Question about Mitsubishi MSH09TW Air Conditioner
Neighbours tv interference
Hi, just has a heatpump fitted 7 kw one. but it is causing interference on my neighbours tv. i know this can happen in a low tv signal area and ours is. i asked the company who fitted it and they said that it was not the pump. the arial of my neighbour is about 12 meters away from the pump. is there any thing i can do or will she need to move her arial. also if it gats nasty where do we stand in the law. cheers Paul.
  • 1,420 Answers
The evaporator unit has a remote board in it that communicates to the remote every second. The interference your neighbor is coming from that and probably not the pump. A new remote board may just cause the same interference so I doubt the dealer will replace it. You can always ask. Try contacting Mitsubishi at www.mrslim.com. they have a contact page on their website that is very handy. They also have a technical manual under Library for your unit. Good Luck.
Posted on Sep 20, 2007
  • Chandler Ede
    Chandler Ede Sep 27, 2007
    Bode, what did you discover?
SOURCE:
Tv has a pink/magenta shimmering when the tv screen has a light coloured backgroung
Shimmering can be caused by a number of things.
The first that springs to mind is electromagnetic interference. Speakers, amplifiers, florescent lights in close proximity can cause this. I even saw a TV that had been fixed to a wall adjoining the next door neighbours who had put his TV in exactly the same position and the interference passed through the wall.
Try moving the TV location away from all sources of interference (including Cable boxes, Video recorders, etc.) Does the problem change or go away?
Is the TV grounded properly? Interference needs to be siphoned off to a ground. if you put your hand around the cable that feeds the TV a video signal does the problem change or reduce?
Another issue may be some form of video post-processing going on causing the shimmering. Some forms of image smoothing software built into the TV can cause this. So try shutting down any features on the TV, does the problem go away?
On a big TV that is fed a low resolution video stream you will always see what the industry calls "artefacts". These are distortions caused by the transport compression of the video signal. there is no way around these except for receiving a better resolution picture stream.
Mar 13, 2015 | Panasonic TCP42C1 Plasma TV
STATIC BACKGROUND NOISE
The time is the clue static in the background is electrical interference this can be caused by faulty electrical appliances UHF ham and CB Radios etc ask neighbours if and when they suffer this interference this will help to locate and identify the cause ie the closer you get the worse it'll be
Once you identify the source the culprit may decide to fix the appliance desist from operation or you can buy filters to eliminate the cause of static noise once you know the cause
Feb 02, 2018 | Apex Digital PF3230 32" TV
I don't know how to wire 15 kw heatstrips in a goodman package heatpump . I've got two height voltage wires ran to it now
There will be a plug that will connect with another plug inside the heating compartment, and then your high voltage wires connect to the breakers.
Dec 08, 2013 | Heating & Cooling
Download KW-878RF(BG+DK) for windows7
Hi ayham33
Your product is not designed to run under Windows 7 : http://www.kworldcomputer.com/kworldcomputer/www.nsf/h/pci878
Try installing a virtual version of XP on your system :
http://download.cnet.com/VMware-Player/3000-2094_4-10470784.html
Best regards ,
fanaudi .
Sep 11, 2011 | KWorld KW-TV878RF PRO (kwtv878rfpro) TV...
HI, My neighbours are complaining about the interference my drill is causing to their tv, radio etc. What is causing the problem and how do I combat it?
check the power cable of the drill is it a 2 prong or 3 prong plug? if it's a 2 prong it is an insulated power tool it is prone to emitt EMI (Electro Magnetic Interferance) becaus the casing is usually plastic, what could be done is check the carbon brushes inside the drill they could be worn and produce a lot of blue sparks, replace the brushes, if it's a 3 prong check for a faulty ground, with a faulty ground the metal casing of the drill is not shealding the EMI and could be deadly for the user in the event of a faulty live wire touching the casing
If all is well for the drill, contact a qualified electrician and ask for a EMI filter you could ave installed in the electric panel
Dec 31, 2010 | Drills
We have analog tv and freeview box but arial is in loft. signal strength is 70 percent and is good most of time.have found bad breakup when running 3kw shower and 3kw kettle, no other apliances interfere,...
The problem with inside aerilas is the signal strength of 70% contains noise as well. You could try using a higher gain aerial and the interference will be limited with a better signal.
Any electrical items can interfere with a poor signal.
Dec 30, 2010 | Televison & Video
Every night at 10 to 11pm, the wireless goes out in my 2wire modem/router. Neighbors have same issue...what's up?
You are getting some kind of elecrical/wireless interference. This is difficult to trace. If you have the TV on during 10 to 11pm, have you noticed any electrical interference on the TV screen?
It could be as simple as someone using an arc welder in your area.
Or a neighbour heating up something in their microwave oven (this oven can be faulty and is leaking microwave energy).
If you can identify the source of interference then you may find a solution.
There are a few things you can try.
Get a surge protection power board and connect your computer equipment and wireless router to this power board.
You can configure the wireless router to a different channel, one that is not used by your neighbours so that the wireless signal won't interfer with each other.
Have a look at the signal strength to your computer, if it is weak then move the router away from walls and/or raise it higher to improve the signal strength.
I hope this info helps you fix your problems.
Sep 25, 2009 | 2wire (1000-100052-000) 802.11g/b Wireless...
Green line down left side and geen snow
Horizontal or vertical bars on the screen could be from an ac line interference, adjacent magnetic field, bad input wire connections.....especially HDMI connector cables. A bad HDMI cable causes all kinds of unwanted picture interference. Check the conditon of all connection wires for proper fit and function. Keep in mind the method in which you connect your tv will result how the tv performs. As well this line problem could be a circuit issue too, requiring a technician to look at it.
Jul 23, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Mitsubishi MSH09TW Air Conditioner Logo
195 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
