Compiling avaya ir designer compilation
Avaya ir designer Tas error no phrase match for string .. while compiling
    Problem Solver:
  • 6 Answers
What is copiltion?
A... compilation? Surely not a copulation.
When one writes software, generally it's written in something that the person understands but the computer doesn't. After it's written (or while it's being written, in some cases), it's "compiled", or translated from the person's language into the computer's language. The result (the same instructions, in the COMPUTER'S language) is called a compilation. Too, the act of compiling is sometimes referred to as compilation, often followed by "linking".
Jul 12, 2014 | Computers & Internet
Can you give an example of compiler using vb?
Dim parameters As New CompilerParameters() Dim results As CompilerResults parameters.GenerateExecutable = True parameters.OutputAssembly = Output results = icc.CompileAssemblyFromSource(parameters, SourceText)
The code above uses the CompilerParameters object to tell the compiler that you want to generate an executable file (as opposed to a DLL) and that you want to output the resulting assembly to disk. The call to CompileAssemblyFromSource is where your assembly gets compiled. This method takes your parameters object and the source code, which is a string. Once you compile your code you can check to see if there were any compilation errors. We use the return value from CompileAssemblyFromSource, which is a CompilerResults object. This object contains an errors collection, which contains any errors that occurred during the compile.
There are other options for compiling, such as compiling from a file. You can also batch compile, which means you can compile multiple files or sources at the same time. Additional information on these classes is available on MSDN Online:
Feb 17, 2011 | Microsoft Visual Basic 6.0 for PC
How to write a c progaram without using semicolon
The semi colon is a required element. C and C++ will not work without them. Depending on your compiler you may be able to set a compiling setting to use a different symbol to use instead of the ; but that is the default Language required end of statement symbol. Without it or something to replace it that the compiler understands there is no way for the program to know where 1 statement or command ends and the next begins.
Jun 30, 2010 | Computers & Internet
Error occur during compiling,unable to open a header file
The compiler is attempting to access the iostream header file and it either cannot find the file (not in the default location or it has been told to look in another location where it doesn't exist), or the file security is set so the current user does not have read access to the file.
Apr 15, 2009 | Computers & Internet
Rendering problem in Premiere Pro CS3
I would suggest u to reinstall the software. after this it should work
Jun 26, 2008 | Adobe Photoshop 7.0 for PC
RUN TIME ERROR 2147217842(80040e4e)
have u check the net framework version of the os ur using
Dec 18, 2007 | Computers & Internet
Need an updated Linux driver for WF748-UIc
http://zd1211.ath.cx/wiki As per that website, the drivers are now included in the Kernel since 2.6.18. If you're manually compiling your kernel, you can find the module in the menuconfig of the linux kernel source (ie in the `make menuconfig` menu) in: Device Drives -> Network device Support -> Wireless LAN (non-hamradio) -> Wireless Lan Drivers -> USB ZD1201 based Wireless device support
Jan 19, 2007 | GigaFast Ethernet WF748-UI (WF748UI)...
Computers & Internet Logo
189 people viewed this question
David Payne
David Payne
