Question about GE GSS20IEP Side by Side Refrigerator
GE side by side GSS25VGMD CC freezer freezing too hard
All of a sudden our GE side by side has started freezing too hard. I have turned the freezer down to 2, but things that you would notice like ice cream are freezing way too hard. Anybody have any suggestions?
  • rlputnam May 21, 2009
    Where is the freezer thermostat? At top back of freezer compartment or is it behind the refrig/freezer control dials in refrigerator compartment?
  • 700 Answers
Get a new thermostat for the frig
Posted on Apr 20, 2009
GE SIDE BY SIDE MODEL #GSH22JFRE CC FREEZER COIL FREEZING AND REFRIG NOT COOLING. DEFROST MANUALLY AND REFRIG COOLS FOR A COUPLE DAYS, THEN FREEZER COILS FREEZE AGAIN
We have a GE side by side that was only 4 years old before it starting giving us problems-coiling freezing over. The warranty period was only one year on all parts, including the compressor. Through our research we learned that profile appliances have or did have a better warranty. I believe it is 5 years on all or certain components. Either way it may be worth contacting GE customer service to help you with the issue and determine if repairs and parts for your appliance are still covered under warranty. They were very helpful in our case and ultimately discounted the parts I ordered and replaced myself. Replaced the the temperature sensors on the freezer side, the defroster thermostat and defroster heater before finally breaking down and replacing the control board. The control board was the problem. It was very easy to replace. While working through the issue, we would defrost the coils located on the inside of the freezer side with a hair dryer. It would get us by until the parts came in or they frosted over again and prevented air from circulating over them, thus causing the freezer not to cool. Good luck. Hope this helps you.
Nov 23, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
GSS25KGMB CC side by side GE fridge not cool.
You should check first to see if the condenser coil is dirty ( condenser coil is the Fin type coil you see in front of the compressor ) You can clean this by just brushing it out with a brush .The relay is plugged directly onto the compressor
May 17, 2017 | GE GSS25KGMBB / GSS25KGMWW / GSS25KGMCC...
The main control board is going bad . This is the electronic board behind the 8 x 10 inch panel , on the back of the refrig . Your relay on the compressor is ok .
Feb 20, 2010 | GE Refrigerators
I have a GE side by side refrigerator. Model#GSS25VGMD and every day I have to chip an inch of ice off the bottom of the freezer. I noticed water on the inside bottom of the freezer and thought it was the...
you have a blocked drain,when the freezer defrosts the water should go down drain but yours is blocked,i use a steamer to do this and you can get one for 40 bucks it's a shark super steamer,look at the back wall at the bottom you will see the drain hole,melt it out with hair dryer and then blow out the drain line with the steamer or use something to snake out the drain,if you use a coat hanger or something watch out because the drain line is pastic,when you think you unblocked the line pour hot water down the drain and if it goes down your done,you might have to take the back freezer wall off if you can't get at the drain hole,good luck,slime builds up in the drain or some thing could be blocking it like a corn kernel or something like that and the water freezes up because it can't drain
Nov 25, 2009 | GE GSS25VGMWW / GSS25VGMCC Side by Side...
GE side by side. The freezer will freeze up with
Replace the defrost heater, located at the bottom of the cooling coils, behind the back wall of the freezer.
Aug 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GSS25VGMD refrigerator not cooling evenly
i would observe the back wall for frost or ice accumulation if there is i would check the defrost circuit. the heater would be first, if it is good check the sensor is more than suspect. the defrost sensor is the one on top of the evaporator. If no ice is present open the door and feel the cabinet where the gasket touches on the frame. if it is extremly warm that would indicate that your condenser fan on the bottom at the back of the unit is out, this would also cause the symtoms you are having
May 17, 2009 | GE GSS25VGMWW / GSS25VGMCC Side by Side...
Water coming from ice maker freezing down back wall of freezer
check for levelness of the ice maker also make sure that the fill tube is inserted all the way into the unit
Apr 25, 2009 | GE GSS20IEP Side by Side Refrigerator
Freezer isn't freezing all of a sudden but frig. side is still cold
There is a cheap repair manual for this model listed on eBay. The item number is 200262539606.
Premmy
Oct 14, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE GSS20IEP Side by Side Refrigerator Logo
330 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
