Question about Garden
CANT GETLINE SPOOL OFF - Garden
Went to start it, and snapped the pull start cord. Trying to pull it apart to replace it but cant get the front gaurd off from the motor to get to the cord.
Usually, the whole starter mechanism can be removed from the left case by taking off several screws. The spool will be revealed when looking at the rear of the mechanism. Remove the rest of the starter cord from the spool and handle, then turn the spool CW about 2-turns, and wedge it so that the spool doesn't unwind again. Fit a new cord end of the same dimension and about 3-1/4 ft (1-meter) in length into the spool slot/hole, melt the end, and tie an overhand knot in the end. Wind the cord CW until you have about 8" left--poke the cord out of the cord port, push the end through the handle, melt the end, and tie an overhand knot. Stuff the knot into the handle bore, release the spool wedge, and pull the cord through several times to make sure that it works without binding in the spool and retracts fully. Reinstall the starter and test on the engine. Hope this helps!
Nov 10, 2010 | Garden
Cant cast the pinnacle platinum plus lp 100 fishing reel more than 15 feet because the line tangles. Any suggestions?
Sounds like your drag is too loose. Best way to get used to setting a baitcaster, in my opinion, is to put a 1/2 ounce weight on the end of the line and engage the spool. The line should drop to the ground freely, but not full speed - if too fast, the spool will continue to spin and you'll get that dreaded birdsnest. If it doesn't reach the ground, you need to loosen it more. Once you have it set, keep that weight on and go practice, using the thumbing process Parorae noted in the previous answer.
They take some getting used to for sure!
Aug 04, 2010 | Pinnacle Solene SLP10 Baitcast Reel
Have Craftsman gas weedwacker double line ran out.
take off knob that holds on the spool on bottom of weedwacker, remove spool, there are notches around the outside splines on the bottom of the spool. (the bottom is the end that fits up into the spool housing. there are 2 little holes opposite one another on the spool - one on each section. Cut two lengths of line about 6 feet long. stick line into first hole (near bottom of unit) wrap line around spool. once wrapped line gets short - to the point where you cant wrap it anymore - stick the end into one of the notches - do the same with the other line - insert spool back into housing - make sure spring is attached to the spool and lines come out of the holes in the housing - reinsert knob and tighten - make sure as you are doing this you unseat the ends of the lines off of the notches on the spool and they are out through the housing - tighten knob and you should be good to go
Sep 06, 2009 | Craftsman Garden
Cant get the spool off homelite trimmer
Unscrew the bump-knob and the rest pulls off. If it won't unscrew you could always cut it off and buy a new one from ALM Manufacturing 01423 797208
Jun 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Cant get the spool off to change the line
check for 2 or 1 push tabs on the side of the spool that might onlock it so it can be turned too replace string
May 10, 2009 | Garden
This is soooo lame but I cant remember how to put the correction tape in.... :~)
As you face the machine, the full spool goes on the left side of the printwheel carriage and the takeup (empty) spool goes on the right. Be sure that the shiny side of the lift off tape faces AWAY for the paper. The matte side is what does the lifting.
Hope this helps.
Apr 17, 2009 | Brother Office Equipment & Supplies
The lcd keeps telling me to turn foot controller off
When you put the bobbin on the top spool, did you move the bobbin spool to the right? It will only work if the bobbin spool is moved to the right.
Mar 23, 2009 | Brother Sewing Machines
Shakespeare 2660 coarse fishing reel,cant remove spool cover
According to the intructions and I quote "Take off the cowling that covers the spool, twist off the pick up mechanism clockwise and a half turn anti clockwise will remove the spool"
Mar 17, 2009 | Shakespeare Agility Spinning Reel 6825
Garden Logo
114 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
