**** RTC battery is low or CMOS checksum is inconsistent **** Press [F1] to set Date/Time
I have a Toshiba PS241A **** RTC battery is low or CMOS checksum is inconsistent **** Press [F1] to set Date/Time. I Press F1 with no respose I have change the BIOS battery and changed it other two days. but I still have the same problem!
  • 61 Answers
Hello
Please reset cmos to factory defaults.
Then enter the bios setup and configure it and save changes.
Posted on Apr 20, 2009
Rtc battery is low or cmos checksum is inconsistent
The RTC battery is a rechargeable Li-ion "clock" battery that's buried underneath the keyboard - it keeps date and time going when your computer is turned off. If you're getting this message, you should go follow the screen prompt, hit F1 to enter Setup, and set the date and time, leave the computer on for several hours to charge it (the clock battery recharges only with the computer turned on) and it should go away.
In the rare event that your RTC battery is bad, it's really up to you as to getting it replaced or not - it's a lotta work, and not all the battery vendors out there is competent enough to sell you the right kind of battery (installing a non-rechargeable Lithium battery will kill the thing outright, and there are actually people selling these....). Not having a working RTC battery doesn't really interfere with the workings of the computer - you'll just have to set date and time every time you start it, and you can do so manually or by downloading some freeware such as Atomic Clock Sync to automatically do it for you.
Sep 19, 2011 | Toshiba Satellite A45-S151 Notebook
When i turned on my computer message RTC battery is low or CMOS checksun is inconsistent press f11 key to set date i have tryed f11 and had it pluged in all night still same message.
Means your CMOS battery is flat and will need to be changed, as that keeps the date and time saved at all times if it dead then every time you turn off the computer the date and time will not be saved and have to re-set it. changing the battery will solve this problem. Kronoguy
Jun 29, 2011 | Toshiba Computers & Internet
I have a toshiba g25 av513 when it the power button is pressed a message shows up on the screen stating RTC battery is low or CMOS checksum is inconsistent. the laptop is plugged in
Hi. This is likely due to a small watch battery inside the machine (called the CMOS battery) being dead. Replacing it usually requires the tools and skill of a qualified technician.
Mar 13, 2011 | Computers & Internet
Hi
The battery could need replacing. Best leave this to a reputable repair person or check my website at www.micromendllc.com
Jun 03, 2010 | Toshiba A45-S121 Notebook
On start up my computer says rtc battery is low or cmos checksum is inconsistent. Press (f1) key to set date/time. I press f1 but nothing happens. blank screen. I can press ctrl alt del and it will restart...
Your RTC battery or CMOS battery is either dead or too low to keep the correct settings, windows will not operate correctly without the proper date and time kept. This battery has to be replaced for your system to operate. Below is the service manual that will advise you of the proper procedure to replace the battery. Once the battery is replaced, reboot the laptop, go to the BIOS screen and reset the date and time, then reboot as normal. In the case of your particular laptop, the laptop has to be disassembled down to the lower case and motherboard. The included service manual has the procedure for this.
http://tim.id.au/laptops/toshiba/satellite%201400%201405.pdf
Nov 11, 2009 | Toshiba Satellite 1410-S173 Notebook
I get the message "Bad check sum (CMOS)" Model toshiba tecra 730XCDT
hi friend,
Probably a dead Motherboard battery. Need to enter the BIOS screens and reset values. Especially the time and date. Maybe the boot order and if using USB KBoard enable legusy USB devices. This will occur each time your friend shuts down and reboots until the battery is changed.
Issue
When you turn your Toshiba computer on, you see an error message like: **** Bad RTC battery ****
**** Bad Checksum (CMOS) ****
Check system, then press [F1] key The Real Time Clock (RTC) battery provides power for the internal clock/calendar and for maintaining system configuration settings.
This error can occur when a machine has been left turned-off for an extended period of time (around a month), and is the result of a depleted RTC battery. Other symptoms include not being able to execute Windows Update properly, errors/problems executing application software (like Norton Antivirus), and the appearance of the Windows XP "Desktop Clean Wizard".
Resolution This condition is easy to fix in 3 basic steps: Reset the BIOS defaults
Set the correct date and time in Windows.
Charge the RTC battery Please follow the detailed instructions in the next section.
Procedure Set BIOS defaults Press the [F1] key as instructed in the error message:
Check system, then press [F1] key In the BIOS setup screen press the [Home] key to restore the default values, then press the [End] key to save and exit, then the [Y] key to confirm and restart the system. Set the correct date and time in Windows As Windows starts-up, you may see an error message about an "Invalid System Time". Go ahead and click "OK" to clear the error dialog. Open the Windows Control Panel and open the "Date and Time" control by double-clicking its icon. Set the correct date and time, then click OK to save. Charge the Real Time Clock (RTC) battery To charge the RTC battery, connect the AC adapter and turn the computer on (both the DC IN and Power LEDs must be green). Leave the machine on for approximately 24 hours to ensure a full charge in the RTC battery. Please note that the RTC battery does not charge while the PC is turned off, regardless of whether the AC adapter is connected or not. Other Information: If, on subsequent reboots, the "Bad RTC Battery" error persists, it's quite likely that you actually do have a bad RTC battery. If that's the case, you should contact a Toshiba Authorized Service Provider to have the system serviced. Windows XP Desktop Cleanup Wizard The first time you reboot Windows XP after resetting the system clock, Windows XP may try to run the "Desktop Cleanup Wizard". Simply Cancel the "Desktop Cleanup Wizard" at the first dialog. If you do manage to clean your shortcuts from the desktop and want to recover them, you will find them in a folder called "Unused Desktop Shortcuts". You can recover them as follows: Double-click to open the "Unused Desktop Shortcuts" folder
Drag the selected items back to your desktop
Close the "Unused Desktop Shortcuts" folder. You can delete this folder if it is empty.
thank u for using fixya
regards,
sivaranjini
Aug 10, 2009 | Toshiba Tecra 730CDT Notebook
Turn on computer and message reads ****bad check sum (CMOS) ****
That means that after computer had been off for a long time the CMOS battery has drained, and CMOS (BIOS) settings had been reset to default.
Usually the computer will work fine after pressing F1, but you may get wrong date and time.
Try charging battery completely, often the problem disappears, if it does not , then the choice is between pressing F1 each time you start the laptop, or disassembling the laptop and replacing CMOS internal coin battery, located on the lower side of the motherboard.
May 17, 2009 | Toshiba Satellite 1805-S204 Notebook
Toshiba Portege R100 CMOS/BIOS PROBLEM at startup.
I'd look at trying to replace the BIOS battery...
Check out this guide for dis assembly instructions :
http://www.irisvista.com/tech/laptops/Toshiba_Portege_R100/remove_system_board_1.htm
Feb 22, 2009 | Toshiba Portege R100 Tablet PC
Toshiba satellite 1410
This is the REAL TIME CLOCK power supply inside your laptop.It maintains the system configuration and clock/calendar. Do not try to replace this yourself unless you are experienced,you could lose everything on the system and worse still these batteries can explode!! Connect the AC adaptor and let it charge for at least 24hrs. Press F2 to enter the bios. Set correct time and date If it Persists take it to a dealer to be replaced
Aug 24, 2008 | Toshiba Satellite 15" Flat Panel LCD...
Message before boot
plz try by changing the cmos battey
Jul 29, 2008 | Toshiba Portege M200 Tablet PC
Computers & Internet Logo
2,493 people viewed this question
David Payne
David Payne
