SOURCE: Harman Kardon AVR 40 no sound
Check the fuses - there may be one inside the box as well. May also be a bad transformer. You can get a multi-meter at Home Depot and lookup how to check the power at the transformer.
SOURCE: My new Harman/Kardon AVR 154
Do you have your receiver output connected to the input on your TV? For example, if the receiver is in connection number 1, is your TV set to connection 1?
SOURCE: can I conect harman Kardon avr 230 to apple tv
Yes, although it (AVR) does not support HDMI only component video.
Connect the audio to the receiver and the video directly to the TV if you have inadequate video inputs, or want to take advantage of the HDMI.
Testimonial: "cheers, have a good year."
SOURCE: hi dear. how can connect my dvd to hamman kardon
connect tv video in to kardon video out (tv audio in to kardon audio out) dvd audio and video out to kardio audio video in. and if you what to record also signal from tv. make a cable from tv audio / video out to kardon audio / video in.
SOURCE: I have a harman kardon avr 745....looks frozen
Did you happen to come up with a solution. I have the same problem, 100% as you have described it.
