Question about Panasonic Lumix DMC-FZ7 Digital Camera
Sanyo VPC-s500 i cant get it to install drivers or find them so i can upload pictures to my computer
Need a little help with my sanyo VPC-s500 camra i have windows xp, im trying to get it installed on my computer so i can upload pics, now when i plug it all in and turn on camra it says Found New Hardware Wizard This wizard helps you install software for: S500 then it says, If you hardware came with an installation CD or floppy Disk, insert now. then it says the following, What do yuo want the wizard to do? option 1. Install the software automatically ( Recommended ) Option 2. Install from a list or specific location ( Advanced ) click next to continue * option 1. continue says, please wait well wizard searches then says, The hardware was not installed because the wizard cannot find the neccessary software !click back if you have installation media such as a CD-RoM, or if you know the location of the software *Option 2. continue says, Please choose your search and installation options 1, Search for the best driver in these locations. use the check boxes below to limit or expand the default search. witch includes local paths and removable media. The best driver found will be installed **box 1** search removable media (floppy, CD-RoM) **Box 2** incluse this location in the search then has a drop down select bar with A:\ on it and at the end has a Browse button 2, Son't search, i will choose the drivers to install. Choose this option to select the device driver from a list. windows dose not guarantee that the driver you choose will be the best match fro your hardware no matter what i search for or try to do i get this please wait well wizard searches then says, The hardware was not installed because the wizard cannot find the neccessary software please help me!
  • Anonymous Dec 25, 2007
    says I don't have a driver on the disk that came with the vpc-s500
  • Anonymous Jan 09, 2008
    can't upload pictures from camera to computer
The simple solution to this problem is that no drivers are required. This camera is treated as a removable (secondary) drive just as if it was a USB thumb drive or external hard drive.
First go to settings on the camera by rotating the dial to the wrench icon.
Turn the camera on and select Set-Up 2
Select USB
Select PC
Your camera is now ready to use with your computer.
Now plug your camera into your computer and check under My Computer for the drive to show. You can now copy files over to your computer from the camera.
If the drive isn't showing you'll have to go into Disk Management to view it
Disk Management is under Administrartive Tools located in your Control Panel (or Start Menu if you have it set to show there)
Select Administrative Tools
Computer Management
On the left hand side click Disk Management (or on the right click Storage then Disk Management)
Finally you can now Right Click the cameras drive and chose Open
Posted on Jul 08, 2009
6ya staff
SOURCE:
Cant upload pics
Install proper driver before making a connection.
Aug 28, 2009 | Sanyo Vpc-s1070w Digital Camera
I have a sanyo vpc-t850 camera and looking for drivers to upload pic's to computer
The sanyo does not need any drivers, plug it in your computer with usb, turn camera on, select "PC" and press the SET button. now your camera will show up in my computer or computer as a removeable storage device and inside you will find the pictures.
I have the same camera so I know this is how its done.
Jun 11, 2009 | Sanyo VPC-C5 Digital Camera
Don't have the CD or driver to upload photos
type in the camera name. and you will get free downloads from the site.
Mar 25, 2009 | Sanyo VPC-S500 Digital Camera
Sanyo digital camera
You shouldn't need any extra software to download your pictures. Most digital cameras are accessible through windows just by plugging them in. Then you can browse through your camera and copy them accross manually. I imagine the Sanyo disc may have had a program that made this automated but I doubt you will find it for download as it would probably have copyrighted material on it. In any case I cannot find it for download.
Good Luck.
Please rate my advice, good or bad.
Jan 30, 2008 | Sanyo VPC-S500 Digital Camera
Sanyo VPC-S500 DIGITAL CAMERA
Sharay, Did you installed to your computer the software CD you received with the camera? In case of a positive answer, check whether the software you received, support the Vista (should be written on the CD). If not, go to Sanyo web site and look for the relevant drivers for your camera and OS. Good luck!
Sep 02, 2007 | Panasonic Lumix DMC-FZ7 Digital Camera
SANYO VPC S500 DIGITAL CAMERA
You have loaded images previously- so it works OK huh! Your are Windows XP/2000 -tell me Remove any software you may have loaded that came with the camera, Now plus the camera in, switch it to the 'upload position' and it should appear in my computer as an extra drive - and/or Camera/Scanner wizard will come up and ask what to do next. If you have the CD - there is a manual on it in PDF format- you do not need any software to load images.
Aug 04, 2007 | Panasonic Lumix DMC-FZ7 Digital Camera
Panasonic Lumix DMC-FZ7 Digital Camera Logo
636 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
