Question about Samsung ML 1710 Laser Printer
Wont printer test sheet
Samsung laser LM1750 will not print a test sheet flashes from green to red stating on line error can you help me sort out this problem
    Brigadier General:
  • 6,966 Answers
Hi, On a similar brand/different model, this type of problem was caused by the the USB cable from printer to PC. Since this particular model does not include a USB cable, perhaps what you are using is faulty. Try another cable known to be good (say from another or your old printer). If the cable checks out, try plugging into your PC's other USB ports. You may have likewise to verify that your USB ports. hubs and controllers are installed properly with no problems or errors in your Device manager. Some issues may be inherent to your operating system,l please check compatibility with your OS. Hope this be of some help/idea. Pls post back how things turn up or should you need further information. Good luck and kind regards. If this also fails, you may have to re-install the necessary LM1750 drivers.
Posted on Sep 20, 2007
  • Louie  Role
    Louie Role Sep 20, 2007
    Hi again,
    In some instances, the PC switches off a USB port. You may have to un-check "Allow the computer to turn off this device to save power." This is in your Device Manager/Universal Serial Bus Controllers/USB Root Hub.
    Cheers.
SOURCE:
Please help with the following: Printer BIXOLON SRP 350 IG When I turn it on Power light: Green Error light: Red Paper light: Red The printer "beep ... beep" continously
Looks like you'll have to contact Samsung http://www.samsungminiprinters.com
The operators manual does not give any indication about what to look for if the error light is on.
Here's what the manual states about the paper light:
This light indicates the near end of the paper roll. Install a new paper roll and the printer will continue printing. When the light blinks, it indicates the self-test printing standby state or macro execution Standby state when the macro execution command is used.
Jul 18, 2011 | POS X BIXOLON Samsung Kps SRP350 Thermal...
Red light blinking, first orange then red, toner blinks green
dear sir
  1. it is problem paper miss feed
  2. over temparature
clean thermostator.thermostator over dry toner
or cartridge assembling problem
Aug 04, 2009 | Samsung ML 2010 Laser Printer
Kyocera Ecosys FS 920
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
Samsung printer ml 1510 red light flashes after self test
Red Error Light Stays On The following conditions can cause the On Line LED to glow solid red:
  • Printer paper is jammed inside your printer.
  • A cover is not be closed properly.
  • The toner cartridge is not inserted properly and needs to be reinstalled.
  • The toner cartridge is running low.
  • There is no paper in the paper tray.
  • The paper inside the paper tray is not be installed correctly.
Red Error Light Blinks If your printer's On Line LED is blinking red, your printer's toner is exhausted and needs to be replaced. On Line and Error Light Blink Simultaneously
If your printer's On Line and Toner Save LEDs blink simultaneously, your printer requires service.
You can go to samsung online service request http://www.samsung.com/us/support/repaironline/supportOnlineServiceRequest.do
Mar 21, 2009 | Samsung ML 1510 Laser Printer
Samsung ML-1710 Printer: Online/Error (red) lite ON: won't print
It is not a computer problem, when your printer won't come to ready. The lights flashing are due to a failure of some sort - electronic, or perhaps a fuser warm up problem. The fact is, whatever the fault, it is cheaper to replace this printer than have it repaired.
Mar 16, 2009 | Samsung ML 1710 Laser Printer
On Line/Error Flashes then goes red
remove the cartridge and reisert it .and for your knowledge that when you insert the cartridge you will hear a click that means the cartridge is fitted properly.if you do not hear a click that means the cartridge is not installed properly.
Oct 29, 2008 | Samsung ML 1610 Laser Printer
Light keeps flashing red,amber, green
If you turn off the printer and turn it back on, do you get any noises, ie motor noises, or does it instantly go to all lights flashing?
If you get no noises this usually indicates a board fault and you should look for a new printer.
Apr 07, 2008 | Brother HL 5140 Laser Printer
Samsung ML2510 laser printer not working
unplug from the wall and try it again after an hour
Jan 10, 2008 | Samsung ML-2510 Laser Printer
Samsung ML 1710 Laser Printer Logo
123 people viewed this question
Top Samsung Office Equipment & Supplies Experts
jasbo
jasbo
Steve Allison
Steve Allison
Lawrence Singapore
Level 1 Expert
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
