Question about Microsoft Office Standard for PC
  • 82 Answers
Dear ROCKY open Tool Menu-Macro-record new mecro-give the macro file name like rocky-do your work when you finish your job then stop button mecro and save it . next day when you do same job on other file then again open macro and run your macro file and get same job on your new file
Posted on Sep 25, 2007
0 characters
3 Points
I am using microsoft excel 2007, the code is not running, the macro was disabled.. How to enable the macro...?
From the excel help file
  1. Click the Microsoft Office Button o12filemenubutton_za10077102.gif, and then click Excel Options.
  2. Click Trust Center, click Trust Center Settings, and then click Macro Settings.
  3. Click the options that you want:
    • Disable all macros without notification Click this option if you don't trust macros. All macros in documents and security alerts about macros are disabled. If there are documents with unsigned macros that you do trust, you can put those documents into a trusted location. Documents in trusted locations are allowed to run without being checked by the Trust Center security system.
    • Disable all macros with notification This is the default setting. Click this option if you want macros to be disabled, but you want to get security alerts if there are macros present. This way, you can choose when to enable those macros on a case by case basis.
    • Disable all macros except digitally signed macros This setting is the same as the Disable all macros with notification option, except that if the macro is digitally signed by a trusted publisher, the macro can run if you have already trusted the publisher. If you have not trusted the publisher, you are notified. That way, you can choose to enable those signed macros or trust the publisher. All unsigned macros are disabled without notification.
    • Enable all macros (not recommended, potentially dangerous code can run) Click this option to allow all macros to run. This setting makes your computer vulnerable to potentially malicious code and is not recommended.
    • Trust access to the VBA project object model This setting is for developers and is used to deliberately lock out or allow programmatic access to the VBA object model from any Automation client. In other words, it provides a security option for code that is written to automate an Office program and programmatically manipulate the Microsoft Visual Basic for Applications (VBA) environment and object model. This is a per user and per application setting, and denies access by default. This security option makes it more difficult for unauthorized programs to build "self-replicating" code that can harm end-user systems. For any Automation client to be able to access the VBA object model programmatically, the user running the code must explicitly grant access. To turn on access, select the check box.
Jun 21, 2011 | Microsoft Office Professional 2007 Full...
VBA and macros
To understand VBA, you download HERE and read it.
Jun 22, 2009 | Microsoft OFFICE 2003 BASIC OEM ENGLISH MS...
Use of a graphic for my signature
I would use a macro. Go to the View tab, and at the far right you'll see the Macros dropdown. Select "Record Macro" and give it a name like MySig. Assign your macro to a button to place its icon on your Quick Access Toolbar at the very top along with the Save, Undo, Redo, etc. You may wish to change the default macro symbol -- just click the "Modify" button to choose from a wide assortment of icons. You can also assign a keyboard shortcut by clicking the Keyboard button and choosing your key combo.
Then step through your macro. I clicked the Insert tab, then Picture, and selected my signature image. Once that is placed on the page, go back to your Macros dropdown and select "Stop Recording."
Voilà! Please let me know if you have any other questions.
Dec 01, 2008 | Microsoft Office Professional 2007 Full...
After you record your macro do the following.
Open the excel file contains the macro. Go to tools and go to macro and click on macros. Select the macro you wish to add the close operation. Click on Step into... This will open up the visual basic editor. In the code window, at the bottom row you will see End Sub. Right before that row, type workbooks.close
Save the macro by clicking the save button. And you can run your macro to see if it works. I tried, it does :) Good Luck :)
Aug 18, 2008 | Microsoft Excel for PC
Hi motilal
Follow these steps to create multiple macros
Click the Microsoft Office Button , and then click Excel Options.
In the Popular category, under Top options for working with Excel, select the Show Developer tab in the Ribbon check box, and then click OK.
Note The Ribbon is a component of the Microsoft Office Fluent user interface.
