Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
No sound when my computer is connected to my Sony Bravia TV
My computer has a DVI output for video and I have a DVI to HDMI cable attached. Vidoe works great but I have no audio from my computer. The Sony TV audio ro audio 3.5mm jack to jack does not work when the video is playin DVI to HDMI. There is a red and while RCA jack connection under the HDMI port connection that is labeled audio on the computer. Do I connect this from my 3.5 audio out jack on the computer to these two RCA jacks? If so where can I get this cable?
  • 87 Answers
If your computer has a svga output use input 7 on tv with vga to vga cable and 3.5-3.5 Radioshack 42-2387 cable for audio for best results. If you use the dvi to hdmi on input 6 on tv use 3.5- rca Radioshack part number 42-2551 1/8=3.5mm.
Posted on Apr 20, 2009
How can i connect my hp pavillion s5610y to my bravia tv
This is a bit complicated since there is no HDMI output capability to the PC, only VGA and DVI. First, check to see if the Bravia has one of its HDMI ports listed as DVI capable. If it does, it should have accompanying audio jacks (red/white) for it. What you would need to get is two different cables for interface. The first is a DVI-to HDMI cable to run from the PC DVI port to the Bravia DVI-compatible HDMI port. You cannot run the DVI to a regular HDMI port because if you do you will get only picture and no sound. DVI outputs, unlike HDMI outputs, do not carry the audio signal. A DVI-compatible HDMI port on a TV set will connect the video from the HDMI port and the audio from the reserved audio port accompanying it. The second cable you need will be a mini stereo audio plug to RCA jacks. This will connect between the PC audio out (green), and the DVI audio plugs on the set. See pictures for cables below
Once you have this done, selecting the appropriate HDMI port on the set should result in audio and video getting to the unit. If you only need the video (you are going to use the PC speakers), then you don't need the audio cable and you can use any HDMI port, but you cannot control the volume using the TV set remote. You would need to use the PC volume settings. (Just as an afterthought if the set has no DVI-compatible HDMI port).
Jan 26, 2016 | HP Computers & Internet
BRAVIA KLV-37U300A 37 in. LCD TV: I have a HDMI cable attached to my Sony Bravia and...
t con is not working is t con is repairbale or can i get ic becouse here in pakistan is not available.
May 17, 2010 | Sony BRAVIA KLV-37U300A 37 in. LCD TV
Cant get hdmi to work
What device are you connecting to the TV? Are you using an HDMI to HDMI cable or a DVI to HDMI cable (or another adapter in the cable or between the cables)?
Try using a different cable. Try connecting the source device to another TV. Basically, you want to see whether the TV's HDMI input is bad, the device output is not active, or if the cable is bad (or an adapter attached to the cable is bad). Adapters are likely failure points. If you are using a DVI to HDMI cable, check your cable and device specs. Single-link and dual-link DVI are different and not interchangeable when attached to an HDMI cable end.
I hope this helps.
(some computers (esp. laptops) will have external video ports turned off by default and you need to turn them on before you try to send the output to an external monitor (TV).)
Apr 17, 2010 | Televison & Video
How can I connect Panasonic TH-37PX60U Flat panel plasma tv to my computer?
It will depend on your video output options on the computer. If you have HDMI output, just use an HDMI cable and an audio cable (this will need to be a 3.5 mm to RCA audio cable). If you have a DVI output, use a DVI to HDMI cable and the audio cable (or a DVI to HDMI adapter and either a DVI or HDMI cable depending on which side you want to put the adapter). If you only have VGA out from the computer, use a VGA to DVI adapter and the DVI to HDMI connection and the audio connection. (Theoretically this should work but each adapter will have some signal loss issues.)
Some graphics cards have a video output, S-video or Component video, which would also connect to your TV with the audio cable. (Read your cards manual for more information)
I hope this helps.
(For DVI to HDMI cables, you will need to check if you have a single link or dual link DVI output. The wrong cable may not work.)
Feb 20, 2010 | Panasonic TH-42PX60U Television
How can i watch movies from computer to my tv
You probably need to get a composite video output card for your computer. Actually, I've seen many cards that have both a composite video output AND a DVI output port on 1 card. The DVI output will give you a noticeably sharper picture than composite video, but you need to check if your TV has a DVI or HDMI input. (If it was manufactured after 2000, it probably does.) If you TV was manufactured after 2006, it probably has 1 or more HDMI inputs instead of DVI. You can buy a DVI to HDMI converter cable. That takes care of the picture; to get sound to the TV, you will need to connect separate sound cables to your TV. Your computer needs to have a line-level output jack on it's sound card, and you will need to get an adapter cable (from Radio Shack) to convert the stereo mini-plug to 2 RCA type plugs to plug into your TV. And that should do it!
Dec 17, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Can i connect a dvid cable from the monitor to my flat screen tv hdmi to watch videos from my computer? Thank you Martin
the Flat Screen TV if has, a HDMI input, also has VGA Input.
You must choose :HDMI or VGA, if HDMI The VGA board must Have HDMI Connector, and you connect a HDMI cable to the TV.
The HDMI is a digital signal input/output, VGA is Analog Signal. You must have Signal Converter if you Use the 2 signals
Oct 31, 2009 | LG Flatron F700P 17" CRT Monitor
No sound on pc connection
HDMI outputs from devices such as DVD players do carry both video and audio, but the HDMI output from your computer video card only carries video. You'll need to connect a cable from the computer sound output to the TV as well.
Feb 25, 2009 | Sony KDL-26U2000 26 in. LCD Television
Right cables for connecting devices
You have connected from PC to TV right???
1.To get the video you have to connect to TV
2.Please take a separate cables for to listen audio and to watch video,
for audio connect cables from DVD Player to Home Theater you can listen the audio
for video please connect the HDMI video to TV Where You can enjoy both.
Jan 07, 2009 | Audio Players & Recorders
Color screen
If you are hooked up with a DVI cable you need to either use hdmi, component cables or turn off the non hd override...
Jun 15, 2008 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
758 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
