Question about Nokia N95 Cellular Phone
N95 screen disfunctional
Screen intermittantly switches off and looses coulour and freezes ocasionaly and shifts to the right when navigating menu,s etc
Why is it sometimes i can drive my car and others it wont move?
You need to give us a better idea of your real problem. Does the engine crank over? Does the engine start? Is the vehicle failing to go into gear?
One part that can be intermittent is the Interlock switch on the Brake pedal lever. If this switch fails to light-up the Brake lights, you may not be able to crank the motor, or shift it.
If the engine starts and runs, but does not shift into gear, your foot needs to be on the Brake pedal. It needs a signal from the Brake switch Interlock to allow shifting of the gearshift.
The Brake pedal Interlock switch can be loose or cracked and it will give you the problems you are having.
Please comment on my info.
Mar 17, 2013 | 2003 Lincoln Navigator
Tip
CTRL+C (Copy) CTRL+X (Cut) CTRL+V (Paste) CTRL+Z (Undo) DELETE (Delete)...
CTRL+V (Paste)
CTRL+Z (Undo)
DELETE (Delete)
SHIFT+DELETE (Delete the selected item permanently without placing the item in the Recycle Bin)
CTRL while dragging an item (Copy the selected item)
CTRL+SHIFT while dragging an item (Create a shortcut to the selected item)
F2 key (Rename the selected item)
CTRL+RIGHT ARROW (Move the insertion point to the beginning of the next word)
CTRL+LEFT ARROW (Move the insertion point to the beginning of the previous word)
CTRL+DOWN ARROW (Move the insertion point to the beginning of the next paragraph)
CTRL+UP ARROW (Move the insertion point to the beginning of the previous paragraph)
CTRL+SHIFT with any of the arrow keys (Highlight a block of text)
SHIFT with any of the arrow keys (Select more than one item in a window or on the desktop, or select text in a document)
CTRL+A (Select all)
F3 key (Search for a file or a folder)
ALT+ENTER (View the properties for the selected item)
ALT+F4 (Close the active item, or quit the active program)
ALT+ENTER (Display the properties of the selected object)
ALT+SPACEBAR (Open the shortcut menu for the active window)
CTRL+F4 (Close the active document in programs that enable you to have multiple documents open simultaneously)
ALT+TAB (Switch between the open items)
ALT+ESC (Cycle through items in the order that they had been opened)
F6 key (Cycle through the screen elements in a window or on the desktop)
F4 key (Display the Address bar list in My Computer or Windows Explorer)
ESC (Cancel the current task)
SHIFT when you insert a CD-ROM into the CD-ROM drive (Prevent the CD-ROM from automatically playing)
Dialog Box Keyboard Shortcuts
CTRL+TAB (Move forward through the tabs)
CTRL+SHIFT+TAB (Move backward through the tabs)
SHIFT+F10 (Display the shortcut menu for the selected item)
ALT+SPACEBAR (Display the System menu for the active window)
CTRL+ESC (Display the Start menu)
ALT+Underlined letter in a menu name (Display the corresponding menu)
Underlined letter in a command name on an open menu (Perform the corresponding command)
F10 key (Activate the menu bar in the active program)
RIGHT ARROW (Open the next menu to the right, or open a submenu)
LEFT ARROW (Open the next menu to the left, or close a submenu)
F5 key (Update the active window)
BACKSPACE (View the folder one level up in My Computer or Windows Explorer)
TAB (Move forward through the options)
SHIFT+TAB (Move backward through the options)
ALT+Underlined letter (Perform the corresponding command or select the corresponding option)
ENTER (Perform the command for the active option or button)
SPACEBAR (Select or clear the check box if the active option is a check box)
Arrow keys (Select a button if the active option is a group of option buttons)
F1 key (Display Help)
F4 key (Display the items in the active list)
BACKSPACE (Open a folder one level up if a folder is selected in the Save As or Open dialog box)
Windows Logo (Display or hide the Start menu)
Windows Logo+BREAK (Display the System Properties dialog box)
Windows Logo+D (Display the desktop)
Windows Logo+M (Minimize all of the windows)
Windows Logo+SHIFT+M (Restore the minimized windows)
Windows Logo+E (Open My Computer)
Windows Logo+F (Search for a file or a folder)
CTRL+Windows Logo+F (Search for computers)
Windows Logo+F1 (Display Windows Help)
Windows Logo+ L (Lock the keyboard)
Windows Logo+R (Open the Run dialog box)
Windows Logo+U (Open Utility Manager)
Accessibility Keyboard Shortcuts
Right SHIFT for eight seconds (Switch FilterKeys either on or off)
Left ALT+left SHIFT+PRINT SCREEN (Switch High Contrast either on or off)
Left ALT+left SHIFT+NUM LOCK (Switch the MouseKeys either on or off)
SHIFT five times (Switch the StickyKeys either on or off)
NUM LOCK for five seconds (Switch the ToggleKeys either on or off)
Windows Logo +U (Open Utility Manager)
Windows Explorer Keyboard Shortcuts
END (Display the bottom of the active window)
HOME (Display the top of the active window)
NUM LOCK+Asterisk sign (*) (Display all of the subfolders that are under the selected folder)
NUM LOCK+Plus sign (+) (Display the contents of the selected folder)
NUM LOCK+Minus sign (-) (Collapse the selected folder)
LEFT ARROW (Collapse the current selection if it is expanded, or select the parent folder)
RIGHT ARROW (Display the current selection if it is collapsed, or select the first subfolder)
PAGE UP (Move up one screen at a time)
PAGE DOWN (Move down one screen at a time)
HOME (Move to the beginning of the line)
END (Move to the end of the line)
