Question about HTC Touch P3450 Smartphone
My HTC Touch mobile got lightly wet and i didn't noticed it immediately.i tried to use it,it got switched off and not turning on again.Even,i didn't remove the battery for couple of hours.what can i d
My HTC Touch mobile got lightly wet and i didn't noticed it immediately.i tried use it,it got switched off and not turning on again.Even,i didn't remove the battery for couple of hours.what can i do now?
  • sailesh18 May 09, 2009
    my htc touch fall in water for a sec them immedieatky i remove my battery then kept it in sunlight afetr sometime i open my htc touch remove screen and dry then put on battery then on my mobile started working fine sound is proper but in screen i can see water whole scree plz solve my problem
    Scholar:
  • 34 Answers
I have fixed a few electronics devices (IPOD< ghettoblaster, radio) that have gotten wet. All using the same approach. Hopefully this will help you:
1) First things first - get the battery out.
2) Dry off what you can.
3) If you are tech saavy, open the unit up and use a hair dryer or put it under a lamp for a few hrs to dry it off. If you can, take as much apart as possibe as the water likely got into all spaces.
4) The most important part is that you will have to make sure that all contact surfaces are clean and do not have oxidation on them. This was the single-most important thing I looked for and fixed. Especially contact points where the battery terminals contact the main unit. If the metal looks tarnished, get a cloth and buff the terminals. If that does not work, use rubbing alcohol on them. If water has gotten under the keypad, you will have to do the same there. Once clean, leave it apart to ensure it all gets dry.
5) When you are confident that all the water has been removed, put it back together, put the battery in and try it. Dont forget to make sure the battery has a charge as well.
Good luck.
Posted on Apr 20, 2009
My nokia n900 got wet when it was on and i didn't took out the battery for some while after that i cleaned all teh outer parts with tissue paper then again i tried to turn it on but it just didn&#
Hi once if a phone gets wet, it is very much risk if we don't put off the battery immediately .Because,as and electronics device it is run by current,when it gets wet the different components(parts) with different current (+ve and -ve) are sort.So, when we put battery/charger the internal components easily fused....So, the first aid is to put off the battery and contact mobile repairing shop.It could not be tried easily.....Therefore, I advise you to do not put the battery again,unless you visit mobile repairing shop.If you are trying to power it on by yourself repeatedly without any knowledge,most of the components may damage more worse.Good luck.Thanks for visiting fixya
Jul 02, 2012 | Nokia N900 Smartphone
I switch my touch screen since it cracked but when i put everything back and turn the phone on, the screen wouldnt light up or anything but the phone still work
The one who replaced didn't fix it well, try to return to him or check another dealer. Maybe it's bad copy of touch screen, or he didn't connect the LEDs
May 16, 2012 | HTC Aria Cell Phone
I have dropped my mobile HTC touch P3450 , it got switched off. After while I have put it to charge , the red indicator was on for a while. But it went off after that and i could not switch on my...
Before asking them to touch your phone inside better do this first. Remove the battery and then insert it again. Maybe pins in the battery got jammed when you dropped it. If this doesn't work, while in charge leave it for a minute or so, if the red light is on, feel the back of your phone and feel it again if the red light goes off. If it heats up then it means a circuit is shorted causing your battery to heat up. As of asking service engineers, better ask the one you personally knew or have a second opinion before proceeding to have them repair it.
Apr 05, 2011 | HTC Touch P3450 Smartphone
Screen suddenly turn white and done all that i could like hard reset but when i switch it on again, it was normal only for a few seconds before turning to white screen again...
If you you are experiencing white screen and nothing changes even after doing a hard reset you may want to call or contact HTC support. Be sure that it is still cover by their one year warranty. Coz having a white screen might caused of a lot of things like infected by virus, water incident, mobile phones has a physical damage. Check as well the lcd of the phone. try to get in touch with them with the link below.
http://www.htc.com/sea/CA_Hotline.aspx?region=NorthAmerica
Mar 16, 2011 | HTC Touch P3450 Smartphone
Not pairing with HTC touch and bluetooth headset
I got jabra bluetooth which is not getting connected with my HTC touch mobile.It is not getting detected.
Oct 07, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
My HTC P3450 mobile was not responding to few calls while the callers could here my mobile ringing.I couldn't see any kind of response from my mobile to receive such calls.Even, i couldn't know that they...
Completely swith off, then switch on. Wait HTC takes a bit more time to respond. Put on vibration mode or put in full ring and alarm mode. This should work.
Apr 21, 2009 | HTC Touch P3450 Smartphone
JVC KD-AVX33 pairing problem
To inicialize to factory settings do: In "Setup" menu go to "others" menu, go to "Initialize" press "Enter".
With this you will loss all your customized settings
Sep 25, 2008 | JVC KD-AVX33 Car Video Player
Phone doesn't ring for an incoming call
try installing this Hotfix
http://www.htc.com/us/SupportDownload.aspx?p_id=88&cat=0&dl_id=101
Hot fix for resolving ring tone and system sound loss problem in HTC Touch Date: 2008-08-28     CategoryHotfix
In some cases, there may not be any ring tone and system sounds on the HTC Touch when the device has not been soft reset after a few weeks of usage. Performing a soft reset will resolve this problem. You can also download this hot fix and install it on your device to prevent this problem from reoccurring.
May 26, 2008 | HTC Touch P3450 Smartphone
HTC Touch P3450 Smartphone Logo
725 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
