Question about Nokia 3230
Nokia 3230 Joysitck Center Butten not working
I am using Nokia 3230. Now the Joystick center button not working. other 4 buttons are working properly. Pls give alternative solution for that Center button. D.Muthu Prakash
    Sniper:
  • 111 Answers
2nd Board replacement
Posted on Jan 27, 2008
    Scholar:
  • 151 Answers
Just look on the screen and press the relevant side buttons. For example, if your mobile shows MENU on left then click on the left button. There is no alternate solution for this.
Posted on Sep 21, 2007
SOURCE:
Ok button and callaing button and joystick up,down keays are not working.
hi you need to buy a new keyboard no the buttons but the keyboard below the buttons.
Dec 28, 2011 | Nokia 3230 Cellular Phone
My Nokia 6300 is dropped .Then the LCD and replacing case are broken. It still rings and can dial. How can I recover the contact numbers on the phone without DISPLAY? Thanks in advance,
hey
since the phone is ringing and you are able to dial the mother board is intact. you dont need the display i will send the sequence of keys to be pressed which will lead to copying of the contacts to the sim.
then you can put the sim in a different phone and view them.
menu( center button in the joystick key)
up (in joystick key)
center button
center button
top left button( above the call key)
center button
down(in joystick key)
center button
center button
now it will start copying all the contacts to your sim.
wait for a minute or two
and then you have the contacts copied to your sim.
b4 copying clear the sim so that it has enough memory to copy all your contacts
hope it helps
Sep 24, 2010 | Nokia 6300 Cellular Phone
While removing joystick circuit got damaged wish to see diagram & way to repair it
by seeing a diagram you will not able to repair it , if you try to repair it , remember that you are damaging the phone again and again, better take to nokia service center they will fix it properly......
Feb 04, 2010 | Nokia 3230 Cellular Phone
Ran into wall with ranger wheelchair now green light comes on and flashes then goes to red and cuts off chair will not go at all please help!
Sounds like you've knocked the joystick off-center in its gymbal mount. This is a pretty common problem since the joystick usually takes the first hit into walls, doorframes, and also happens a lot when the chairs get run under table and counters. The power control module has a "prevent" circuit which will not allow the chair to boot-up if the joystick is not top-dead-center, otherwise, the chair could be turned on while pushing the joysitck full-speed forward, etc. and you could inadvertantly run over someone or drive off a cliff!
There's nothing you can do to repair this yourself. If the chair's under warranty, call your provider for a replacement. If not, call your banker as the new joystick is about $1,000.00. There's a company I found that advertises it can repair these but I have never used them. It'd be worth a try to save all the money. Here's the link.
http://www.flightsystems.com/cart_controls/wheelchair_powered_scooter_market_cart_controls.htm
Good luck
Oct 16, 2009 | Health & Beauty
3230 nokia processing faild
The nokia need to be reflash take the phone to a mbile service center and have that done
Sep 12, 2008 | Nokia 3230
Focus
Switch it on auto (or easy) first and see if focus works that way. If your on manual (or P) You have to use the joystick on the display to control the focus. All you do is push the center button on the joystick, move the joystick down to focus, press the center on the joystick and adjust it left or right. Press the center on the joystick when corrected.
Jun 22, 2008 | Canon MV730i Mini DV Digital Camcorder
3230 joystick
piles sir i am request my mobile 3230 joystick up down no waking piles help emijate
Jun 02, 2008 | Nokia 3230
Blank screen after switching on the phone
the only way to restore your phone software is to contact the Nokia service Center it will be free if you have warranty an it will bw charged around $50-150
Apr 19, 2007 | Nokia 3230
Nokia 3230 Logo
140 people viewed this question
Top Nokia Computers & Internet Experts
Anthony Ward
Anthony Ward
k24674
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
