Question about GE Refrigerators
Ge gss22ufmd cc not staying cold in fridge or freezing in freezer
I changed the settings over 24hrs ago and no real change
  • GE Master
  • 4,655 Answers
Your refrigerator has a control board located on the back. If you can unplug refrigerator and remove the board so you can examine both sides. We need to look for burn marks on the board. That circuit board controls all functions on your refrigerator. If you want we can get this fixed from here, Let me know, Thanks, Sea Breeze
Posted on Apr 20, 2009
Hotpoint HTR17BBRFRWW top freezer does real cold but bottom fridge stays at 52 or above. Coils clean and gaskets good, unit level and compressor runs quiet. What is obstruction between freezer and f
http://www.partselect.com/Schematics/GE/00113789i02.gif
look at number 304. Ice more than likely has formed and not letting air flow from the freezer to the fridge.
Jun 03, 2012 | Hotpoint Refrigerators
Ge profile Ps27sgra refrigerator and freezef are
Hi, this problem is going to be with the running thermostat2.gif (cold Control). It has gone bad and stays open which in turn will keep the compressor running continually and will cause the fridge2.gif to get colder and freeze food. It can normally be located in the control panel inside the fridge (it is the control that has wires, the other is the damper). Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Oct 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Side by Side freezer cold but not freezing, fridge is warm
you might have a defrost problem, timer,heater or bimetal when the coils freez up they dont cool enough .
Jul 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge fridge GSS25LFGww, fridge part freezing food
Hi, Change the controls back to normal settings. Make sure the freezer is getting 0 to 5 above. If the freezer is getting cold enough, try and turn the cold control to 1 and see if the refrigerator shuts off. It sounds like the cold control in not working properly and will need to be replaced. NOTE: The freezer temp has to be right temp or the fresh food side will not work proper.
I hope this helps. Please let me know if I can assist you further.
Vic
May 30, 2009 | GE GSS25JFM Side by Side Refrigerator
I have the top mount refrigerator - 4years old. Ice maker was installed then removed because it broke about 2 years ago. Suddenly I am getting a huge amount of water in the crisper drawer but no other...
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer and Fridge temperature not very cold
I can find only one good reason why your refrigerator may not be cooling. There is a control board inside the fresh food compartment and no signs of a defrost timer. If there is someone that go through some test to eliminate other possible problems would be good. If the refrigerator is still running, unplug and open the freezer compartment. Remove the back panel so we can have a look at the evaporator coils. Clean or are they frozen with a large piece of ice? Let me know, Thanks Sea Breeze
Mar 23, 2009 | Maytag ZigZagW / B Side by Side...
Kenmore Side by Side Refrigerator too cold
On a fridge freezer only the fridge temperature is monitored. In a cold location the fridge might not even need cooling and the freezer would get too warm but the thing won't care.
If the fridge sensor sees it as too warm then it will keep the motor running and the first thing to get really cold is the freezer.
Remember the freezing part is not temperature controlled ion a fridgefreezer.
Apr 28, 2017 | Refrigerators
Refrigerators Logo
222 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
