Question about Canon PIXMA MP530 All-In-One InkJet Printer
How to tell the printer to print on both sides of
How to tell the printer to print on both sides of the paper
  • 716 Answers
The normal way to set this is to go to your start menu and click on printers and faxes. Right click on the printer you want to double side print then scroll down to properties and select it.Next go down to where it says printing preferences. Next select Print Layout tab and at the bottom it will have a two sided option select that and click on ok at the very bottom and then ok on any tab that fallows to close out of this option. Now enjoy and let me know if there is any problem and I will further assist you.
Sincerely,
Michael Scott
Posted on Apr 20, 2009
Please tell me how to enable duplex printing in my Cannon MP470. This option is checked on the printing dialog box, but only one side of paper is being printed. Thanks in advance for your help! SMK
The printing dialogue box may allow you to select duplex printing but you may have to physically turn the paper over yourself UNLESS you purchased a DUPLEXER for your printer.
If the paper feeds from the back and the finished product comes out the front, you will have feed the paper back into the back of the printer.
Apr 03, 2011 | Canon PIXMA MP470 All-in-One Printer
I used the print on both sides of paper. Now when I try to uncheck the print both sides it shows it unchecked but the next time I print something the arrow prints and tells me to turn paper over. How do...
folow these steps : start / control panel / printers and faxes / right click on your printer / proprieties / now here some ware u got to uncek the duplex printing , after that clik aply an ok.
Feb 02, 2011 | Lexmark Office Equipment & Supplies
Which way do I insert the transparency into my front loading MP 560 Canon Printer.Shiny side up or down Thank you V
It depends on which side you want to print on. For transparencies, you want to print on one side only. Most likely, you want to print on the shiny side; essentially as if it were a glossy photo. Load the transparency so that the shiny side gets printed on. Don't know that part? Front loading printers are the easiest to determine which side is printed on. Look at where the paper goes in and where it comes out. Think about it; for single sided printing, the paper isn't being turned around inside; merely rolled around an internal roller, then back out. Watch what happens to the paper the next time you print on a single side. See if the top of the printed page came out first, or last.
The most common designs of front-loaders have the paper come out above where it went in. The paper curls around the bottom of the internal roller and comes right back out on top. Therefore, the printed side started out on the bottom, then curled around the internal roller and came out with the printed side up.
Most front loading printers have the top of the printed page come out first; therefore, the same edge that went in first, got printed on first. With that in mind, if you ever want to print on the unprinted side of a piece of paper (that is already out of the printer), obviously keep the printed side up, but since the top of the printed side came out first, you need to make sure the top goes in first to come out first for the back side.
Your Canon 560 printer has duplex printing, so it is a good idea to run your test to see what happens when printed on a single side, and what happens if you use the duplex-mode. For duplex mode printing, after printing on one side, the printer pulls the paper back in to print the other side automatically. Think about how much space is inside the printer. Depending on how much data the printer can store, either the first page is printed, then the second page, or the second page is printed first, then the first page. It depends on how the printer wants the page to come out. You can run a simple test and see exactly what happens.
Since the printer cannot easily turn the paper around, it merely starts with the opposite end of the first printed side when it prints on the back. If the top of the page came out first for the first printed side, the printer prints the bottom lines of the second page of text working back to the top in reverse order. As a result, the bottom of the page comes out first, with the top coming out last.
Some duplex printers can store so much data that the determine how the second page will look, print it first, then print the first page. Watch to see what yours does.
Worse comes to worse, mark a sheet of paper in one corner, insert it into the printer, then print a document that contains only the period character and see where it is printed. By knowing how you put the paper in, and where the period was printed, you can tell how to handle any situation. By the way, the period character was chosen because it will be so small that most likely you can use that sheet again.
Jan 07, 2011 | Computers & Internet
The green light on my HP Deskjet 3845 is flashing ..when I try to print it tells me there is a paper jam ..there is no paper jam. I have inspected the printer carefully, reloaded the paper. It will not...
i think u should check for peices of paper ,tiny objects etc that might be obstructing the movement of the paper. also check that the print head is not disconnected from the belt you can check this by slidind the print head from side to side and ensure that both of them are moving hope this helps.
Oct 19, 2010 | HP Deskjet 3845 InkJet Printer
My duplex printer prints the second page(inside) of a half- fold card upside down. The printer wizard from orintmaster and printshop is designed for single- pass printers si that doesn't work... In fact,...
actually the gears in the printer are got worn out or some thing is blocking the gears so its not able to turn the paper internally to print on the right part of paper.and its printing upside down.remove the cartridge from the printer.and apply air blower in the inner area of printer.remove all the dust collected in the printer by blowing air everywhere in the printer.then check out if still the same problem the paper sliding gears needs to be replaced.you can get the gear assembly for local printer repair shop.they also help if replacing the gear assembly.
This will help. Thanks please keep updated.please do rate the solution if helped.thank you for using fixya
Oct 02, 2009 | Brother HL 5250DN Laser Printer
Printer loads paper incorrectly when trying to print
in the tray where you put the paper, there are two pieces of plastic that site on the side ,,,,, bring them close to the paper as to touch the paper.
this way the paper cannot go left or right when loaded and now will go in straight.
this oughta do it.
Mar 26, 2009 | Dell 922 All-In-One InkJet Printer
Printing double sided with epson stylus 1400
The printer does not automatically print on both sides.  You will have to print one side then reload the paper.
Dec 15, 2008 | Epson Stylus C86 InkJet Printer
Double Sided Printing
Hai
This Printer doesn't support Duplex Printing(Double - Sided).
Thanks
Riz
May 30, 2008 | HP PSC 950 All-In-One InkJet Printer
Printer screen tells me that there is a paper jam - no paper left in printer
Check rear door, it comes off, and also look to left and right sides of carriage paper gets scrunched into sides by head.
Dec 25, 2007 | Brother MFC 240C All-In-One InkJet Printer
Small photo paper
have you set up the paper size in the printer options when you press print, as it should pop up in a window before the print whre you click ok, asking what quality and size paper, but if you don't tell it it will assume that you are using standard A4 or whatever your standard paper size is.
May 27, 2007 | HP Photosmart 7450 InkJet Printer
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
65 people viewed this question
old marine
old marine
