What does Code 5ud for front load Kitchenaid washer mean?
This error code indicates excessive detergent suds occurred during the cycle. This could be caused by using too much detergent or not using High Efficiency (HE) detergent.
The washer will not be able to spin out water with the excess suds. When "Sud" or "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the tumbling and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This pause and rinsing are necessary and may occur several times to eliminate the suds. This could significantly lengthen the time for your washer to complete the cycle.
If the problem continues, and the correct amount and correct type of detergent is being used, we suggest running a "Clean Washer" cycle to remove residual detergent that might have built up in the washer. Follow the instructions in your Owner's Manual for cleaning
