Question about GE GTS22WCP Top Freezer Refrigerator
Ice cubes taste bad
GE GTS22WCP Top Freezer Refrigerator We're renting. We've been in this house for almost a year now. Curious to find out if anyone knows if this fridge has a filter for the ice maker inside the freezer? The ice has an odd taste to it. If it does, how the heck do you get to it? Now this problem is new within last month or so.
  • 700 Answers
There should be one in the frigerator for the water if not go the the local home depot and get a inloine on for it.
Posted on Apr 20, 2009
  • Todd Born
    Todd Born Apr 20, 2009
    there should be one in the frigerator for the water if not go the the local home depot and get a inloine on for it.
Bad fan blower smell and bad smelling and tasting ice cubes from ice cube maker
If unit has a water dispenser, how does water taste? I've run across bell peppers that will emit a bad smell. Keep in mind 95% of all refrigerators circulate air from freezer to refrigerator side and then back. It continues to circulate air so bad produce from refrigerator side will get into freezer side and ice will absorb smell. First, dump all ice. Then line shelves in refrigerator side with newspaper, that absorb smells. You can even try kitty litter in small cups in refrigerator side. Bell peppers gives off that metallic smell and can take some time to get out of unit. Highly unlikely a motor is bad and you've already changed outside water line.
Aug 07, 2015 | Maytag Refrigerators
What all should I take apart to try and repair myself. No money at this house.
If the freezer is working then the compressor must be working. Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 11, 2012 | GE GTS22WCP Top Freezer Refrigerator
Why does the ice from ice maker have an awful smell and taste? Is there a filter that needs to be replaced?
i found that the previous homowners hooked the icemaker to soft water instead of hard water. Once I changed it to hard water, both ice cubes and water tasted fine.
Jul 09, 2010 | GE J Series 18.2 cu. ft. Top Freezer...
Does make ice cubes
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
fjjkf
Oct 02, 2009 | GE GTS22WCP Top Freezer Refrigerator
Black dirt/sediment on ice cubes
maybe the waterline leading up to the refrigerator is dirty?
Oct 27, 2008 | GE GTS22WCP Top Freezer Refrigerator
ICE CUBE MAKER SMELLY ICE CUBES
Hello margrek
Welcome,
YOU SAID, YOU HAVE KENMORE ELITE BOTTOM FREEZER WITH ICE MAKER THE ICE CUBES SMELL HORRIBLE ALWAYS, I EVEN TOSS THEM OUT EVERY FEW DAYS, STILL SAME PROBLEM
Ice has bad odor and taste.
1• Ice has picked up odor or
flavor from strong food stored
in refrigerator or freezer.
2• Water running to ice maker
has poor taste or odor.
3• Ice not used frequently enough.
4• Cover foods tightly. Discard stale ice. Ice maker will
produce fresh supply.
5• Add filter to water supply line. Consult a water purifying
company.
7• Discard stale ice.
Huuum
Please remember to leave a rating!
Oct 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Bad water & ice cube taste
Hello redwood City
Welcome
You said,
Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You replaced the copper tubing which delivers the water to the fridge and that didn't help. You replaced the copper tubing again with plastic tubing...no better. Any suggestions? Your tap water doesn't taste this bad.You bought a Kenmore french door fridge with water dispenser in the door in July 2008. The fridge has a filter. A few weeks after the fridge came the water and ice started tasting really bad, unlike any bad water taste I have ever tasted. And your tap water is fine. The bad taste appears to be random. Sometimes you get a cup full of nasty water and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions!
Did you do this before connecting the water line to your fridge?
"Place the free end of the tubing in a container or sink, and
turn ON the main water supply. Flush the tubing until water is
clear. Turn OFF the shutoff valve on the water pipe. Coil the
copper tubing."
Whirlpool remedy
Off-taste, odor or gray color in the ice
1.Are the plumbing connections new, causing discolored or
off-flavored ice? Discard the first few batches of ice.
2.Have the ice cubes been stored too long? Throw old ice
away and make a new supply.
3.Does the freezer and ice storage bin need to be cleaned?
See “Cleaning” or “Ice Maker and Storage Bin.”
4.Has food in the freezer or refrigerator been wrapped
properly? Use airtight, moisture-proof packaging to help
prevent odor transfer to stored food.
5.Does the water contain minerals (such as sulfur)? A filter
may need to be installed to remove the minerals.
6. Is there a water filter installed on the refrigerator? Gray or
dark discoloration in ice indicates that the water filtration
system needs additional flushing. Run additional water
through the water dispenser to flush the water filtration
system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to
7 minutes initially). Discard discolored ice.
Let me know what works,
Thank You ,
HUUUM!!
Please remember to leave a rating.
Sep 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
GE GTS22WCP Top Freezer Refrigerator Logo
348 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
