Question about Electrolux EOU6330 Electric Double Oven
Main bottom oven not working
Hi when the main oven is switched on the power indicator comes on and the fan starts but the oven will not heat up.I have checked the manual timer and this is on.The top oven and grill works fine. What do you think?? Thanks
  • 3 more comments
  • Anonymous Dec 05, 2007
    Hi I m having exactly the same problem and have been told that its the element not working
  • bertram Dec 13, 2007
    main oven not working.
    changed element and thermostat.
    still same.
  • Anonymous Apr 17, 2008
    same proplem with my main oven of {eou6330} when i turn main oven on . the main oven indicator neon light on panel comes on red and the oven light comes on inside aswell as the fan . but oven does not heat up . oven only 2 yrs old .I have checked oven in on setting for manual cooking .
  • Anonymous Dec 25, 2008
    Main oven not working and trips the house circut breaker
  • Anonymous Feb 17, 2009
    Oven doesnt get hot but fan, light inside oven and temp light comes on I think it also cause my electricity to trip as the bootom plugs went and now some things that were plugged in have fused. nightmare
Brand new euro pro oven TO161A. Used once. The oven will not turn on the indicator light is off?
Posted on Jan 02, 2009
I solved the problem by replacing element . new one cost 23 euro from electrolux spare parts dealer .1 undo 4 screws of plate inside the bottom oven . [ plate has holes in a circle patern in the middle of it ] . 2 gentle remove plate and expose the element .3 element has 3 srews .undo these and gentle take away from ovens backwall wall this will expose 2 wires that are connected to the element .3 very gentle unclip the wires from element . {grip the clips not the wires } connect new element and replace all screws and outer plate . this worked for me ....... remember to turn off the power to the oven before you go at it .
Posted on Apr 17, 2008
  • 1214 Answers
SOURCE: bottom oven not working
A tripped breaker or blown fuse on an electric oven or cook-top, combined with an element that has stopped working, is usually a sign of a shorted, then blown (if the fuse or breaker no longer fail) element.
If you know how to use an ohmeter, you can pull the element, disconnect the wires from each end, then measure the resistance between each end of the element, and each element to the outer sheath.
A good element has just a few ohms of resistance between the wire connection points, and infinite resistance from the wire connection points to the outer sheath. Any readings other than that means the element is bad and need's to be replaced.
Posted on Jan 14, 2009
mastatech
  • 478 Answers
SOURCE: Main oven of cooker is on, fan is working, but not
Most likely a bad,open, heating element. Turn off power at breaker, remove element ohm with ohmmeter if good. its the thermostat or control. However, some units have resettable thermosats
Posted on Mar 11, 2009
  • 12 Answers
SOURCE: indesit fde20 main oven wont heat up
sounds like the circular element at the back of oven has blown.
Posted on Oct 24, 2009
  • 417 Answers
SOURCE: fan in main oven boken
Sounds as if your oven heating element has failed. You need to fit a new one.
Usually you have to get the back off, disconnect the old element, remove the fixxing screws and element, fit new one, reconnect and it should be fixed. Don't forget to switch the power off before starting work.
Posted on Dec 31, 2009
heatman101
  • 43501 Answers
SOURCE: Top oven (and Grill) have stopped working
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Jul 30, 2010
Have replaced burnt-out element in main oven. Red light comes on when control turned, but no fan or heat.
an open circuit indicates infinity which means no ohms and what the element should read is a closed circuit. open is bad and needs replacement as for the no fan check for loose wire or power issue also might want to check for a blown fuse
May 06, 2015 | Ovens
My buttom oven is not working but top is working
If it is a fan assisted oven, and the fan is working, then it is likely to be a faulty heating element.
This should be located behind a removeable cover at the rear of the oven compartment.
If the fan is not working as well, then could be a faulty thermostat, even without the element or fan not working, there should be an indicator light on to show that the power is on,
Also make sure the main oven is set for manual operation, and not set on auto, as this will prevent the main oven coming on if it is.
Feb 12, 2011 | Tecnik TKC8522 Electric Double Oven
Bottom oven is not working even though the top one is 720EF model
When you turn the bottom oven on, does the fan start to run in the oven? Do the oven lights come on? Does the main cooling fan switch on? Does the oven control knob illuminate? Does the thermostat neon illuminate?
As a guide, the power/control for the bottom oven is via the main switch on the front panel. Power then goes from the switch through the thermostat to the the oven/element/fan. The lights go direct from the switch.
I hope this helps.
Sep 17, 2010 | Stoves 720EF Electric Double Oven
Main fan oven not heating
If the light and the fan are working then it is the heating element that has failed. You need to replace it.
Its not a difficult job but you have to take the back off the oven. The heating element is usually in a circular shape around the fan housing.
You have to disconnect the wires to the heater and remove the retaining screws, fit the new heater and reconnect. Remember to switch off the power before starting work
Jan 04, 2010 | Ovens
Fan in main oven boken
Dec 31, 2009 | Zanussi Ovens
Main oven does not heat up
When you turn the main oven on, does the oven fan switch on?
When you turn the main oven on does the cooling fan come on?
Does the dial illuminate when the oven is turned on?
Does the oven thermostat neon come on the the oven is switched on?
Have you had a power failure recently and have not set the clock?
Are you sure that the clock/timer is NOT set and in manual mode?
Dec 13, 2009 | Stoves 720EF Electric Double Oven
Stoves 720EF - main fan not working
When you say the main fan, do you mean the background cooling fan or do you mean the circulating fan in the bottom oven?
Do you have the handbook for this oven as the wiring diagrams are included in it. If you haven't, you can take a copy from my BT Digital Vault - all I need is an email address to register you.
Looking at the diagram, the power for the cooling fan comes via the timer board. If, as you say, the fan doesn't work at all, the timer board could have gone faulty.
Nov 15, 2009 | Stoves 720EF Electric Double Oven
Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
heatman101
Nov 12, 2008 | AEG D2100-4 Electric Double Oven
Main cooling fan switches on and off rapidly
hi there,
could i get the exact model # for your stove please?
Sep 14, 2008 | Tecnik Ovens
Electrolux EOU6330 Electric Double Oven Logo
643 people viewed this question
Top Electrolux Ovens Experts
Steve Allison
Steve Allison
John Tripp
John Tripp
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
