Question about IBM ThinkPad X31 2672 Notebook
Connection vith pocket pc sense
It impossible connect my pocket with active sync, by usb,byinfrared, by bluetooth.......
tank you for answer
How to connect i-mate jam phone to pc with help of usb cable
to install Microsoft Active Sync 4.5 for your Imate Jam and a USB cable, You can download the Microsoft Active Sync 4.5 latest version
Jan 24, 2011 | i-mate JAM Pocket PC
How to connect the imate jama mobile to pc
To connect your Pocket PC to your PC, you need the following:
  1. USB sync cable which has a USB at one end and a mini-USB on the other. This cable is supplied to you in the sales package.
  2. Microsoft Active Sync, which youcan get from the microsoft website. Download and install it on your PC.
Connect your PPC and you may use them together now for-
  • File-transfers
  • Internet Sharing
  • installing applications
  • etc.
Please Rate if this helps...
Jul 04, 2009 | i-mate JAM Pocket PC
Active sync problem
check your anti-virus and firewall software - this can prevent outside connections being made over activesync
Nov 30, 2008 | HP iPAQ H1940 Pocket PC
PC/PDA "connected" yet PC won't read PDA
try syncing through bluetooth, there could be a problem with the cradle. i have had an issue very similar to yours and had to do a soft reset on my pda. then set up your device to use a blue tooth connection( you may need to buy a bluetooth dongle for your pc).
Feb 06, 2008 | Compaq iPAQ H3850 Pocket PC
How to connect it to a pc running Win XP
Simply download the active sync from http://www.microsoft.com/windowsmobile/activesync/default.mspx
And use the USB cradle to connect to computer (You can also use Infrared and Bluetooth). As long as active sync is on the computer system will recognize pocket PC automatically
Good Luck
Jan 27, 2008 | Dell Axim X3 Pocket PC
Pocket pc 3850
Set it up with what? Do you mean sync with your computer? Are you using USB or Bluetooth?
Best thing to do.
1. Unplug your USB connection from PPC -> Computer
2. Uninstall Activesync if you have it installed
3. Restart your computer
4. Re-install activesync
5. Restart your PPC
6. When asked to connect the PPC connect it via USB
Jan 06, 2008 | Compaq iPAQ H3850 Pocket PC
Help active sync will stay in limbo attempting to connect to cradled axim
Does your system detect the handheld? After you connect the cradle or cable to the computer, then you should be prompted to install drivers for the handheld. Make sure that Dell Pocket PC appears in the Device Manager.
Sep 13, 2005 | Dell Axim X5 Pocket PC
"Communications Error 608"
If you put the Toshiba Pocket PC e740 in your USB Cradle you may receive a "Communication Error 608". This is not a serious error, it is just a false setting in the ActiveSync Program. Please follow these steps below to correct this problem: "Tap" on start and choose the ActiveSync program Then "tap" on "Tools" and choose "Options" in the ActiveSync Program Check under "Enable synchronization when cradled using" to see if the setting is on "USB" If it is set on "Bluetooth", please change it to "USB". Now you can close the application window Important: Please remove the Pocket PC from the cradle and then return it to the cradle. This activates the new setting Important to note: This above described issue occurs if you "tap" accidently on the Bluetooth Icon in the Program Group or activate Bluetooth of any other reason, the ActiveSync Option will be set to "Bluetooth" instead of "USB". This setting will cause the "error 608" if you put in the Pocket PC e740 in the Cradle and start to synchronize over USB.
Sep 07, 2005 | Toshiba e310 Pocket PC
USB connection
my 740 had also problems with loosing the USB connection. I gave it to my dealer and he told me that the USB connector was defective...
Sep 07, 2005 | Toshiba e740 Pocket PC
IBM ThinkPad X31 2672 Notebook Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
