Question about Intel 845GE Motherboard
I am new in computers and I want to build my own..., I bought all the parts .. I put them together and O don't knot what to do next.. I check all the bios and put exactly what the manual as is the mother board I bought is AP45TUD3P The CPU is Intel Quad 2 (64 -bit Please answer to cgarmendez_2@yahoo.com
  • Mike  Petrowsky
    Mike Petrowsky May 11, 2010
    need the make and model of the motherboard.
There is not enough information here to help you. Can you be more descriptive of what you are or not seeing? some information about what hardware you have and how you have it configured would also assist in giving you a better answer. If you do not have enough experience to know hat you have done wrong you may need a pseudo-expert to help you.
Posted on Apr 20, 2009
Whirlpool washer ties clothes in knots on spin cycle
Its the wash or rinse cycle that is tieing the clothes in knots not the spin cycle. Try putting less shirts in. It happens because of the agitation during the wash. Or pin the sleeves together.
Mar 09, 2015 | Whirlpool LSR5132PQ Top Load Washer
How to install pull cord?
take off cap then take out old pull cord once done get a cord long enough some will hanging out when recoil rewinds rope next there is hole in rewind pulley make sure you find it then hard part rewind spring on recoil till it stop hold tight the unwind 2 winds hold on tight next slip cord trough houseing and through pull hole put screw driver threw holes in threw rehousing that will hold in place the pulley not the cord take a lighter heat the cord up this will keep the knot in place grab cord remove screw driver from houseing hold cord tight pull cord until knot is seated next two pulley slowly let reciol wind rope in until it stops should be cord hanging out grab hiold of cord next to recoil hole pull out for two pulley revolution hold there install handle on rope tie knot heat knot with lighter your done cut off excess rope reinstall cap and completey down let me no if you have problem i will help im the red neck i like helping people
Aug 28, 2014 | Garden
I just bought a trampoline for our backyard. One problem, I have no idea how to put it together. Can someone please help me?
Don't worry - it seems more difficult than it is. I just recently put together a trampoline for our family and found an amazingly useful how-to guide (with pictures) that really helped me when it came time for me to assemble our *****. I would be more than happy to pass it along to you.
http://www.wikihow.com/Build-a-Trampoline
Jul 30, 2012 | Sport & Outdoor - Others
I am having a problem with the thread knotting up on the bottom of my material. The needle starts to lock up and when I start checking the thread is all knotted up. I then take the bobbin out and it...
What you have going on is probably a bobbin problem. The knots are referred to as birds' nests and happen usually happen when your bobbin thread gets caught on something in the bobbin area. To be certain it's a bobbin problem, change your needle. Even if the needle looks fine, it could be just slightly bent and still look fine to the naked eye. If that doesn't solve the problem, take the fabric out of the sewing machine and turn the machine wheel by hand. Watch what happens thru the plastic window in the bobbin area, or if you don't have a plastic window leave the bobbin covering off. Is the thread catching somewhere and causing a bunch of thread to gather in the bobbin area? Be very careful when investigating in the bobbin casing/area-it's easy to chip things in there! Often times, a piece of something falls in there and can be pulled out with tweezers. Just as often, the bobbin casing is slightly tilted and needs to be straightened or has a chip in it and needs to be replaced. You can normally get a replacement on eBay, searching with your machine model number. Also, check out SewVacUSA. If you need help replacing the bobbin casing (it's easy, you just need to be careful), or if these solutions don't work, leave me a comment. I check back daily, so I'll get back to you within 24 hours normally. Leave me as much detail as possible and I'll do everything I can to help you!
May 11, 2011 | Singer 3116 Simple
Bought a KB classics build & load track set. The small car fell apart when I thought I was putting in the battery. Instead when I unscrewed the car, the small motor just fell apart. There are...
i have the same exact problem, tried to put the gears back together myself and couldn't figure it out. i tried to see if i could just order another car car but no luck with that either. please let me know, as well
Jan 01, 2011 | Toys
Dryer not heating. need instructions on pulling heating element out to replace.
Most dryers have a panel on the back where one can check the heater coils. Depending on the make, sometimes you have to remove the top and or the drum to access the coils. When you get to the coils you can replace or join(splice) them back together by forming a hook on each end and after hooking them back together twisting the free ends on themselves. This will work and you may not have to but a new coil. Kind of like a fishing knot without the knot.
Feb 23, 2010 | Dryers
How do you put on a new starter rope on a poulan# 306a chainsaw
I'm guessing the pull rope is broken.
First you'll need a C-clamp large enough to clamp the spooler, needle-nosed pliers, a small tipped screw driver and a new length of rope.
The safest way is to remove the rewind assy. cover leaving the spooler in place in its housing, try to remove the old rope with the
needle-nosed pliers and small tipped screw driver.
Next hand spin the spoiler to achieve spring tension (about 5 or 6 revolutions) and using the C-clamp to hold it in place, attempting to lineup the knot recess in the spooler with the ropes exit hole on the cover.
Then you can try to fish the new rope into the hole in the knot recess trying to guide it to the exit hole in the cover (its easier to feed the rope if you singe the end of the rope with a bic lighter and form it to a point) and with a small knot at the other end, pull the rope all the way until you can seat the knot into the knot recess.
Next tie a loop knot onto the other end of the rope, so the end wont be recoiled all the way into the housing. With tension on the rope gently remove the C-clamp and let the rope be drawled in.
If it draws all the way to the loop knot, check to see if the spooler is full if so, (not too full where its binding) pull the rope about a foot and re-clamp the spoiler and install the pull handle.
If it does not draw all the way to the loop knot and the spooler is not full, then you may need to add another revolution to the spring tension in the same fashion as described above.
There are easier ways, but that evolves removal of the spooler and repacking the recoil spring. (not a job for a novice)
Good luck
Aduz
Mar 11, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
New build computer wont turn on (ASUS A8N32-SLI Deluxe Socket 939)
The ATX power supply needs to have pin16(PS_On#) to be connected to COM for it to work. When you press the power switch on the front panel of the computer, you are essentially making this connection. Check that the cable from the power supply to the motherboard is making good connection. You can verify operation of the power supply by shorting Pin16 to pin17 on the powersupply output, with a paper clip. Pin16 is usually a green wire and 17 is black. Hope this helps. -Vish
May 04, 2007 | ASUS A8N32-SLI Deluxe Motherboard
Intel 845GE Motherboard Logo
37 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