To set the security level temporarily to enable all macros, do the following: On the Developer tab, in the Code group, click Macro Security.
In the Macros Settings category, under Macro Settings, click Enable all macros (not recommended, potentially dangerous code can run), and then click OK.
Note To help prevent potentially dangerous code from running, we recommend that you return to any of the settings that disable all macros after you finish working with macros.
Open the workbook that contains the module that you want to copy and the workbook that you want to copy the module to.
On the Developer tab, in the Code group, click Visual Basic.
On the View menu, click Project Explorer .
Drag the module that you want to copy to the destination workbook.
May 06, 2008 | Microsoft Excel for PC
Private Sub Workbook_Open()
Application.OnTime TimeValue("15:00:00"), "MyMacro"
End Sub
This will run the Procedure MyMacro at 15:00 each day.
Mar 19, 2008 | Business & Productivity Software
Writing macros
Macros for Excel and the rest of the office suite are based on Visual Basic for Applications (VBA) which is a subset of VB programming language.
If your not familier with this language then i would suggest "Googling" VBA Introduction or similar and have a look at some introductory info. If you are ok with VB then you can record doing a task you want to do and then look at the code generated to see what it has created.
Feb 02, 2008 | Business & Productivity Software
Macro on excel
Macros are a timesaving feature that allow you to record a sequence of actions that you do in excel, and replay them back later.
You give each macro a name, and you can invoke them later, and Excel will "do" whatever it is you did when you recorded the macro.
To record a new macro:
1) Open Excel
2) Go to Tools->Macros->Record New Macro...
3) Type in a name for your macro and hit OK
(A new toolbar will popup with a "stop" button on it. Excel is now recording everything you do)
4) Do something, like, for example, select some cells and make them bold.
5) Click the "stop" button.
Now your macro has been recorded! You can play it back later by:
1) Open Excel
2) Go to Tools->Macros->Macros...
3) Select your macro from the list
4) Click "Run"
The actions you performed earlier will now be executed.
Macros are written in Visual Basic for Applications, or "VBA". It is a programming language which uses the Excel Object Model to perform various actions. You can edit and create custom macros by writing the code manually in VBA. To do this:
1) Open Excel
2) Go to tools->macros->macros...
3) Select an already existing macro
4) Click "Edit"
(The visual basic editor will open, showing you the code for your macro)
At this point you are writing a program in Visual Basic. To learn how to edit macros, you need to learn visual basic, as well as the specific quirks related to excel macros in visual basic.
Recording a macro, and then using it as a template while you edit it is a common trick for making macros manually more quickly.
If you are not familiar with VB, I would not suggest attempting to edit your macros in any but the most simplest of ways. If you're brave, you can try to learn about editing macros in VBA here:
Jan 28, 2008 | Business & Productivity Software
Macros Command Help
Your Excel may have a different "Macro Security" setting. Your "Macro Security" can be adjusted: Tools, Macro, Security. I highly recommend the "Medium" setting. This will prompt you when an Excel file is opened that contains Macros to Enable or Disable. If you choose a security setting of "Low" please be very careful as this will allow Macros to run without any notice, VERY DANGEROUS.
Oct 04, 2007 | Microsoft Office Standard for PC
Need to Know fully info about Macros
Macro is a simple way to automate tasks in Microsoft Office programs. It allows advanced users to program or create their own commands in Office, thereby automating tasks. For example, a user might want to create a table with four values already in them. The user could create one, and then copy it, and paste it. However, when you restart your computer, that data is lost. Unless you open the old document and copy the table, you'll have to start all over again. Macros helps you do your tasks. By recording the table creation to a macro, creating the same table over and over is just a simple macro away.
Sep 26, 2007 | Microsoft Office Standard for PC
Microsoft Office Standard for PC Logo
105 people viewed this question
Top Microsoft Business & Productivity Software Experts
Brian Sullivan
Brian Sullivan
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Microsoft Business and Productivity Software Expert? Answer questions, earn points and help others
