Question about Compaq Presario 900 /1500 Series EVO n1015v 15. inch LCD Display -285520-001 (285520001) CD-ROM Drive
Evo N1015v lcd screen goes dark after booting pc
Iwhenever I put my laptop on the screen goes dark after a couple of minutes. It seems that the back light goes out. I have taken the pc to compaq and they changed the inverter, twice, but the problem still persisted. I have been told that I need to change the screen. Is there a way how I can fix this problem and what I should do. I would appreciate any advice you could give me on what I should do.
  • sgtA Nov 21, 2007
    my compaq 915 notebook lights up when starting with the compaq emblem on the screen and then blacks out...any ideas?
  • joeb61 Sep 05, 2008
    I turn on the laptop, it works fine for a minute or to and then the screen goes dark. Have plugged in a remote monitor to get work done but this is not ideal. I have to close the lid of the computer for a while and then reopen it. Sometimes this works in refrshing the screen (ie backlight coming back on) sometimes it doesn't.
I've had similar problem, but this situation happened when I was plugging in Pendrive or another USB device.
I've opened up (unscrewed) the LCD display and there is small metal 'switch' (or metal strip I should say) which must be touching laptop's plastic cover. Cover is painted with special paint which allows ellectric current goes to the other parts of the display.
If that metal 'switch' is not touching the cover you will not be able to see anything.
What I've done was just to bend it slightly, allowing that metal strip to touch the cover correctly.
I do not have any picture of it now and this is quite difficult to explain for me, but it's located at the bottom of the display (somwhere between the middle and left side)
Good luck with it.
Posted on Nov 18, 2008
  • 472 Answers
Sgta, you have the inverter problem that hadrian had fixed. You just need a new inverter.
Hadrian on the other hand quite possibly has a blown CCFL tube. This is the light tube inside the panel that projects the light.
These even if blown, can still last a minute or two before cutting out.
Thats the good news.
The bad news is it lives inside the panel, and not alot of places will attempt to open the panel to replace it. This is possibly the highest risk procedure for anyone who works on LCDs since the slighest amount of damage to the controller tabs inside the panel that connect to the controller board and it's finished.
Safest bet (and probably cheapest) get a dead laptop from eBay with a faulty motherboard and swap out the screen. You will also get other useful parts from the donor system to keep for the future.
Posted on Apr 17, 2008
SOURCE:
Compaq evo n1015v will not boot up when power is pressed
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
http://www.chargerbuy.com/replacement-compaq-evo-n1015v-ac-adapter-90watt.html
Dec 18, 2012 | HP Compaq Evo Notebook N1015v (470046-573)
I have a compaq Evo n1015v and I need the directions to replace the LCD backlight.
Do you do your own dentistry, and do your own exploratory surgery?
Probably not, because you would need to ask "how" to do it. :-)
If you need to ask "how" to fix your laptop, you should STOP, because the risk of damaging your laptop while disassembling it, is too great.
Pay a qualified technician for less than one hour of their labour, and get it done correctly.
Nov 19, 2009 | Compaq Presario 900 /1500 Series EVO...
Laptop screen goes dark after booting .
your issue with your laptop is a faulty ccfl BackLight Inverter, the display uses the backlight to illuminate the lcd screen, the inverter is used to illuminate the cold cathode light in the back of ther lcd theirs countless places to laern about it on google.
They are cheap to replace google your model with inverter at the end..
They are not too hard to replace
Nov 21, 2008 | Dell Latitude CP (0001849d-38380-968-p06e)...
Compaq Presario 900 Series PP2140 Power Up
Leave the battery out and try booting up on ac power only.
Jan 21, 2008 | Compaq Presario 900 /1500 Series EVO...
Weird Screen display
If one of the options presented is "use last known good configuration" use that as a first step.
Jan 08, 2008 | Compaq Presario 900 /1500 Series EVO...
Laptop will not boot up
Whenever any of my clients say the word "Burnt" & "Smell" in the same sentance with reference to their PC's I always shudder... This unit almost certainly has to go to the "Shop" for repair. When you do so ensure ya get a firm FREE "Quote" and an explanation B4 proceeding.
Jan 23, 2007 | Compaq Presario 900 /1500 Series EVO...
Open Questions:
See all Compaq Presario 900 /1500 Series EVO n1015v 15. Questions
Compaq Presario 900 /1500 Series EVO n1015v 15. inch LCD Display -285520-001 (285520001) CD-ROM Drive Logo
154 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
