Question about Nikon Coolpix S550 10 Megapixel Digital Camera (Graphite Black) with 5x Optical Zoom + 4GB Memory Ca
My nikon camera lens won't work
Every time i turn on my camera the screen pops up as lens error and then the camera turns off. i had gotten sand on it so i'm sure there's sand stuck in the lens but i don't know how to get it out. Please help me!
  • 70 Answers
You must have cleaned/repaired by a professional.
Nikon is in Melville, NY or you may contact
SP-TS.com, an Authorized Service Center in Florida for an estimate.
Posted on Apr 20, 2009
Nikon coolpix lens error
Hello Ken,
The lens error in many cameras are caused due to sand or grit interfering with the lens extension mechanism. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials stick to the camera by electrostatic build-up from the camera rubbing against the side of the carrying case. To resolve the lens error remove the battery for some time. Then insert the battery again and charge the battery completely. Then try pressing and holding the Menu, Function, Function Set, or OK button while turning the camera on. Also try the factory reset option. Also try the on/off button many times after battery full charge.
Jul 02, 2011 | Nikon Coolpix S3000 Digital Camera
My lens is stuck open, every time i try to turn it on a lens error message pops up then quickly shuts down, wat can i do?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Dec 29, 2010 | Nikon COOLPIX S200 Digital Camera
Push on button. Camera turns on, lens pops out.
Most of these kinds of errors come as a result of some kind of impact, sand or dirt exposure, possible water damage, or some other problem with the lens.
There is a possibility that the lens is off track.
Try pulling or pushing (not too hard either way) and see if it may be off track and return it to the correct setting.
Since it is not working anyway, try the above a few times and then test the camera to work right.
I have fixed more than one with similar (off track problems) and they worked good after wards.
Worth a try.
If nothing works, I suggest to sell it (include all that you have with the sale) on a site such as Ebay as parts, or as is repair. It should bring something like $20.00 to $50.00. The LCD is worth something over $15.00 alone. The other parts of the camera has value to those who repair cameras.
Oct 19, 2009 | Nikon Coolpix L14 Digital Camera
Nikon Coolpix Lens Error
Hi!
It could be focus system problem - most likely stuck. Could be sand or some dirt inside focus gears. They're very small for these lens which are used in many Nikon, Olympus, Casio and other cameras so even one small piece of sand can block the focus system. The only way to fix it to take the camera and lens apart and clean it.
Sorry for the bad news. I repair cameras every day and you can trust me - I know what I'm talking about.
Tom
Sep 26, 2009 | Nikon Coolpix S210 Digital Camera
How can i fix a lens error on s610?
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 13, 2009 | Nikon COOLPIX S610 Digital Camera
Lens Error!
Hi onikaassing, A very common problem in all the brands "lens error". The remedy is that you have to replace the lens block assembly. Actueally the sled motor start malfunctioning, Contact nikon service centre maybe they have the component level repair facility which can reduce the repair cost. Thanks for using fixya.
Jun 14, 2009 | Nikon Coolpix S210 Digital Camera
Nikon s200 when camera turned on lens error
You may have a jammed lens assy. When the camera is turned on, camera go through a few stages of processing to be ready to take picutre and if the lens does not respond mechanically, it will give you a lens error. Lens jams due to sand or impact (even unnoticable light impact). If the lens is extended out you can somehow grab the lens barrel lightly with two fingers while turning the power on and nudge it side by side. If this did not help, take it to a reliable local technician for a diagnostic(should be free). Good luck. -james
Mar 28, 2009 | Nikon COOLPIX S200 Digital Camera
Camera stuck in "lens error" mode
Hello, It's time to let a Nikon camera repairman take a look. If lens does not pop out, then it could be motor, shutter, etc, etc. Check out one of our Camera Repair providers and get a repair quote.
Nov 30, 2008 | Nikon Coolpix 4600 Digital Camera
Nikon Coolpix S550 10 Megapixel Digital Camera (Graphite Black) with 5x Optical Zoom + 4GB Memory Ca Logo
630 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
