Question about D-Link AirPlus DI-524 Wireless Router
Router Configuration in "Wireless Client" Mode
Hi there, who knows if it is possible to configure a DI-524 wireless router to be able to work NOT as access point but as wireless CLIENT? The idea is to be able to connect WIRELESS (!) a small home LAN to an external wireless access point. Rem.: My old D-Link router DWL-900AP+ works pretty good in this mode! Thanks in advance! yacc
  • Dr. Lector Sep 21, 2007
    Hi Benimur,
    thank you very much for your hint with the open source firmware! I´ll try to replace the original firmware. Do you think the DD-WRT or WRT54G firmware will be able to work with the DI-524?
    Kind regards!
    Brigadier General:
  • 6,966 Answers
Hi, If I understand you right, what you want to do is to make the DI-524 as a repeater, i.e. receive from the "external wireless access point" and re-broadcast to your "small home wireless LAN". Unfortunately, no. D-Link made it a point not to enable repeater mode in the DI-524 model (firmware has no support for wireless distribution service). Other than your old DWL-900AP+, one other model they have that can do this is the DWL-G710 but only in WiFi and not in the Ethernet port. On some other brands of similar feature models, the original manufacturer's firmware may be replaced with an open source firmware with more features enabled. An example is the LinkSys' WRT54G and the replacement firmwares by Sveasoft and another named DD-WRT. Hope this be of some information to you. Post back should you require additional information. Good luck and kind regards.
Posted on Sep 20, 2007
  • Louie  Role
    Louie Role Sep 21, 2007
    Hi again,
    WRT54G firmware for a DI-524 - unfortunately again no. Different chipset, different design.
    DD-WRT version for DI-524 - don't thinks there's any (my familiarity with WiFi bridging and repeater begins and ends with WRT54G).
    However, friends in the business suggest possibly if and only if the version of DI-524 uses an Atheros chipset. You can perhaps learn more about DD-WRT at www.dd-wrt.com and Sveasoft at www.sveasoft.com. You can also tryhttp://sourceforge.net/projects/wifi-box... and http://openwrt.org/. Further you can also check up on Alchemy.
    Cheers.
2 Suggested Answers
SOURCE:
SOURCE: DI-524 Configuration as "Client"
It's correct, exactly this is the point. The wireless router (DI-524) should realize the wireless connection between my switched LAN and the external access point only. This mode is called "wireless client" mode and is unfortunately no more supported by the DI-524 firmware. :-( Now I'm looking for an another (maybe open source) firmware for my router. Thx!
Posted on Sep 21, 2007
Http//192168.0.1
Hi!
The wizard (link below) will get your wireless up and running in just a few minutes.
Hope this is helpful.
-Steve
DI 524
Jan 29, 2013 | D-Link AirPlus DI-524 Wireless Router
Well.. i try connecting through the 192.168.0.1 but i wont get through to the config site
What do you mean??? the password do not work??? the configuration page do not appear???
First is your computer is connected to the DI-524 with a wire??? or not???, there could be a 1000 things that can prevent you to reach the configuration page of the router....
Check network connectivity first (wires, IP address, etc...) never try to configure a wireless router from the wireless connection, (always from the wired connections)
Apr 09, 2011 | D-Link AirPlus DI-524 Wireless Router
Using DI-524, can't find the wireless network
Have you properly configured the web based Wireless configurations of the router? Also check WLAN IP configuration of your laptop. Configure WLAN IP configuration to DHCP and try again.
Regards;
Hassan
Jul 22, 2009 | D-Link AirPlus DI-524 Wireless Router
Want to know the pre shared key
If you don't know your pre shared key or forgotten it. You need to access the configuration page of your router and create a new network name and a sign a new network key or pre shared key. Create the profile of your SSID/Wireless network connetion under wireless settings.
Jan 17, 2009 | D-Link AirPlus DI-524 Wireless Router
Belkin wireless set up
Hi, As you ave the modem in bridge mode and also it works ine with wired connection just follow the instruction below for wireless
1.Login in to the router - > wireless settings
2.Configure your wireless using SSID and WEP and save settings
3.Laptop : Using windows wireless client configure the client using the same SSID ,WEP as configured in the router(view available wireless network in wireless properties)
(by default OEM wirelesss client takes over the wireless configuration in branded pc.to disable it and use windows wireless client..control panel ->administrative tools -> services -> enabl2 wireless zero configuration)
14.after all configuration shut the desktop,laptop,router,mdm and pwr them in seq..first modem and then router and then your desktop or laptop
Cheers !!!
Feb 24, 2008 | Belkin (F5D7231-4) Wireless Router
DI 524 Router Not able to connect to office VPN on Wireless
I have the same model router at home, just checked the settings, you should be able to pass through the router with a normal vpn connection.
If you use a special VPN client, like a CheckPoint Secure VPN client, the router might block it. Also you might want to ask your office's sys admin if you are not blocked by the firewall or something similar. Your office's sys admin will prolly solve your problem since he knows your work network's configuration and setup and how to connect to it.
Nov 08, 2007 | D-Link AirPlus DI-524 Wireless Router
Forgot the URL for my DLink 525 Wireless router
Hi, To enter the webinterface configuration of your D-Link 524, type "192.168.0.1" at the address bar of any browser. UserName is "admin" and password - leave blank. Good luck and kind regards.
Oct 10, 2007 | D-Link AirPlus DI-524 Wireless Router
hi
just had same prob if you go to dlink site in phillipines there you will find the latest firmware for dlink 524 . i couldnt belive i had to do this as all links to uk site had no pages diplayed .i went first to .singapore site then to australia but the most uptodate firmware i found was on phillipines site
ver2.06b02
Sep 20, 2007 | D-Link AirPlus DI-524 Wireless Router
Have D-link 704 router, can I connect the DI-524 to it also to add wireless?
Hi, I have not tried it myself with DLink but with LinkSys, yes it will work. It may take a little configuration tinkering but should work. However a few notes: 1. You should only have 1 DHCP server (both have this feature); 2. You can not have 2 identical IP address; 3. I suggest you make the 524 as the gateway and the 704 as a slave; 4. In effect you will connect 1 of the LAN port of the 524 to the WAN input of the 704; 5. You have to copy the WAN settings of the 704 to the WAN settings of the 524; 6. Or if you want to retain the 704 as the gateway, disable the identical features in the 524. I suggest you treat the 524 as a client of the 704. Hope this gives you some idea and work out for you as it did with my LinkSys. Goodluck and kind regards.
Aug 17, 2007 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
6,299 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
