CD player not turning
I have a JVC music system (CA-S20BK)which is working perfectly except for the cd player. When a cd is inserted into the player the cd door closes ok but the cd does not rotate in the system and a "no disc" message comes up in the display. I have tried cleaning the optic but to no avail. Any bright ideas?
  • 2 more comments
  • JohnDiane Dec 10, 2007
    I have a Sony home 3CD AM/FM casett system, if I insert one or three cd's the turntable operates, but it does not 'read" the cd, and indicates "NO DISK", is this a cleaning issue?
    [email protected]
  • Anonymous Feb 13, 2008
    We just repair ours and it still read no cd. What would with this .
  • dolcy Jul 10, 2008
    mine is JVC music system
    i hv inserted cd it says no cd
    not playing
    pls let me know wat is the problem
  • aebd Dec 20, 2008
    I have a Technics 5 cd player. Took the cover off and was able to notice that when the player was on the CD rotation unit was not turning. So I gave it a push with my finger and the CD began to spin. So i tried to blow air around this location. It have begun to work again, but for how long.
    Is there a small motor that causes the CD to spin and can it be replaced.
    ANy comments. ANd If this can be done, where does one get the parts.
    THanks
    New Friend:
Take off the cover and look at the unit from the rear. Just below the lens there is a component with a yellow cross head. I have just fixed this problem by giving this a slight adjustment (maybe 1/10 of a turn) counter clockwise. So far so good. Hope it works for somebody else.
Posted on Jun 19, 2010
I PUT IN A DISC AND HIT THE PRESS INDICATOR. THE SYSTEM READS "NO DISC". I TRIED HITTING ALL THE BUTTONS BUT NOTHING STARTS IT. I NEED A SOLUTION. JVC CA-S20BK. THANKS A LOT.
Posted on Nov 30, 2008
Change a CD reader pickup
model OPTIMA6S
Posted on May 25, 2008
  • 752 Answers
The laser is damaged/worn out. It would be cheaper to purchase a whole new unit, instead of repairing that one.
Posted on Sep 20, 2007
SOURCE:
JVC ca-mxkc58 buttons have stopped working
Your control board is unplugged internally or it is shot. You might be able to find a replacement for the board but you will have to take it out first.
Jan 11, 2014 | JVC Audio Players & Recorders
Jvc kd-sx770 car stereo--radio works, but cd player doesn't
Hello beeswing70,
The player is recognizing that a CD has been inserted but is not able to read it.
Sometimes the lens assembly becomes contaminated and obscures the laser. I'd try using a commercial "lens cleaning CD" two or three times and then try a CD again. These lens cleaning CD's are widely available. If cleaning does not help, the player need professional service.
Hope this helps.
May 25, 2009 | JVC KD-SX770 CD Player
the tray should have a micro switch to touch when its closed. maybe it needs some fine adjustment. if it doesnt say closed then the laser drive wont start. or maybe the magnetic clamp hasnt come down onto the disc properly
Nov 09, 2017 | Audio Players & Recorders
Cd player on RCA R52653
overheating or lens dirty in unit buy lens cleaner cd to clean it
Jan 27, 2008 | RCA 100-Watt Stereo System With 5-CD...
JVC KD-SX770
Per manual, you can lock a cd in by pressing and holding the power and cd button for moer than 2 secondsthe cd cannot be ejected. if acd is inserted upside down, please -eject appears.
May 18, 2007 | JVC KD-SX770 CD Player
When a blank cd is put in screen says "NO AUDIO CD"
Make sure that the CD-R you're using is a "Digital Audio" CD-R. The distinction is marked on the packaging and on the disc. The packaging usually says "Music CD-R." The JVC XL-R5010 won't take data discs to burn music.
Dec 31, 2006 | JVC XL-R5010 4-Disc CD Recorder
614 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
