Manual for NEC TV FS59V80 - Televison & Video
I have a nec plasma TV model number pxt42s11s with no remote how do I turn it on
see the following web site: http://www.manualslib.com/manual/672168/Nec-Pxt-42s11s.html?page=12#manual
page 12 has a pictorial of the layout of the manual buttons & an explanation of what each does.
Apr 14, 2015 | NEC Televison & Video
URGENT: How can I connect my tv to my NEC VT695 projector?
Do you want to duplicate the image going from the source to the projector on your TV? If so, then if your TV has a VGA port, just use the monitor Out on the projector. If your TV doesn't have a VGA port, you'll need an appropriate converter. (Avoid a VGA to component video or VGA to composite cable.) If you add a comment with more information on the inputs for the TV (or the model of the TV), then I will try to point you to the correct converter.
If you want to get your TV signal to the projector, you would need a set-top box (cable, satellite, digital tuner) as the source. Most TVs do not have a video output. You can connect a computer or DVD player to the projector.
The manual and quick guide for the VT695 are available from NEC here: http://www.nec-display.com/dl/en/pj_manual/vt695_491.html . The direct link to the English language version of the manual is http://www.support.nec-display.com/dl_service/data/manual/english/vt695_491_manual_e.pdf .
I hope this helps.
May 25, 2014 | Office Equipment & Supplies
WHAT MODEL REMOTE DO I REQUIRE FOR A NEC TV MODEL FS59V82S
the user manual for the tv can be found at this link:
http://www.generalmanual.com/Televisions/NEC-FS59V82-Stereo-Television.htm
look it up in there as it is likely to be found
Aug 16, 2011 | NEC Televison & Video
NEC 42VM2A plasma tv switch to internal speakers
I don't know if you have the owner manual for this T.V. or not but if you need one you can download a manual at www.devicemanuals.com/guide/Television/ Hope this helps!
Dec 03, 2009 | NEC PlasmaSync 42MP2 42 in. Television
Timer on light flashes tv doesn't turn on
Hi
I emailed NEC and they sent a manual
Thanks
Aug 20, 2009 | Televison & Video
Nec tv codes for comcast universal temote
You may have to try a different universal remote control. All universal remote controls do not contain all possible codes.
Dec 17, 2017 | ViewSonic N3251w 32 in. LCD HDTV
NEC model PX42VM2G service manual
You can search this database for the service info you seek about your tv here:
http://www.samswebsite.com/photofacts.html
Most service manuals with schematics cost about $27.95 for the PDF version of it, otherwise the paper version is about $15.00 more for handling and shipping.
You will need the chassis number of the unit in question in order to search for it. I hope this helps!
Good Luck!
Rich Lilja
Feb 04, 2009 | NEC PlasmaSync 42MP2 42 in. Television
Older NEC TV mising a manual
Manual missing here as well... what i found out.... if you press the "menu" button for 3 seconds you can set it up automatically (grey button on the lower right) and have 1 additional menu by pressing menu again. Hope this helps!
Dec 01, 2007 | Televison & Video
Televison & Video Logo
183 people viewed this question
Top Televison & Video Experts
