Question about Olympus Stylus 710 Digital Camera
Error message on olympus camera
When i switch on my camera it displayed on the screen the""""write protect""""what should i do? thanks
  • rhuzzlesorit Apr 20, 2009
    WHAT SHOULD I DO IN ORDER THAT I CAN FIXED MY DIGITAL CAMERA
    President:
  • 919 Answers
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup- right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
Posted on Apr 21, 2009
When I try to take a picture an error message comes on the screen saying Write Protect
You neglected to specify the model of your Olympus camera so I'm assuming it's one of those that use SD/SDHC cards.
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 29, 2012 | Olympus Cameras
When i switch on my digital camera write protect message is displayed on it , my camera is olympus fe-190
If your camera uses a SD memory card then the write protect switch maybe on.
SD and Micro SD memory cards has a smallslide switch on the edge of the card, which write protects data on the memorycard. Slide the switch from the READ position tothe WRITE position, which is furthest away from the contacts.
May 06, 2012 | Olympus FE-190 Digital Camera
Olympus D-700 manuel
The Instruction Manual for the Olympus VG-110 / D-700 Digital Camera can be downloaded online here:
http://www.olympusamerica.com/files/oima_cckb/VG-110_D-700_Instruction_Manual_EN.pdf
On page 53 there is a section on Error Messages. The Write Protect message indicates that the memory card write-protect switch is set to the "LOCK" position. You will need to remove your memnory card and move the swith to the 'UNLOCKED' position.
See Pages 12 and 58 for illlustrations.
Jan 08, 2012 | Olympus Cameras
Error message on screen " write protect" why is this?
Is your memory card write protected, SD cards have a small notch on the left hand side of the card which you can slide up or down to select/deselect protection.
Most cameras also have a photo protection facility in the menu to stop you over writing pictures you've decided to protect.
This can be switched on or off via the camera menu under card settings.
Apr 09, 2010 | Olympus FE-190 Digital Camera
Olympus 850sw- write protect and picture error
Sounds as if the memory card has corrupted data on it now. You will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup Menu - right arrow to Format- Press Ok. You will see format yes or no. Choose Yes and press ok. This will clear the write protect and picture error messages and the card can be used again.
Dec 29, 2008 | Olympus Stylus 850SW Digital Camera
"Write Protect" on Olympus FE-115
Check the manual to discover how write protect is achieved with your particular camera/card Some card rely on a silver foil stick[Smart Media] other have a switch. Compact flash rely on a control on the camera. So you will have to have a good browse through the manual - do not forget that there is a Full manual in PDF on the software disk.
Aug 20, 2007 | Olympus FE-115 Digital Camera
"Write Protect"?!
It's the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Mar 27, 2007 | Olympus Stylus 600 Digital Camera
"Memory card is protected"
This error message indicates that the memory card is locked. The switch on the memory card is in the write-protect position. Reset the switch as shown on the camera screen.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Olympus Stylus 710 Digital Camera Logo
166 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
