razu ahmmad Posted on Sep 28, 2013
Toshiba 2820c service manuall - Office Equipment & Supplies
Alex
Level 1:
New Friend:
  • Contributor 13 Answers
  • Posted on Nov 26, 2013
Alex
Contributor
Level 1:
New Friend:
Answers
13
Questions
0
Helped
4382
Points
35
Http://www.smpcshop.com/Toshiba-e-STUDIO-2020C-2330C-2820C-2830C-3520C-3530C-4520C-Service-Manual.html
E-Studio 2820c. How do I correct error code C390?
On the black process unit, there is one sensor contact with the drum surface, make sure there is no stain on the sensor or the drum surface...
How do I remove error code ce60?
Error ce60 e-Studio 2820c - Fixya
www.fixya.com/support/t17213833-error_ce60_e_studio_2820
Mar 19, 2013 - So I put in the code 8 clear/stop so it will show the error code. No error code is popping up. The number 8 just stays on the screen, like nothing ...
Error code of C970 and call for service
Toshiba Copier Error code c 970 problem solution help: Toshiba E STUDIO 2330C, Toshiba E STUDIO 2500C, Toshiba E STUDIO 2820C, Toshiba E STUDIO 2830C, Toshiba E STUDIO 3500C, 3510C, Toshiba E STUDIO 4520C
PROBLEM:
1.The charger wire at the side door is broken. angry.gif:(" title="Angry">
2. The charge wire is vibrating. angry.gif:(" title="Angry">
3. Main charger grid could be deformed. angry.gif:(" title="Angry">
4. Broken T/S wire. angry.gif:(" title="Angry">
5. High voltage transformer abnormaility. angry.gif:(" title="Angry">
Solution:
4. Check if the spring of the high-voltage supply contact point is deformed. cheesy.gif
1helpful
2answers
How can i reset/clear time for periodic maintenance in toshiba E-2820c
We have Toshiba 2820c all in printer it ask periodic maintenance it self what can I do
I have a toshiba estudio 2820c but i dont have a CD, where can i download that? thankyou
Please go to this link http://www.toshiba-sa.net/main/index.php?id=274
Choose your preferred version and download your desired driver and software.
Thanks
3helpful
3answers
F10 error code for a toshiba e-studio 28
Your HDD is having issues. You can try formatting the HDD (make sure you backup templates and address book if you use them.) To format HDD hold 0 and 8 while turning on the copier, when the machine comes ready key in 690 and hit start. It will then display "2 2", hit start again. Wait for it to say please reboot the machine, turn it off and back on. Hopefully this will work but if not, your HDD will need replacing.
k24674
ADMIN Andrew
ADMIN Andrew
