Question about Ricoh AC205 All-In-One Laser Printer
Open heat error
All the time display "open heat error'
  • 628 Answers
You have a fuser error. Unplug the machine and try again. If you still get the error, then you'll need to replace it.
Posted on Apr 20, 2009
Oven won't heat flashes F2EO and 5D on
List below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
F0-E0 Analog to Digital failure
Disconnect panel for 30 seconds
Should the above error re-appears, replacement of the control is required.
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad. Replace Keypad.
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Below applies only to the two digit display models for the brands above.
F0 Defective ERC Replace ERC
F1 Defective ERC Replace ERC
F2 Oven over heat Replace defective Sensor
F3 Oven Sensor Open Check/Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground.
F7 Shorted or sticking button Clean button or replace ERC
F8 Defective ERC Replace ERC
F9 Door Latch Error Check latch and latch circuit
Mar 20, 2016 | Ovens
I have a Rheem rtg 74dvp but its not heating and the display show me 1 76 and 2 76, and come all the time to 76 F and another times its blinking the temperature, but not heat
Error code 76 is communication problem between remote control and tankless unit.
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
Multiple error codes could indicate that main PC board is bad.
Before calling service technician, open following link for troubleshooting resources including link to Rheem chat, manuals, error codes, etc.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Jul 15, 2011 | Rheem Tankless Water Heater RTG-74DVP...
GE SPACEMAKER XL1800 IS NOT HEATING FOOD - GIVING "SENSOR ERROR" ON DISPLAY. I am a handy guy capapble of fixing if you can help me out w/the part I need
hello,
if you have a sensor, it means, the door was opened before steam could be detected. Do not open the door until stream is sensed and time is shown counting down on the display.
Steam was not detected in the maximum amount of time. Use Time Cook to heat for more time.The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
thanks.
Jun 16, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F7 Shorted Touch Panel Replace Glass Panel
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F2-E0 Shorted Keypad Replace Keypad
Ovens with 2 Digit Displays
Dec 18, 2009 | Ovens
I have a GE microwave with the message sensor error
On GE models, "SENSOR ERROR" appears on the display when:
  • Using the sensor feature, the door was opened before steam could be detected. Do not open the door until stream is sensed and time is shown counting down on the display.
  • Steam was not detected in the macimum amount of time. Use Time Cook to heat for more time.
Thanks.
Jun 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave oven is displaying sensor error
  • Steam was not detected in the maximum amount of time. Use Time Cook to heat for more time.
Nov 19, 2008 | GE JE620 Microwave Oven
Sensor Error, Funny Smell and Noise
If none of these conditions apply to your situation, then you may have a defective sensor and/or magnetron.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Sep 02, 2008 | Microwave Ovens
GE microwave model jes1456 has sensor error
Aug 23, 2008 | GE Microwave Ovens
Ricoh AC205 All-In-One Laser Printer Logo
229 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
