Question about JVC BR-S822DXU VHS/S-VHS playback VCR
HELP! JVC-BRS822U ejectomatic
Hi, Bought a used BR822U for $37 and it powers up, display lights, accepts tape but after a moment ejects it with "32" displayed. Hopefully not a terminal error, but I may have gotten what I paid for. The reason I purchased it is to give me a good analog signal (hopefully better quality than a nicely working Panasonic 1000B I got for $5) for capture through a Canopus 300 . Any suggestions? I don't have the manual and a peek under the lid gave me a bit of a scare. Any help appreciated. Paul
  • precognito Sep 24, 2007
    A local repair shop says it is the drive belt, some adjustments and lubrication. Says it is worth fixing. For $100 to $150, I suppose it is.
    Paul
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 4 Answers
I have a similar problem on a SONY SLV-700HF. It may be a drive belt problem with the take-up spool not gathering the tape. I'll be interested in any other suggestions before I pay out the $30 or so for a set of new belts.
Posted on Sep 24, 2007
  • Noexpert Sep 28, 2007
    Follow Up
    Replacing the drive belt worked for my SONY. Sony part # 3-946-999-01 available from Sony Direct Accessories & Parts Center web site -http://www.sony.com/accessories. Price 10.31 plus tax and shipping.
    With hindsight, probably would have been a good idea to change the other belts too, Part #s 3-946-923-01 and 3-946-962-01
    Noexpert
  • Barry8Track Nov 04, 2010
    I have 5 of these machines (and have repaired them all), and almost all of them need new loading belts, plus pull the mechanism for cleaning and lubrication. It's a fairly major operation, but I have it down to about an hour because I've done it so many times. In many cases, you can simply turn the pulleys by hand while the machine is trying to cycle, and plow past the gummed-up lubricant which will then restore operation after several manual "persuasions". Then, using it often will keep things healthy. This isn;t the right way to do it, but it should work.
6ya staff
SOURCE:
Tape won't eject on my jvc gr-d60. help please.
Remove battery
Press and HOLD Eject as you place battery back on (so its the first command it recognizes with power) and try to eject. If it does not come out, camera will need service to remove tape or fix gears
Nov 16, 2014 | JVC GR Video Cameras
Hi, I have a JVC HR-J658 VCR that doesn't eject tapes.
You mean a tape is stuck inside? Disconnect power and open up the cover. If the tape is stuck around the posts, free it and by manually turning the loading motor you can slowly get the mechanism to eject the tape.
Nov 05, 2013 | JVC HR-670 VHS VCR
Error 04: unit in safeguard mode, eject and reinsert tape. However, after I opened the cassette holder cover, the cassette holder didn't automatically open, and I can't get the tape out. I tried taking...
hi
i am dammika
from sri lanka
i have a jvc handy cam
but it broken display ribbon
i want by it in sri lanka
how can i get
pls send me a sms 0094778280849
thanks u
Apr 26, 2011 | JVC Video Cameras
JVC HR S5700AM S-VHS video recorder - won't accept tapes
Hey Lindsay
Yes the ejector is probably damaged inside maybe a bent arm or something mine is like that 2 and I didnt even bother fixing it I will be finding one very soon and I suggest you should 2 so just throw out the old and come in the new with your new vcr or dvd vcr combo..
Jul 23, 2008 | Televison & Video
Won't properly accept tapes/ tape won't fully insert
probably a bent cassette housing in the deck - time to seek out jvc authorized repair.
Jun 12, 2008 | JVC BR-DV3000U DV/Mini DV VCR
Flashing auto display - won't power up
The infra red light in the middle of the mechanical deck, that powers the left and right photo sensors is not ok.It looks like a small lamp( you cant see it when it works-Infra red mind it).The video cassette has a large round opening in the bottom towords the front, and accomodates this lamp.please check it out.
Apr 25, 2008 | Televison & Video
Cleaning the camera
hi, just insert a brand new dv tape and let it record for 10 min.. rewind back to 5 min and start playing and do a repeated ff and rw you can see the black lines slowly going off.. all the best my friend sreejith
Jul 08, 2007 | JVC Cybercam GR-DVP7 Mini DV Digital...
Trouble playing JVC KD-S580
i have the same problem in a 2001 mercury cougar. i got power all the way to the back of the radio from the ignition (red) and constant (yellow) wires and the ground wire is good. Think the head unit might be screwed the fuses are all fine. not sure though
Nov 11, 2006 | JVC KD-S580 CD Player
Tape door won't open on eject?
Many times I've heard my tape will not eject,most of the time unpluging the unit from the wall for about 10 minutes and then plug it back in,this resets the microprocessor and it goes bak to normal and the tape ejects.I hope it works. Please rate this solution if it does.
Oct 17, 2006 | JVC BR-S822DXU VHS/S-VHS playback VCR
JVC BR-S822DXU VHS/S-VHS playback VCR Logo
434 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
