Question about Canon Office Equipment & Supplies
Error code 343 on canon printer image class mp 360
  • 2 more comments
  • bbnt10 Apr 20, 2009
    At this point in time the alarm for error no 343 is hard to move.
    Tried as suggested and cannot bring up that mode.
    The number of functions on my printer is 6.
    The ink tank is nearly full warning has been on for a while, have tried turning off the printer but to no avail.
    Keep trying.
    have tried most options but still the same, the halfwits at canon said i would have to replace it, b----****.
    keep trying son i am still here
    funny you should say that, when i lift the top the ink cartridges do not go to the centre of the printer,
    could this be part of the problem and am i looking at it wrong
    we seem to be heading in the same direction but i cannot get the ink cartridges to come to the centre of the machine.
    keep going i think we are getting there
  • 1,183 Answers
The error code is for the "waste tank full "
Manual Reset procedure Waste Ink Tank for Canon MP390 and Canon MP360 Just Follow this step to reset waste ink tank full:
  1. Start with printer on, press aadditional functions, Scan, Copy, Scan. Now you should be in service mode.
  2. Select Test mode which is like the last available selection
  3. Select #8 Printer Test, it will do something here like cleaning or something then it will come up with some other option this is where it gets a bit confusing cause now all it says is like 8-2 or 8-3 push the + or - button until it says 8-3 then hit the select button
  • The menu will now say EEPROM Clear
  • Select Ink count which is option (0) and press set
  • Then press Stop/Reset Followed by the power button and then wait for it to restart.
Thanks
proton
Posted on Apr 20, 2009
  • 3 more comments
  • Mandeep  Singh
    Mandeep Singh Apr 20, 2009
    Note : to enter service mode Press the Menu + copy key or Menu + Scan key
    Thanks
    Proton
  • Mandeep  Singh
    Thanks for posting back , wanted to know what all steps have you tried with the cannon technical support , so that we donnot end up repeating the same.
    If even after resetting the printer the problem doesnot go away the problem could be due to a faulty ink sensor or the spcnt board.
    Thanks
    proton
  • Mandeep  Singh
    According the service manual that i found , both the mp360 and mp390 have the same error codes
    The problem can be resolved by replacing the waste ink cartridge only, rather than the whole printer .
    http://www.kaj-max.dk/Download/Computer/...
    Its mentioned on page 5-7 of the service manual .
    Thanks
    proton
  • Mandeep  Singh
    I guess, you are having two problems with the printer together, lets try to first align the print head , to remove that point failure from our list of troubleshooting.
    step 11Turn the printer on and lift the scanner until it locks in place. The ink cartridge holder will move into view. Remove the cover from the ink cartridge holder.
    Step2Grip the tab at the front end of the ink cartridge. Pull the tab towards you, freeing the cartridge from the printer. Remove the ink cartridge.
    Step3Reseat the replacement ink cartridge into the appropriate slot in the ink cartridge holder. The black ink goes on the left side, and color ink goes on the right.
    Step5Restore the cover to the ink cartridge holder and lower the scanner into place. The printer will display a message asking if you have replaced an ink cartridge. Press the left arrow button.
    Step6The printer will ask which cartridge you replaced; use the right arrow button to navigate to the correct choice and press the left arrow button to confirm your selection. This will reset the printer's ink counter.
    Step7Insert a piece of paper into the tray and press "Additional Functions." Use the arrow buttons to navigate to "Maintenance" and press "Set." Use the arrow buttons to navigate to "Align Print Head" and press "Set" again to generate a printout.
    Thanks
    proton
  • Mandeep  Singh
    Well, if it still doesnot move , then its time to get your hands dirty , because the printer requires a full service overhaul. The cartridges could be stuck because of Foreign material or dried ink in head cleaning unit (also known as "purge unit") , or waste ink pump jammed up.
    You can download the service manual for the printer first from the following website
    http://soft-manufaktura.ru/servman.html
    Caution: You would require specailised tools for the job, second its slow and tedious process to remove components from the printers.As they generally are not serviced at home. Incase you need me to find a service tech for you to do the job, do let me know which city state and zip code you are in. The instruction for cleaning and removing the cartridge tray is given below
    http://www.techimo.com/forum/technical-s...
    Best of luck
    Proton
How to fix the Canon Image Class Printer 4750 error code e001-0000
Canon IR2270/IR2870/IR3570/IR4570/IR5070/IR5570/IR6070/IR6570
Enter the service mode (Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again).
Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here you can reset all error codes on by one.
for more details : www.mytechtime.com/2011/10/canon-error-e001e002-e003-e007.html
Jan 04, 2015 | Canon Office Equipment & Supplies
I own a Canon Image Class MF 4550 d. This morning
Try turning the printer off and back on. If this does not work, try rebooting your computer. Another choice is to go to the Control Panel > Programs > Unistall a Program and delete the printer's software, reboot your computer and re-install the printer's softwre.
If this does not work, you can always return your printer for a full refund or ask them to exchange it for a new one.
Sep 07, 2013 | Canon I-Sensys Mf4550d All-In-One Laser...
Canon image class mf4412 error code 301-0001
good affternoon i want the salution of canon printer 301-0001 eror
Mar 27, 2012 | Canon Office Equipment & Supplies
It keeps coming up with Printer Check and then flashes ##343 FAX TYPE: CANON IMAGE CLASS MP390
The ink absorber for ink test is full of waste ink.
The waste ink absorber will need replacing, and the detection value needs to be set at '0' in Service Mode.
Nov 19, 2009 | Canon Office Equipment & Supplies
How do I change the Ink on ImageCLASS MP 360 Have been given printer and do not have instructions with it.
With the mp 360 you just have to lift the scanner unit with power on and the carriage will move to the center allowing you to install new inks. unless there is an error code...
Jun 24, 2009 | Canon MultiPASS MP360 All-In-One InkJet...
Error 002 with Canon image class MF 8180 C
I usually open the back cover, top cover, cartridge cover and pull out the paper tray. Sometimes this clears the alarm, if this does not clear the alarm, I unplug the printer for a couple minutes. Between opening and closing the covers and unpluging the printer, the alarm goes away. Ray
Dec 30, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
How to work scanner and copier on my image class MP360
i have canon image class MP 360, but i don't have the cd, for downloading the canon. can u help me, to solve my problem. because it's urgent. thanks anyway..
Oct 16, 2008 | Canon SmartBase MP360 All-In-One InkJet...
Canon smartbase Mp 390 ##343 Check printer
can you help my printer canon smartbase mp390 not working gives notice check printer ##343
Jul 25, 2008 | Canon SmartBase MP390 All-In-One InkJet...
Error code ##343
We have just attempted to install an Cannon imageclass mp360 and the error message "check printer ##343" is displayed.
Can you please help.
May 14, 2007 | Canon SmartBase MP360 All-In-One InkJet...
old marine
old marine
