there will be option select linux boot loader , and one more think linux partition space should more then windows partition
Mar 26, 2008 | Acer Aspire 5100 Notebook
Unable to Install Red Hat Linux Enterprises 4
when the time of installing only you have to take linux boot loader then it will show both operating systems otherwise i think the problem is monitor configuration in linux installing
Mar 24, 2008 | Computers & Internet
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
