Question about HP LaserJet 3050 All-In-One Printer
Distorted copy quality in the sent faxes
Sir, I have a HP 3050 laser printer[scan,fax,print]. It receives the faxes correctly and nice copy quality. It scans and prints nicely too. But when we send faxes, we receive poor, distorted copy quality complaints from the receiving fax terminal.
Pls. help.
  • pradeep2580 Apr 21, 2009
    If the rollers would have been the cause, how could the printer scan the originals and copy print them nicely. only the sent fax pages show the pblm.
    pls. analyze this correctly.
    Pradeep Kumar
  • 628 Answers
Make sure the rollers that pull the paper through are clean and that the glass is also clean. Clean the rollers with a cloth dampened with alcohol.
Posted on Apr 20, 2009
My home HP laser jet 3055 machine is not connecting
Hi:
Make sure that it is set to Auto Receive not Manual Receive. Also make sure the the telephone line cord is plugged into the Line jack not the Tel jack on the back of the fax machine.
Jul 19, 2012 | HP Deskjet 3050 Wireless All-in-One Inkjet...
Memory low on hp laser jet 3050. Please advise how to fix the problem. Thank you
solution: 1. Clear the fax memory. Here are the steps to clear the fax memory: a. Press the menu/enter button on the control panel. b. Press the > button once to select Fax functions , and then press menu/enter . c. Press or > to select Clear saved faxes , and then press menu/enter . d. Press menu/enter to confirm the deletion. NOTE: In addition to clearing the reprint memory, this procedure clears any fax that is currently being sent, unsent faxes that are pending redial, faxes that are scheduled to be sent at a future time, and faxes that are not printed or forwarded. 2. Enable the settings to print directly to the printer. Perform the following from the PC that has the printer driver installed: a. Click Start , Printers and Faxes , and check for the driver listed for the printer. b. Right-click the printer driver, and select Properties . c. Then click the Advanced tab, and check the print directly to the printer option. Click Apply , and thenOK . After performing each of these troubleshooting steps, try doing a print job and check for the results.
Jun 10, 2011 | HP LaserJet 3050 All-In-One Printer
My HP Laserjet 3050 used to print automatically after each fax sent a call report showing that the page(s) had sent. For some reason, after a service call, now it doesn't do that any more and I have...
Hi Dear
HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming
Jun 01, 2011 | HP LaserJet 3050 All-In-One Printer
HP 3050 Laser Jet: I can receive faxes but can not send fax? Help
Hello !
You need to reset fax settings first, go to the "Service" under the printers Main Menu and click on "Restore Defaults"
And then set the following settings under Fax Setup > Fax Receive Setup :
Answer Mode: Automatic
Rings to Answer: 2
Distictive Ring: All Rings
Now go to "All faxes" and change this settings:
Error correction : OFF
Fax Speed: Medium v.17
If you are using a digital line it would be a good idea installing a filter for the line
Hope this works
You can contact me on :
eliteprintersolutions@gmail.com
Jan 08, 2010 | HP LaserJet 3050 All-In-One Printer
Hp 3050 laser jet printer the fax page is black
The scanner in your FAX is nothing working -- i.e., "100%-black" or "100%-white", and so what is transmitted is what the scanner has scanned, improperly.
Dec 13, 2009 | HP LaserJet 3050 All-In-One Printer
HP Laser Printer 3050 (Sl.No. CNCK787866)sending distorted faxes
It assume you are trying to find out the solution for your Fax, in ALL-IN-ONE Printer.. If i m not wrong.
Otherwise please explain in bit more detail
Apr 27, 2009 | HP LaserJet 3050 All-In-One Printer
Printing a sent fax
in the settings of the fax there is a setting in reports that you have to turn on conformation with print out.
that gives you time date and 1/2 of the top page of fax sent
May 20, 2008 | HP LaserJet 3050 All-In-One Printer
Faxes sent through HP 3050 is unreadable
Following could be the reason behind this issue:
1. Check ink cartridges of the recieving printer.
2. Make a copy from your printer,if there is any problem while copying then replace the printer.
3. If the copying is not fine then clean the scan feeder, andif it is fine then it is an issue wih the other printer.
Jan 22, 2008 | HP LaserJet 3050 All-In-One Printer
Fax receiving problem in 3050
changing these settings:
ECM-error correction 'off'
V.34 'off'
Silence Detection 'on'
Dec 28, 2007 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 3050 All-In-One Printer Logo
207 people viewed this question
Seeker5211
Seeker5211
