First, ensure you are connecting the scanner to your computer. I'm assuming USB connection, and that you're using an operating system supported by this device.
Next, install the drivers and software for this device. Those should have come with an installation disc, but if you don't have that disc, you can get them from the PIXMA MP830 support site, here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=12804
To scan a single document, place the document:
1. Place the document face down on the platen glass.
2. Open the MP Navigator 2.2 software.
3. Click Scan Photo/Document.
4. Click
Document Type drop-down arrow and select the type of document to be scanned. Chose from the following types.
- Color Document(Simplex): Select this to scan one side of color documents.
- Color Document(Duplex): Select this to scan both sides of color documents.
- B/W Document(Simplex): Select this to scan one side of monochrome documents.
- B/W Document(Duplex): Select this to scan both sides of monochrome documents.
- Text(Simplex): Select this to scan one side of text documents.
- Text(Duplex): Select this to scan both sides of text documents.
5. Click 'Specify' and set the preferences as required.
Click here for detailed information6.
After making the setting changes, click 'Scan'
7. Click
'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an
image is captured with Scan Photo/Document or Batch ScanningThe directions for Batch Scanning, or using the ADF to scan, are shown below.
- Place the document(s) in the Automatic Document Feeder (ADF).
- To scan using the ADF, remove any documents from the platen glass.
- Open the document tray.
- Insert the documents face-up in the ADF and then adjust the document guides.
Note:
When scanning using the ADF, the documents will automatically feed.
- On the Windows desktop, double-click 'MP Navigator 2.2'.
- Alternatively, on the Windows taskbar, click 'Start', point to '(All) Programs', 'Canon', then 'MP Navigator 2.2'.
- Then click 'MP Navigator 2.2'. MP Navigator opens.
- Click 'Batch Scanning'.
- Click Document Type drop-down arrow and select the type of document to be scanned. Chose from the following types.
* Color Document(Simplex): Select this to scan one side of color documents.
* Color Document(Duplex): Select this to scan both sides of color documents.
* B/W Document(Simplex): Select this to scan one side of monochrome documents.
* B/W Document(Duplex): Select this to scan both sides of monochrome documents.
* Text(Simplex): Select this to scan one side of text documents.
* Text(Duplex): Select this to scan both sides of text documents.
- Click 'Specify' and set the preferences as required. Click here for detailed information.
- After making the setting changes, click 'Scan'.
- After the documents are scanned, a dialog box will appear indicating to load the next document.
- After the next document is loaded, click 'Scan'.
- Repeat steps 6a and 6b until all documents have been scanned and then click 'Exit' to end the scanning process.
- After all documents have been scanned, ensure the documents, in the preview area, are selected (have a check mark).
- Click
image is captured with Scan Photo/Document or Batch Scanning.
Save to PC dialog box
Save as PDF file dialog box
- Make settings to save a file. (Click File save settings for details.)
- Click 'Save' after all settings have been selected.
i've done to configure .. but still on the same problem
