Question about Maytag MMV5186A Microwave Oven
Maytag microwave model MMV418AAW doesn't cook
Turntable also doesn't operate, lights and fan operate normally, and timer counts down
MicrowaveSvc
  • 9098 Answers
SOURCE: mvp Iv microwave oven model vm12av-1
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Aug 02, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: I have a Whirlpool MH6130XEQ-0 microwave that doesn't heat food
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and your magnetron is still under the part warranty, but you would have to pay labor.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
If within the magnetron portion of the warranty (5-9 years) but out of the original full warranty (1 year), the manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If nothing else, you can save about $50-75 if you remove it from the wall and take it to a Whirlpool-authorized servicer.
You can find your nearest Whirlpool/Maytag-authorized servicer here.
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Whirlpool owner's manuals and installation instructions here.
Posted on Mar 06, 2009
tomsat69
  • 219 Answers
SOURCE: Maytag MMV4205BA microwave buzz/grind when operating then no power
you may have some arching inside where your magnatron is located.If you open the door on the right middle part there is a silverplate on the wall .If it is burned you may need to replace magnatron.if you do not seee burn marks it may still be the magnatron hope.that would be the only possible thing that would make the noise other then the mtor plate out of place.
Posted on May 15, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: I have an MMV5000,the microwave will cook food but
Have your cooktop lights been replaced lately?
It is vital that the cooling fan runs, or the magnetron will be destroyed.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on Aug 04, 2009
  • 8404 Answers
SOURCE: Maytag Over The Range Microwave: Melted glass turntable, rollers
Considering the melting pooint of glass ...
Normally, microwave travels around round surfaces (Look at the B-1 for example) If you put flat metal in a microwave, you will create sparks ... lots of em. Is it possible you have something going on with one of the wheels ... like a piece of tin foil?
At a minimum, I think id be inspecting everything inside very carefully and then give it a good cleaning.
You might want a pro in your area tale a look at this as well.
a
Posted on Oct 05, 2009
Microwave timer works but will motor will not run/cook.
If everything works on the unit, but you do not receive any heat or possibly the turntable does not turn you have a faulty magnetron (controls heat) and a faulty motor (controls turntable). You would require service on the unit, if parts are available. Some microwaves are so small in cubic foot size, that manufacturer's do not have parts available for purchase/repairs.
Dec 24, 2012 | Frigidaire FMV156DC Microwave Oven
Kitchenaid KCMS185JSS
The problem is one of the door switches has failed, usually caused by food partical buildup, switch must be replaced for normal operation.
Mar 12, 2012 | KitchenAid Microwave Ovens
Frigidaire model cfmv156fmc allows programming, lights work but when hitting go wont turn on yet timer is counting down.
If the inside light comes on when you try to cook, but the turntable and internal cooling fan do NOT, then that's a bad bottom door switch or that switch's mount.
See this helpful text file.
If the inside light, turntable, and internal cooling fan DO all come on when you try to cook, but it does not cook, then you have a bad relay or connection on the control circuit board, which we can repair for $39.95. Details here.
We have the service manual and have uploaded it to our site here to help you.
Jan 11, 2011 | Frigidaire Microwave Microwave Oven
Our microwave is not heating and the turntable is also not working. When I try to cook something the timer starts counting down but nothing else happens.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Nov 03, 2010 | Maytag MMV5186A Microwave Oven
The timer counts down but the microwave doesnt turn on.
I have a FNCB115GC Microwave problem. The microwave has a icon on the left hand side of the panel that looks like a opened book on a stand with lines on top. This is best that I can descibe it. The microwave turntable does not move or the microwave does to come on but the light comes on and the timer will count down. I have cleared the microwave and unplugged it with no results. Please help. Thanks in advance.
Jun 03, 2010 | Frigidaire FMCB115GC Microwave Oven
GE Microwave Model # JE1860: Unit does not heat. The timer counts down, but the oven does not heat.
When you hit Start to cook, do the inside light, cooling fan, and turntable come on?
Any unusual noises? Is it louder or quieter than usual?
These answers will help me judge whether it's in the high voltage section (magnetron, transformer, or diode) or the control section (door switch or control board relay or connection).
Nov 27, 2008 | Microwave Ovens
JVM1190 wont cook
You have a blown actuator. This is the device that creates the microwaves that cook the food. The cost of one of these will be as much as a new unit.
Nov 09, 2008 | GE JVM1190 Microwave Oven
Maytag MMV5186A Microwave Oven Logo
69 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
