I have an HP Pavillion ZE2000 laptop and it will nto boot up, push button to turn it on. goes to windows page then goes black and nothing happens will nto boot all the way up to windows page with icons. is there something wrong with my hard-drive??
  • 253 Answers
Press f8 at startup to get to the windows startup menu, choose "last known good configuration" If that fails, you can choose "disable automatic restart" and the BSOD, Blue screen will appear and give you an error, you can also goto safe mode with the f8 key on startup, choose safe mode, and then click yes at the prompt to start the system restore, pick a date and time the PC worked, and try that.If that doesn't work, you need to restore the PC to factory default state, by using or purchasing restore disks, you would have been asked to make them when you 1st powered on the PC, if you don't have the CD's call HP and order them.
Posted on Apr 20, 2009
Blackscreen blinking cursor
First in that Computer Setup, use HDD self test options. If results are ok - no SMART failure, no bads - it's a problem with operating system. You will have to download HIREN from http://www.hirensbootcd.org/download/
after that you will have to use yumi to install Hiren on usb
http://www.pendrivelinux.com/yumi-multiboot-usb-creator/
Ask for directions here. In yumi you choose Hiren, browse for the folder where you saved hiren iso image then proceed. After all is done. You will have to boot the laptop from USB with hiren.
Best is to USE mini Windows XP
Once Mini Windows XP is started go to Start, RUN
type CMD
hit enter
type: chkdsk c: /f /r
let it check
type chkdsk d: /f /r
let it check
restart
if problem persist you will have to reinstall windows
Good luck.
Post here results please
Dec 14, 2012 | HP Compaq nc4200 Notebook
HP pavillion laptop dv9428 17 in. Barely used, i pushed the power button to turn on , fan goes on, keypad lights up but no screen and i do not hear the hard drive like before. also, unable to turn off by...
One of the main, classic problems with HP is heat. What probably happened is the GPU (Graphics card, it handles the picture basically)solder cracked, meaning the onbard card and the board it goes on have come apart slightly and as **** you would need a new motherboard to remedy the problem.
May 17, 2011 | HP Pavilion dv9428 Notebook
HP pavillion dv2700 clicking noise, black screen
try to run the hdd test in the bios page and see what it says. if it says no ide device found, try to reseat the hdd.
Apr 26, 2010 | HP Computers & Internet
Wont boot on it's on,and then gives blue screen and restarts over
this is a system32 driver issue with windows i believe. i had this same problem when i plugged in a PCI Sata Adapter it screwed a driver all up and windows was stuck rebooting over and over. the only way i could think to fix it was to format the HDD and reinstall windows from scratch
Oct 17, 2009 | HP Pavilion ze2000 Notebook
HP Pavillion dv2500 laptop will not boot up.
Pressing the f8 key doesn't work either? This should boot the laptop to safe mode, if it doesn't then check the memory cards before you do anything else, try to get somebody with the same type of memory card to lend it to you. If that doesn't work, then your HDD is corrupted, and to re-install Windows.
Sep 05, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP Pavillion ze2000
the boot sector is damaged at this time, try again the system restore, if all else fails you need to install a fresh OS XP home version be mindful of all your drivers cause you need this afterwards
Sep 17, 2008 | HP Pavilion N5415 Notebook
HP Pavillion ZV5405 with Black/White vertical lines through screen
Will it boot from a CD/DVD? Make sure the boot sequence is set to boot CD first and then see if it will boot into setup from a CD/DVD. If it will, then maybe try reinstalling windows. Hope this helps.
Aug 21, 2008 | Acer Aspire 5100 Notebook
Freezing or shutoff on boot, setup or minutes into operation
Try this:
Boot the system with your Windows XP installation disk. When the boot options window appears select R for recovery console. Once you have logged into the DOS session type: fixmbr and hit the enter or return key and select "y" for yes you want to do this. Type: fixboot and hit the return key again, hit "y" for yes.
May 17, 2008 | HP Pavilion ze2000 Notebook
Laptop troubles
I will reinstall windows XP, or your batery Bios is completely dead
Aug 27, 2007 | HP Pavilion ze2000 Notebook
Computers & Internet Logo
169 people viewed this question
David Payne
David Payne
