Question about Kenmore 72293 - Stainless Steel Top Freezer Refrigerator
Freezer fan freezer compartment freezes ok, Fan will not come on while evaporator in back is 'healthy' i.e. no ice build up, freezing to the touch, sports the frosty look it should have. Fridge portion cools nominaly only, to be expected I suppose due to no Freezer fan activity. Next step? Thank you very much in advance!
  • 909 Answers
Actually, freezer fan has to come on otherwise how is the fridge supposed to cool.(fridge draws off from the freezer compartment). check if there is power to the fan. if freezer is nice and cold and fan does not run(assuming there is no power to the fan at that time, then you would need to check your freezer thermistors after that, your board. all this is assuming you dont have a blockage or shortage of gas in the sustem.
Posted on Sep 20, 2007
  • 3 Answers
Possible solution if this is frost free fridge freezer you get a large biuld up of ice behind the plastic back on the inside of the freezer which you can not see the ice tends to jam the fan and stops the cold air from circulaton solution is to defrost your freezer this will take about 2 days because the of large amount ice behind the back pannel on the condensor hope this helps
We have a FRS-U20FA
The water dispenser tube has a low wattage element to prevent the water from freezing in the tube. its normal. Check to see if the evaporator fan is running. Open the freezer door and when the fridge is running, press the switch on the side wall. The freezer light should go out and then you should hear the fan running at the back of the freezer compartment. Common symptoms of a failed fan is ice growing down the back of the freezer compartment , poor refrigeration in the food compartment and partial or poor freezing of food in the freezer. If the fridge is less than 2 years old, it will be under warranty. (Contact Castel Electronics in Melbourne 13
00733962) If its over, they can give you the name and number of a local agent. There are a lot of bits and pieces to remove to get to the fan on an ice and water model, also the rear panel inside the freezer should be removed to make sure ice hasn't blocked the air ducts. If you are not confident in doing it, get one of their agents to sort it out. Cost of fan motor, call and labour should be around $200 to $220
Dec 26, 2013 | Daewoo Refrigerators
Kenmore refrigerator model 59562998 Compressor is running but no air is blowing into the refrigerator or freezer
the evaporator fan has stopped. it is usually in the back of the freezing compartment behind all the plastic. when the fan stops no air can circulate over the cooling coils so even though the compressor is running no cold can move iside the freezer or fridge. be extra careful when you take the small screws out as the screw heads can be full of build up that makes it hard to get a good hold of them. take your time and clean off all the screw heads so they don't strip out. The evaporator fan is not to expensive wait to buy on until you get the old one out.
May 01, 2011 | Refrigerators
Ice maker just stopped making ice. had no problem up to a complete stop
Hi and welcome to FixYa, I am Kelly
First off make sure the water in door still works. If it does not work suspect the door / light switch.
Next make sure the freezer temp is below 16 Deg F. The ice maker has a thermostat that starts the ice harvest / fill cycle and if the freezer is warming up because of automatic defrosting problems (Ice build up on the evaporator coils) the ice maker will never cycle. If you note an ice build up in the back of the freezer compartment or poor air flow from the evaporator fan you have an automatic defrosting problem. If the fan is not running at full speed the bearings or windings on the evaporator fan are failing and there is not enough air flow to get the freezer to @ or Below 16 F.
Check to make sure the evaporator fan in the freezer and the condenser fan in the rear bottom of the unit are running un-obstructed. (clean as necessary.... but if the front of the cabinet is hot to the touch then the condenser coils my be clogged with lint or... the condenser fan is not running full speed.
The ice maker may be cycling but it may not be filling with water. If it is cycling but your not getting any water.... at all the prime suspect is the solenoid on the inlet water valve. The water valve is not repairable.
Make sure that the rubber fill tube on the back of ice maker is not blocked with ice... squeeze the end of the tube. If it is frozen with ice... the inlet water valve is bypassing water off cycle and causing the tube to freeze up. The only remedy for this is to replace the inlet water valve.
Thanks for choosing FixYa,
Kelly
Apr 19, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
The freezer isn't making alot of ice. Can the hose behind the ice maker freeze?
Hi and welcome to FixYa, I am Kelly.
When a refrigerator slows down ice production it is usually the result of poor air-flow through the evaporator coils. The poor air-flow is due to ice build up on the evaporator coils. The ice build up happens because the unit is not defrosting properly or the evaporator fan is not running at full speed.
To answer your question "Can an Ice-maker tube freeze?" Yes, they can and do freeze but when they do freeze that is caused by a defective inlet water valve that is leaking water by when it is supposed to be shut off. It can freeze if some one set the temp control to MAX cold. Additionally when they do freeze and the Ice-maker cycles the plastic hose on the back of the unit pops out of the ice maker tube and each cycle starts porting ice maker fill water on the floor.
