Question about Panasonic KX-MB781 All-In-One Laser Printer
Panasonic KX-MB781 drum reset
My printer Panasonic KX-MB781
I noticed that a kx-flb802 did not have a reset. Can you tell me if my 781 has a reset? If so, can you tell me the procedure?
Thanks and many blessings,
GrandPaGoz
  • 3 Answers
I already answered this at some other place her - but here I go again: There is a little special (white) gear on the outer left side of the drumkit - a little bit below where the toner sits. That gear joins with toner mixing assy - and you can rotate it in counterclockwise all the way back. This should reset the drum counter - worked for me - I hope it also does the trick for you ;-)
Posted on May 04, 2009
I have a Panasonic KX-MB781, When I make copy, send fax or scan. It make lines one the copise. Looks like scanner problem. How can I fix, it?
Posted on Jul 15, 2009
    Problem Solver:
  • 19 Answers
That trick from HobbesVT WORKS!!!! The gear he's reffering to is the litlle white gear with a crossed slot. I turned it to the left and the "replace drum soon is GONE. Thanks HobbesVT
Posted on Jul 05, 2010
  • Rosh Amendra
    Rosh Amendra Nov 29, 2016
    Do you have to take the drum out to do this?
  • Panasonic Master
  • 4,338 Answers
Here is the user manual, On page 11, there is reference to the "replace the drum " .But I did not see any reference to "reset"
http://service.us.panasonic.com/OPERMANPDF/KXMB271.PDF
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Apr 20, 2009
Posted on Aug 19, 2009
I have a similar problem, it tells me low toner, check supplies and check rear cover. I haven't touched the rear cover, I'm guessing check supplies means I need to replace the drum. I've read HobbesVT's answer, but I'm not too sure which gear I need to turn back, is the gear circled in red the one I need to turn back? If so, which direction do I turn it (up or down in relation to the picture).
http://img51.imageshack.us/img51/2497/dsc00329m.jpg
Posted on Jan 07, 2010
Panasonic kx-mb1500 drum life over reset code
There is a screw on the side of the cartridge that you have to screw in to reset the drum life timer. With the cartridge flat side toward you, the screw is on the right side.
Aug 30, 2013 | Panasonic KX-MB781 All-In-One Laser...
Drum life over in panasonic kx-mb1500
how reset panasonic kx-mb1500 drum life over
Jan 11, 2013 | Panasonic KX-MB781 All-In-One Laser...
I am receiving an error in panasonic fax machine KX-FLB802 CHANGE SUPPLIES & CARTRIDGE LOW REPLACE SOON kindly tell me solution for this error or how to factory reset panasonic KX-FLB802 THANKS
Your printer is signalling that it is out of ink and that you should put a new ink cartridge in. Without a new ink cartridge it cannot print the pending faxes.
Mar 25, 2011 | Office Equipment & Supplies
How to reset the drum on a panasonic kx-mb781
How to disable the COPY option of KX-MB781 all in one laser printer?
Jul 01, 2010 | Panasonic KX-MB781 All-In-One Laser...
Hi ihave a panasonic kx-mb781 and it say on
Fuser unit cannot heat up. Replace fuser unit.
Refer to CALL SERVICE 3 (P.120).
Mar 26, 2010 | Panasonic KX-MB781 All-In-One Laser...
Lost cd printer driver
Here is your printer driver please open this link in browser then download and install. this is perfect driver of your printer.
Note:- please dont forget to Give me RATING Thanks
http://cs.psn-web.net/support/fax/common/file/mb781/MFS78_117_ENG.exe
Sep 05, 2009 | Panasonic KX-FLB801 All-In-One Laser...
Panasonic KX-FLB802 driver
Hi!
You can download free drivers for your printer Panasonic KX-FLB802 from this link---
Panasonic KX-FLB802 Printer Drivers
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 12, 2009 | Panasonic KX-FLB801 All-In-One Laser...
Reset drum
I think this machine does not have a reset option instead you can reset manually.All you have to do is on the right side of drum unit there exist a white + type notch,rotate it clockwise till it allows.Put back drum unit into machine.Switch on and see replace drum and supplies message will disappear.In my case it worked.Hope this is the best solution.All the best
Jan 07, 2009 | Panasonic KX-FLB801 All-In-One Laser...
PANASONIC KX-FLB802
Printer Panasonic KX-FLB802 Driver for this printer to work with windows vista home ultimate cannot be found. Does a driver exist to suite Vista and where can i find it. Many thanks
Jun 16, 2008 | Panasonic KX-FLB801 All-In-One Laser...
Panasonic KX-MB781 All-In-One Laser Printer Logo
7,098 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
