CAN NOR FIGURE OUT WHERE THE LOW SERVICE POINT ON THE 1999 DODGE CARAVAN
WHERE IS THE LOW SERVICE POINT ON A 1999 DODGE CARAVAN FOR AS RECHARGING
  • 700 Answers
It shopuld be by the evaporator section by the fire wall
Posted on Apr 20, 2009
AC recharge location
theres 2 hi side and low side
if your thinking of using the stuff seen on tv don't it dos more harm then good as in compressor failure best to take it to a profational
Feb 28, 2014 | 1999 Dodge Caravan
Code 1,2,7,8,23,55 1999 dodge caravan
1/2/7/8/ are not in the code system code 23 intake air temp. sensor either to high or to low. code 55 end of message. hope this will help!!!
Apr 12, 2010 | 1999 Dodge Caravan
I took my 99 dodge grand caravan to advanced auto and got a computer readout of p1491 as the error code. is this important and is this expensive?
P1491 is Radiator Fan Control Relay Circuit. MEANING: An open or shorted condition detected in the low speed radiator fan control circuit.
Some questions for you:
1. Is your Caravan overheating?
2. Is your Caravan water temperature spiking going past the midway point on the Temp Gauge before the radiator is engaged?
3. Is your Rad Fan coming-on and then turning off and back-on in a very short period of time (like under a minute?
If all of these are "No" then do not worry about it.
Nov 15, 2009 | 1999 Dodge Grand Caravan
No ac / fan only works on high
replace the AC blower motor speed control resistor, it is burned out
Jun 30, 2009 | 1993 Dodge Caravan
I need to recharge the 134A A/C dual system in a 1999 3.3 litre Dodge Grand Caravan. Most if not all of the oil was probably lost when the van hit a deer. The high side line was broken as was the...
Most of the oil should be in your compressor, if the compressor was not damaged and not replaced you should be ok on oil other than recharging it with a 134 w/oil. That should be sufficient. Usually there is about 8 oz put directly into the compressor when replaced. In that vehicle I believe it should alos be recharged with 32 oz. of freon.
May 13, 2009 | 1999 Dodge Grand Caravan
1999 dodge caravan 3.3 responding to "no" answer.. key is sheared off inside crankshaft. i need to remove it to put a new one in. what is the easiest and safest way to do this?
You can use a small point punch and tap on the end and the other end will raise out and can be removed with needle nose pliers once raised.
May 01, 2009 | 1999 Dodge Caravan
No high beams on 1999 Dodge Caravan; low beams work fine
replace the switch in the column i had the same problem on a 1996 caravan when i replaced the switch the problem stopped
Jan 02, 2009 | 1999 Dodge Caravan
No heat and thermostat light just came on
it is either low on coolant or the thermostat is sticking
Jan 01, 2009 | 1999 Dodge Caravan
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
