Question about Samsung ML-2571N Laser Printer
About print spooler
Frequently the print spooler is stopped automatically. What is the problem. Kindly suggest.Now I am starting the print spooler manually and taking print everytime. Regards, M.L.Rajasekaran System Support Engineer Larsen & Toubro Ltd Pondicherry-605111
  • 161 Answers
If you are using Windows Vista, maske sure you download and install updated drivers. Other than that, use a USB rather than parallel port connection and check your antivirus and firewall settings. You can always call Samsung for support at 1-800-samsung.
Posted on Sep 26, 2007
SOURCE:
Where i could see the printer spooler?
I open the run command you can type: net start spooler
(You will get a message that says the print spooler service has started)
If you still have issues open the run command and type: services.msc
it will display a list, where you can find print spooler.
From there you can right-click on it and set it so it is started and runs automatically.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Jan 25, 2013 | Canon PIXMA MP287 ALL-IN-ONE INKJET...
Printing sitting in queue wont print
The print spooler may not be working.
Start and stop the print spooler Windows XP
To start and stop the print spooler open Computer Management, click Start, click Control Panel, double-click Administrative Tools, and then double-click Computer Management. In the console tree, click Component Services.
Under Console Root click Services (Local)
In the details pane, double-click Print Spooler. Do one of the following depending on the task you want to do:
Click Stop to stop the service.
Click Start to start the service. When you try to install a printer and get an error message "Print Spooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the General tab then select these items - Startup type select Automatic Service status click Start Then click OK
Aug 28, 2012 | Brother MFC-290C Printer
Print spooler subsystem stopped
To start and stop the print spooleropen Computer Management, click Start,click Control Panel, double-click Administrative Tools,and then double-click Computer Management.In the console tree, click Component Services.
In the details pane, double-click Print Spooler.Do one of the following depending on the task you want todo:
Click Start to start the service.When you try to install a printer and get an error message "PrintSpooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the Generaltab then select these items - Startup type select AutomaticService status click StartThen click OK
May 12, 2012 | Office Equipment & Supplies
While installing my printer driver the warning appears that your printer spooler is not working
You need to go into services and enable the print spooler.
How to start or stop the print spooler?
  1. Right click on My Computer (Computer on Vista) and select Manage
  2. In the console that opens, pull down the Services menu and applications
  3. Click on Services
  4. Double-click on the Print Spooler key
  5. In the "General" tab, go to Startup Type
  6. Set the value to Automatic, Manual or Disabled
  7. To enable or disable the print spooler service immediately, click Stop or Start
  8. Finally click Apply
Mar 02, 2011 | Computers & Internet
Printer spooler service not running
Go into Control Panel, Administrative Tools, Services, Scroll down and highlight Print Spooler, Double click Print Spooler, and ensure Startup Type is Automatic, and that the Service Status is Started. If it is Stopped, then Click Start, then OK to exit. If it doesn't Start, try rebooting your computer, then confirming the above settings.
Jan 14, 2010 | Office Equipment & Supplies
Problem with print spooler service
Turn the print spooler to automatic by going to services, change start up to automatic, click on recovery first failure should be restart service as well as second failure, go to RPC service and make sure it is on automatic as well
May 12, 2009 | Lenovo ThinkPad T61p 15 inch widescreen...
In win xp sp2 the print spooler services automatically stop when i give print comand plz help
  1. Open Computer Management.
  2. In the console tree, click Services.
    Where?
    • Computer Management/Services and Applications/Services
  3. In the details pane, double-click Print Spooler.
  4. Do one of the following depending on the task you want to do:
Notes
  • To open Computer Management, click Start, click Control Panel, double-click Administrative Tools, and then double-click Computer Management.
  • When you stop the Print Spooler service, it might stop other dependent services.
  • The print spooler runs under the Local Computer system account by default.
Jan 14, 2009 | Computers & Internet
Printer Spooler service!
Click on "Start, Run", type "services.msc"
On the right side of the services window, scroll down to "Print Spooler". Double-click it.
If startup type is "disabled", click the drop-down and set to "Automatic" and then click "Start". If already on automatic, click "Stop" to stop the service. Once stopped, click "Start" to restart the service.
Reboot and try again :)
Hope this helps - remember to rate!
Oct 01, 2008 | HP DeskJet 5550 InkJet Printer
Spooler subsystem has stopped working
if u not getting print due to " Spooler subsystem app has stopped working " Error then go to Run---->type "services.msc"------->u get services console----------->select "Print Spooler"go to propriety ---------->check start-up type ------>if it is disable select automatic &press start for get start (if it is alredy started then get service stop & after get start with automatic )
if there is problem in printing due to Spooler it should be resolved
if this information is useful for u please Rate me..........
Jun 22, 2008 | HP Color LaserJet 2600n Printer
Printers vanished and can't add printer
Your shell extensions have a software conflict. The offending piece of software will have to be determined and removed, or at least stopped, before re-booting the computer. You may be able to repair the problem using the System Restore option.
Oct 10, 2007 | Adobe Acrobat Distiller Server V6 for Win...
Samsung ML-2571N Laser Printer Logo
127 people viewed this question
Top Samsung Office Equipment & Supplies Experts
jasbo
jasbo
Lawrence Singapore
Level 1 Expert
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