CTRL+HOME (Move to the first character)
CTRL+END (Move to the last character)
SPACEBAR (Switch between Enlarged and Normal mode when a character is selected)
Microsoft Management Console (MMC) Main Window Keyboard Shortcuts
CTRL+O (Open a saved console)
CTRL+F4 (Close the active console window. When a console has only one console window, this shortcut closes the console)
Remote Desktop Connection Navigation
CTRL+ALT+END (Open the Microsoft Windows NT Security dialog box)
ALT+PAGE UP (Switch between programs from left to right)
ALT+PAGE DOWN (Switch between programs from right to left)
ALT+INSERT (Cycle through the programs in most recently used order)
ALT+HOME (Display the Start menu)
F5 key (Update the content of all console windows)
ALT+SPACEBAR (Display the MMC window menu)
ALT+F4 (Close the console)
ALT+V (Display the View menu)
ALT+F (Display the File menu)
ALT+O (Display the Favorites menu)
MMC Console Window Keyboard Shortcuts
CTRL+P (Print the current page or active pane)
ALT+Minus sign (-) (Display the window menu for the active console window)
SHIFT+F10 (Display the Action shortcut menu for the selected item)
F1 key (Open the Help topic, if any, for the selected item)
CTRL+F10 (Maximize the active console window)
CTRL+F5 (Restore the active console window)
ALT+ENTER (Display the Properties dialog box, if any, for the selected item)
CTRL+ALT+BREAK (Switch the client computer between a window and a full screen)
ALT+DELETE (Display the Windows menu)
CTRL+ALT+Minus sign (-) (Place a snapshot of the active window in the client on the Terminal server clipboard and provide the same functionality as pressing PRINT SCREEN on a local computer.)
CTRL+ALT+Plus sign (+) (Place a snapshot of the entire client window area on the Terminal server clipboard and provide the same functionality as pressing ALT+PRINT SCREEN on a local computer.)
Microsoft Internet Explorer Navigation
CTRL+I (Open the Favorites bar)
CTRL+L (Open the Open dialog box)
CTRL+N (Start another instance of the browser with the same Web address)
CTRL+O (Open the Open dialog box, the same as CTRL+L)
CTRL+P (Open the Print dialog box)
CTRL+R (Update the current Web page)
CTRL+B (Open the Organize Favorites dialog box)
CTRL+E (Open the Search bar)
CTRL+H (Open the History bar)
on Jul 25, 2010 | Computers & Internet
Tip
Windows General Keyboard shortcuts
CTRL+V (Paste)
CTRL+Z (Undo)
DELETE (Delete)
CTRL+A (Select all)
N95 key pad working when phone is switched on but the screen in blank. the very odd time the screen does switch on. would it be a loose connection between phone and screen? and how would i fix? thanks john
Yes this is definitely loose connection. You may need to change the flex cable. Dismantle your phone (You can search for instructions on Google). you might only need to remove your slide.
Mar 03, 2010 | Nokia N95 Cellular Phone
My nokia n95 screen goes on but freezes all the time and i always get a black screen. the fone is still on but the screen is just black it only comes on when i put the fone into music mode ( when i slide...
your cellphone is fine. Its the strip which needs to be replaced.
actually the strip connects the LCD and the navigation keys.
U might have noticed sometimes your navigation keys also don't work.
get your strip replaced n your cellphone will be fine again.
slide up the phone and you will see 2 screws at the top.
get these screws removed and replace the strip and also do change these screws after the repairing.
Feb 09, 2010 | Nokia N95 Cellular Phone
Nokia N95 8G - freezes when you turn it on and you can't go past the NOKIA welcome screen. Tried taking the battery out, charging it, etc.
Just format your phone by the following way
To Format the phone
1)Switch off the phone
2)Hold 3,* and Green button simultaneously
3)Now press the power button holding the 3 button, After 5 seconds leave the 3 buttons
4)You phnoe should say, formatting and all your data would be reset to factory orginal
CAUTION: You will loose all the data and contacts stored in phone memory, But this is the only way
PLEASE RATE THIS SOLUTION
RNJ VINODKUMAR
Sep 29, 2009 | Nokia N95 Cellular Phone
Zoom position keeps shifting
in low light situation focus shift. In some recent camcorder you can ''manually ajust the focus'' by entering in the menu and navigating. You could also light up the place like everybody does in the video and film industry. I mean light up, buy a two head 2x500Watts construction light on tripod. Put one on your subject and one on the ceiling to reflect the light and kills the shadow and produces sharp line on hairs ... Basic video lighting ... Look for the right keyword in google and open to a whole new world of quality ....
Aug 05, 2009 | JVC Video Cameras
Navigation screen switches to menu screen w/out touching it
go to MENU --> SETTINGS --> DISPLAY --> there u can switch off the navigation key icons.
May 25, 2008 | Tomtom GO 720 GPS Receiver
Nokia n95
well it sounds like you have two major problems first you need to get the lcd change and the phone's need to have the firmware reflash........take the phone to a recognise mobile service center and have them replace it for you and fix the freezing issue.
Mar 11, 2008 | Nokia N95 Cellular Phone
Navigation screen freezes GPS unit
I believe they fixed this problem with a firmware upgrade. Use Garmin's web updater to perform the updates.
Jul 07, 2007 | Garmin eTrex Legend Cx GPS Receiver
Nokia N95 Cellular Phone Logo
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
