Question about Sony VAIO VGN-FJ270/B Notebook
Sony vaio vgn-fe18gp cd drive has died, no power, no lights
When I start up there's no flashing light on the cd drive and although I have cleared values on upper and lower filters, unistalled drivers, and downloaded latest gear drivers nothing seems to fix it, it seems to be no power to it at all. I have unscrewed the back, checked for loose connections and still no joy. Any help with this will be greatly appreciated!
  • 4 more comments
  • kostas73 Apr 20, 2009
    yes I have, the device manager reports no problems and lists all drivers
    I added a comment 5 mins ago but cannot see it! yes, I did try the device manager and it reports no faults
    no I have not done a system restore or reformat, not quite sure how
  • Anonymous Apr 21, 2009
    I have now done a system restore, still no joy!
  • ERIC BAKER May 11, 2010
    Have you tried doing a system restore or a reformat?
    Have you tried going to the device manager to resolve the issue with the cd drive?
My vaio van sz483N will not start following a hard drive replacement?
The HDD has not been placed correctly leading to a short circuit so the laptop does not switch-on . Remove the HDD and power-on the laptop if it switches on then need to check the HDD .
Jun 17, 2015 | Sony Vaio Vgn-sz436n/b / Vgn-sz476n/c /...
Viao vgn-nr430e/p just died
remove battery and retry with only ac power connected ..if that works then the battery is bad...if that doesnt work then it could many other things like bios battery, power connector, mobo...
Apr 15, 2013 | SONY VAIO NR Series VGN-NR430E/P NoteBook...
How to check mbx-160- vaio
I HAVE A SONY VAIO LAOTOP VGN-N31S DO NOT START UP. LED LIGHTS ARE ON. SCREEN IS DARK. CAN ANYONE HELP
Feb 20, 2010 | Sony Computers & Internet
Laptop will not boot, Sony Vaio VGN CR220E, lights come on, don't hear the Hard drive start up, however. I get the clunks from the CD drive, but that's all.
Such problems happen when you have either faulty RAM or faulty Mother Board. Repairing MotherBoard Chip is a costly affair but replacing RAM is convenient and most probable solution.
With Regards,
Ankit
Oct 08, 2009 | Sony VAIO VGN-CR220E/P Notebook
Problems booting Sony Vaio VGN N250E
no more then likely it sounds as tho your hard drive went ..not the mother board.
Jul 23, 2009 | Sony VAIO VGN-N250E/B Notebook
Cd drive dosent work
Please follow the instructions through the link to troubleshoot the CD/DVD drive.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C425906
If the issue persist after performing all the steps successfully then service may be required.
Jun 23, 2009 | Sony VAIO VGN-N130G/W Notebook
Sony VAIO VGN-FJ3M/W does not boot.
Possible hard disk failure or hard disk controller failure.
if you feel confident remove the hard disk and replace - obviosuly make sure that there is not power running and remove the battery - replace hard disk then battery then power and try again.
Do you get any beeps? is the hard disk clicking? listen carefully to it and post your findings.
Jan 10, 2009 | Sony VAIO VGN-FJ270/B Notebook
Sony VAIO VGN-FJ270/B Notebook Logo
163 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
