Question about Mitsubishi WD-73833 73" HDTV
Single HDMI Input. Need to connect several HDMI components
I own a 62" Mitsubishi DLP TV.  It only has one HDMI input.  Is there a way to connect several HDMI components?  I purchased a device to be able to connect up to three HDMI components, however, I could only assign one component to the HDMI input on the television.  Any suggestions?
    Scholar:
  • 31 Answers
Number 1 would be to connect the 3 Devices to a Receiver with 3 HDMI Inputs, So this way you get the HDMI Audio as well. 3 in and 1 out to the TV as you know. The other way would be to get a Key Digital HDMI 3 to 1 Switcher. I have used these a lot in the field on installs and they work Great. They also have 4 to 1 if you think you might need more. No programming of the piece you just plug in and setup your TV in the HDMI Menu and your other Devices. If they don't sync AUTO! The Receiver would be Best I feel, Some let you assign 2 different Video and Audio sources at once. Such as Video from a Game and Audio from a CD. Hope this helps out!
Posted on May 05, 2009
Scrolling diagonal lines
The cable box signal on the components video have a too high refresh rate frequency, that is the reason for the lines.
Use RCA cables or an alternative connection.
Other solution is changing the display out settings for cable box (from PAL to NTSC etc.)
Sep 01, 2008 | Mitsubishi WD-62525 62" Rear Projection...
My Toshiba 62hm195 DLP HDTV's HDMI ports have been losing sound intermittently. Both HDMI ports while connected to multiple devices (HDTV cable box, Panasonic Streaming Player) lose sound intermittently...
Your problem is in the streaming player. It is not keeping up and when an HDMI loses connection it will not auto find it again. To verify this take the Panasonic out of the loop and see if this fixes it. I love HDMI but it is touchy
Feb 18, 2015 | Toshiba 62HM195 62 in. HDTV DLP TV
Wd65738 blue screen
blue screen means no video signal, if the source is on hdmi ensure the cable is rca or in simple audio video jacks which u will have to connect in the dvi input of the tv reason is hdmi means high definition interface and transmits by hdcp like the data of an internet meaning its digital platform which the tv can only process thru the dvi inputs or component y,p,b
Jul 17, 2013 | Televison & Video
What channel to set for dish network
Depending on the type of cabling your using the input may vary. If you are Connected using a digital cable such as an HDMI or component (y/pb/pr) cable then you want to set the TV to the HDMI or component input by pressing input or source on your TV. If this is connected using coaxial cable tune the TV to channel 60, 62, 73, 75, 3 or 4
Daniel Busa
DISH Network
Customer Service
Apr 21, 2011 | Vizio L32 32 in. LCD HDTV
HDMI connection
You should have an Input selection on your remote, keep pressing it until HDMI is high-lighted and that should be it. The other method is going into the menu under input and select HDMI. Let me know?
Mar 14, 2009 | Televison & Video
I have a Mitsubishi WD-62525, and when the Directv installer came out, he said that he could not connect the box to my tv because he didn't know how to get my tv in HDMI mode. From what I am reading, it...
Your right connect the HDMI output from the directv receiver to an HDMI input on your tv. Change the tv input to the HDMI input and it should work. If your tv does not have HDMI input then it should have component input indentified as red blue green connectors on the back of tv. This is for video only. Connect the red and white for audio using the yellow/red/white cable that was included with receiver. The red blue green cable is also included with receiver as well as the HDMI cable. Did this installer educate you on how to use your directv equipment. If you are paying for HD access but your receiver is not connected the an HD input on your tv then you are not getting what you are paying for. This should of been resolved during the installation. The installer either is incompentant or just did not care. Call directv and demand them to make their receiver work with your tv if this means a field supervisor tech being sent out to correct this.
Mar 11, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Random flashing streaks on screen
Check multiple inputs and multiple sources. Check your dvd player; does it happen there? If not, you are probably right to suspect the cable box.
When you are checking multiple inputs, you want to make sure that if your cable box uses component or HDMI, that you check your DVD player on the same style input.
The reason for this is that your electrical chassis treats the analog (composite, s-video) inputs different from the HD and digital inputs (component, DVI, HDMI).
If you try your DVD player and cable box on the same input and experience the same probelm, you probably need to have the electrical chassis rebuilt in order to fix a problem on the tv's FMT board.
Cost: $800+
Wait time: 4-8 weeks.
Sep 23, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi HDMI connection trouble
I have the same issue with my 73". Rather then going over all of my connections and equipment I'll just say htat I feel your frustration. I have been on the phone with Mitsubishi directly and it appears as though they have a free software upgrade that should address this problem. If you call 1-800-332-2119 and press 4 in the menu you will get someone to help you. Be patient. They will make you go through all of the fixes that you have already tried. They will mail you a flash drive that goes right into the front USB port of your TV. I hope this is of help. Good luck.
ret4good
Jan 04, 2008 | Mitsubishi WD-73833 73" HDTV
Mitsubishi WD-73833 73" HDTV Logo
425 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
