SOURCE: DRIVERS OF PRINTER CANON BJC-250 FOR WINDOW VITA
[English Below]
No lo encontrarás.
Utiliza el mismo para Windows XP, cuando lo instales presiona "Continue Anyway" (o su equivalente en Español). Esto debe funcionar, hasta la fecha Vista aún no tiene soporte para tu modelo de Canon.
Suerte!
)O(
The question is: "I cannot find the controller for a Canon BJC-250 Printer for Windows Vista"
CoolDragon's Answer:
You won't find it.
Use the same one for Windows XP, when you install it press "continue anyway" until today, Vista has no support for that model of Canon printer.
SOURCE: Printing from my macbook pro using my Canon Image Class D320
I am sorry but some companies do not have Mac drivers for the older devices. You can try downloading the SWITCH ( not sure of the correct name) program that lets you run a make shift ( simulation) windows on your Mac and that may be the way to print to this device.
SOURCE: PAPER JAM
laser printers dont use ink.
you will have to check the sensors. first the one where you put the media (paper) then check the registry one (remove the cartridge and you should see it) then the fixing on, from the back it has a small cover you can open an dthen a pair of green coloured levers to remove any jammed paper in fixing (the hot ***'y) then check the delivery sensor right where normally you see the page printed out and coming your way. there should not be any media remains anywhere. also if you copier is dirty it may also be causing this. try to clean it with compressed air.
SOURCE: Canon Image Class D320 does not copy entire page. New toner has been installed.
Has anyone changed the paper size in the paper tray to another size by accident? Have you tried the manual feed tray? If that copies the whole image then the problem is with the paper size input of the paper tray.
SOURCE: i have a canon image class D320 that is flashing a
try to replace the ff. parts heater/thermistor/thermostat
