Question about Amana ARB8057CSR Bottom Freezer Refrigerator
AMA BX21 7 years old Came home found freezer warm and thoughted, top referigator was still almost cold, have bben gone 5 days---the compressor keeps trying too start but cuts off after 30 seconds , fan still runing Help
  • Amana Master
  • 4,655 Answers
Look inside the fresh food compartment. Behind the temp. control cover is a defrost timer. Yours may have a small opening that you can put a pencil eraser in and turn clockwise. When you do that the refrigerator should begin cooling again. I will be here to help you get your refrigerator going with diagrams and part numbers, Thanks, Sea Breeze
Posted on Apr 20, 2009
  • John Tripp
    John Tripp Apr 20, 2009
    Told you the wrong place for timer, It's behind the kick plate on the front and floor of refrigerator.
Hi, my Hotpoint ff200e fridge freezer is cooling but not freezing, compressor wires are warm and compressor itself is quite warm, top fridge is not cooling enough, then the lights on control panel start...
Hi.. feel the dividing rdge between fridge and freezer.. is it warm?.. chances are that the little fan at the back of the fridge freezer that helps cool the compressor, has snagged own it's own wire... it's a weak fan, like you get in a computer, but it does a lot of work.. without it, the coolent does not do it's job, which results in your device not cooling things properly
Apr 24, 2017 | Hotpoint HTM17BBSSA Top Freezer...
Chest freezer model mfco5mobw4 been plugg in for 2 days now set on the coldest setting not getting cold compressor is warm
God day,
Either the refrigerant has leaked out or the compressor isn't pumping properly. If you can put your ear up to the unit and it hums that is the compressor running.
No practical repair possible unless the unit is under 5 years of age in which case you are entitled to factory warranty service.
Apr 29, 2010 | Frigidaire 5 cu. ft. / 142 liter Chest...
2 year old Kenmore freezer won't keep cold. It
Check underneath the unit and make sure the compressor is running and that the compressor fan is turning.
Oct 15, 2009 | Freezers
Frigidaire plht189sska top freezer fridge problem. Freezer is cold, fridge is warm. About a month ago, had the problem of frost build up in freezer, water pooling under veggie bins, warm fridge. ...
If the defrost heating element, defrost timer or evaporater fan weren't working, you'd develop a block of ice on the evaporator. Is the compressor running? If it is, it might have bad valves from the frost buildup scenario. Liquid refrigerant could have gotten to the suction valves. The sealed system should have a five year warranty. Might be time to call a pro
Sep 15, 2009 | Frigidaire PLHT189CSB Stainless Steel Top...
Kenmore Elite Trio Refrigerator not cooling
No, it is not a failed condenser. You need to see if the compressor is running though. When it runs you shaould have a fan in the freezer running, a fan underneath the fridge running, and the compressor should be running. I would be willing to bet that either the compressor is bad, or the start relay on the compressor.
Sep 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
No power
Fridge is 60% nit working.The freezer is -20%.Circuteboard was replaced and defrost controler.Referigator does not work.Service technition has tried three times to repair.Referigator is 14months old.
Aug 05, 2009 | LG LFC23760ST Side by Side Bottom Freezer...
GE Side by Side Ref
Sounds like an internal mounting spring for the compressor. Only solution is replacing the compressor. However the compressor can run in this condition for years. Replacement compressors only have a one year warranty. A new refrigerator comes with a five year warranty.
Dec 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer cold but frosted up, Fridge Warm
If the freezer is packed to the top and the air ducts are blocked it can not share the cold air with the refrigerator and it gets warm. If this is the problem, then the next day it should get cool again! let me know.
If you decide you need service!
Here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Sep 02, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Westinghouse Fridge Problem
Is the fan in the freezer running? You should be able to hear it. If not, that is your problem. Check the door light/fan switch or check if the fan has power to it when you press the door switch in by hand. If fan is running, you could have a defrost problem. The defrost timer or the defrost heater could be faulty.
Nov 04, 2007 | Refrigerators
Amana ARB8057CSR Bottom Freezer Refrigerator Logo
636 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