This may sound odd.. but. Perform a manual defrost by removing the freezer contents and directing a fan into the freezer compartment for just over 2 hours. (Makes a water mess so do not leave it unattended) The return the unit to normal service and after 8 hours start watching the amount of ice produced. (Should be normal for 2 days!) If after 2 days the ice production slows again you have an automatic defrosting problem that is causing the ice build up on the evaporator coils.
If you need any more assistance please include your complete model number in any future responses.
Kelly
Feb 15, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE Monogram won't freeze food
your evaporator coil in the rear area behind the panel is iced up and blocking fan air flow to the freezer compartment
Jul 25, 2010 | GE Refrigerators
GE side by side refrigerator GSHF5KGXECWW MS
Ok.. Just a bit of info for you if you have to sometime in the future do a parts search. This unit is the same as the Hotpoint HSS25GFTWW
Now for the icemaker problem.
When ice makers start making less ice it is usually a sign of some other problem.
1. Ice build up on the evaporator coils in the back of the freezer.
2. A slow or not functioning evaporator fan.
3. Dirty condensor coils in the back or the unit
4. A condensor fan that is running slow or not turning.
5. An automatic defrosting problem (most common problem)
If you have ice cream you probably notice that it is softer than usual. Or things in the freezer just are not as stiff as they usually are. When you notice this the freezer is warming up but the fresh food compartment is fine.
1st.. check to make sure the control panel settings are set to "0" for the freezer and "37" for the fresh food compartment.
2nd.. look for any obvious signs of ling build up in the bottom and back of the unit.
3rd .. Listen to the evaporator fan in the freezer compartment.
a. must be running full speed
b. should not sound like it is striking anything
4th.. Is the chassis near the doors hot to the touch? (should be warm not hot)
a. if hot to the touch the condensor is not getting rid of the heat due to lint build up, or slow / stuck / failed condensor fan.
5th.. there is always the very rare chance that there is an actual problem in the ice maker. (thermostat)
Parts reference: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5203104&diagram_id=24933028#d24933028
Thanks for using FixYa.
Kelly
Jun 18, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Electrolux frost free fridge freezer
i have the same fridge freezer and the same problem and have no manual can any 1 explain thank you
Mar 31, 2009 | Electrolux Refrigerators
Freezer side not freezing
It is possibly your defrost element which is not working causing a build up of ice and reduced airflow through the freezer compartment. This is located behind a cover in the freezer compartment. It is best to change both the element as well as the defrost limiting thermodisc which is attached to the fins of the evaporator.
Mar 04, 2009 | Amana SXD524VW Side by Side Refrigerator
Fridge
ok pull the cover off the back wall of the freezer compartment where the evaporator fan is after look under the evaporator should see an aluminum pan with a hole there that's the drain hole for the defrost system if its frozen and that hole is stopped up then every time it defrosts the water will run in the freezer and freeze and also drip into the fridge remove the ice and clear the hole also check the drain tube in the back to make sure its clean
Jan 18, 2008 | Refrigerators
Refrigerator freezes up
PLEASE DISREGUARD GUEST FIXYA SOLUTION,FREEZER PROBLEM PROCEDURE IF NOT DEGITAL,FIRST CHECK IF ICE ON BACK FREEZER WALL. STEPS-FIND DEFROST TIMER,BOTTOM FRONT ,BOTTOM BACK, INSIDE FRIG.ON CONSOLE,LISTEN TO SEE IF FAN IS RUNNING IF SO TURN THE DEFROST TIMER CLOCKWISE TILL YOU HEAR A CLICK SEE IF FAN TURNED OFF IF SO YOUR FREEZER IS IN DEFROST,FREEZER WILL COME OUT OF DEFROST IN 20-30 MINUTES IF IT DOES AND THE FAN COMES ON YOU HAVE ELIMINATED DEFROST TIMER&FAN,NEXT REMOVE BACK PANEL TO FREEZER IF THERE IS ICE FORMING REMOVE BOTH LEADS TO HEAT AND CHECK WITH VOLT METER ON OMES,IF YOU GET ANY READING THE HEATER IS GOOD,IF NO READING REPLACE HEATER AND CLIPON TEMINATOR,IF HEATER IS GOOD DEFROST COILS WITH HAIR DRYER TOP TO BOTTOM AND THIS WILL ALSO CLEAR THE DRAIN,IF EVERYTHING CHECK OUT GOOD DEFROST TIMER ,FAN ,HEATER, DRAIN, YOU NEED ONLY TO REPLACE THE LITTLE ROUND CLIP ON TERMANATOR,LET ME KNOW-MIKE
Oct 13, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 72293 - Stainless Steel Top Freezer Refrigerator Logo
294 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
