Question about RCA TruFlat 27F520T 27" TV
Tilted picture Just after moving my samsung txg204645 to another area in my room, I immediately noticed that the picture had slanted and the picture was green on both top corners. I removed both speakers from both sides of the t.v.. Fortunately, the green diminished but the slant remained. Thinking that it might be an internal problem I tried a different television in the exact area and it, too, was slanted. Therefore, it must be an external problem. I don't know what to make of it. I looked in the t.v. manual for picture rotation, but found nothing. Thank you for your time.
    Problem Solver:
  • 5 Answers
You must be placing the TV near something Magnetic, Speakers, etc. This would account for the green in the corners. The tilted picture is most likely the yoke in the set has moved during rough handling. The first issue can be fixed with a degausssing coil, the second requires a technician to manually realign the yoke assebly and perform a convergence on the set.
Posted on Apr 20, 2009
Picture is slanted left to right.
Check and replace the main digital processor board. Synchronization problem, along with phase.
Aug 19, 2012 | Samsung HL-T5676S Television
LEAKING ON THE INSIDE OF THE HOUSE
There is an outlet to allow condensed water to flow outside the house from the AC unit runs. Please check whether there is any dust block in the tube and once you clean it water will flow out and not into the house. Sometime the garden lizard or flycatcher could get into the drain pipe and got stuck and block the outflow of condensed water.
Please ensure that the window air conditioner is installed in such a manner the out side portion of the unit is slanted or tilted to the back so that the water will run out and not into the room. By providing some pad to the front portion of the unit the above could be achieved and condensed water will not flow into the room.
Jul 08, 2009 | GE AJCQ08ACB Air Conditioner
Slanted Picture
It sounds like the dm bd. is loose. This is the module with the DLP IC on it. With the back off of the unit their is a module directly in the middle of the chasis that has a metal shield around it. Try to move it gently to see if it is loose. If it is loose that is what the picture is tilted. This is very difficult to align, but if you have someone watch the picture as you gently move this module you can get it strait. Then locate the screws that keep it tight and snug them
Mar 21, 2008 | RCA HD50LPW175 50" HDTV
Slanting Picture
The yoke has probably come loose and tilted.. From the rear of the set looking on the back of the crt you'll find a copper wire wound magnet called the yoke. It terminates on the neck of the yoke with a clamp. With the set off slightly loosen the clamp and turn the yoke assembly in the opposite direction - key word here is slightly - and apply power to check the alignment.
Keep doing this until you achieve the alignment you want. And always remember to unplug the set between attempts.
Nov 05, 2007 | Sharp 32SC26B 32" TV
Slanted picture
THENION-IF YOU CAN GET FRONT SPEAKER GRILL OFF AND REMOVE THE 4 SCREWS TO GAIN ACCESS TO FRONT ENGINE YOU SHOULD BE ABE TO USE A SCREWDRIVER TO SHIFT ENGINE APPROPRIATELY.JOE TV
Jan 08, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Picture slants right to left
Hope you have fixed this problem by now, if that tv is unserviced, I mean if nobody has ever opened it, it could be a problem with the positioning of your tv, just tilt the tv in different positions and find out the position in which it will show the right fit. If it is serviced, especially yoke is changed, this is rare, it could be because the position of yoke is not aligned properly.
Dec 16, 2006 | Philips 27PT5445 27" TV
Slanted picture
Your deflection yoke (a coil around the neck of the picture tube) must have gotten turned. Your can turn the picture upside down by rotating this coil. If your set is in warranty, you should return it. When this "yoke" is adjusted the color is affected too. If you try this yourself you'd void the warranty and mess up your color. Stargazer
Nov 05, 2006 | Philips Magnavox 20MT133S 20" TV
Picture is very dark and has a blue haze to the darker areas
Theres no adjustment except the tvs On screen disply is what you should ONLY fool with. Anytime you have the option you do and your not happy with it . GO for it!!! get a full refund and start over with another one or go to another store. Good Luck
Jun 21, 2006 | Mitsubishi WD-52327 52" Rear Projection...
RCA TruFlat  27F520T 27" TV Logo
172 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
