Question about HP Computers & Internet
I changed my os vista-xp so internet connection is not working .could it be identification probs
  • Mike  Petrowsky
    Mike Petrowsky May 11, 2010
    did you install the network adapter drivers?
    Problem Solver:
  • 6 Answers
Yep, make sure you got network drivers installed either from CD supplied or via download @ manufacturers site
Posted on Apr 20, 2009
How come frostwire and lime doesnt work in my laptop,i have a windows 7
Get the lastest version for both "torrrent/P2P" downloaders
FrostWire 4.20.8
Requirement
128 MB of RAM (256 MB Recommended)
OS: Windows 7, Windows Vista, XP, 2000, NT
Mac OS X 10.5 or later
Linux, Unix such as Solaris
Java 1.5 or later (1.6 Recommended)
An active internet connection
You can download @ http://www.frostwire.com/
LimeWire 5.5.13
OS: NT, 2000, XP, Vista, Win 7
You can download @ http://www.limewire.com/download/?bw=1
Do your PC meet the above requirements?
Hope it helps.
Aug 13, 2010 | Computers & Internet
Disc drivers not working
hi dorys_brian,
you may go to your device manager first, right click on the first item (saying: computer) then click on the option that says "detect hardware changes". once this is done and you are online, your computer will ask for drivers which can be found in the internet. this is strongly effective for vista. but please note that if you change OS from XP to Vista, some hardware that worked for xp may not run on vista because of drivers not made for the said hardware to work on vista.
hope this helps, lemme know if you need more info.
regards,
voodoo
Apr 14, 2009 | Computers & Internet
How to share internet connection on Windows Vista OS. I want to share internet connection between two Laptops using Windows Vista Operating system and the other using Windows XP. The Host computer is...
All right let's call your Vista computer A and your Xp computer B. First you have to bring the two computers into LAN. If you already did this, please skip the next eight steps.
Step 1: In Vista, before doing this you should enable Sharing and Discovery. You can do that by going to Control Panel -> Network and Sharing Center. Under the section ‘Sharing and Discovery, enable Network discovery, File Sharing, Public folder sharing and others if you want to. (See picture below)
Step 2: If your LAN card that is connecting to another computer is installed, it will be shown under Control Panel -> Network Connections.
Step 3: Right click that local area connection and click properties.
Step 4: Under the tab ‘Networking’, click the properties Internet Protocol Version 4 (TCP/IPv4).
Step 5: Click the radio button to ‘Use the following IP’ and give an IP address (For example, IP address: 192.168.0.1 and Subnet Mask: 255.255.255.0)
Step 6: Don’t give any other information, Click Ok and close everything.
Step 7: In computer B, which is the XP, make sure you enable the LAN card which is used to connect to computer ‘A’. Here you need not give any IP information as Computer ‘A’ will assign an IP address dynamically. If it’s not working make sure there are no IP assigned and change the properties to ‘Obtain an IP address automatically’.
Step 8: Test the connection by pinging. (You can do this by typing ping 192.168.0.1 or whichever is Compter ‘A’s IP in the comand prompt)
NOW your computers are connected. Now to share the internet:
Right click LAN card which is connected to Internet under Control Panel -> Network Connections and click ‘Sharing’ tab and enable both the options to share Internet. (Note: Unless there is another enabled LAN setting you will not be able to see the shared tab under properties)
Click Ok and close. This option is given by the Windows OS known as ICS (Internet Connection Sharing).
Now you can use Internet from both Computer A and Computer B from a single connection.
So this is the setup you need on the Host computer as you requested, if you turn out to need help witht he XP one too, let me know:)
Feb 14, 2009 | Compaq Presario 700 470024-192 Notebook
No internet despite network connection
ok your problem is the home edition for some reason there are features that are missing compared to all xp versions and i'm a little surpise with vista because of none problems but check all your network settings on all computers but start with the home edition the pproblem one make sure the sttings areset and there are a few things that might not be turned on that has to be check under the add and remove program components but sometimes this area might request the os disk to make changes and also check under network settings that the log on in the network properities is client for microsoft networks then goto internet protocol the address should be obtain auto and very important under internet protocol click properties then advance then at the top click the tab at the top that say options then you will see tcp/ip filter click properties and make all checks are enabled and permit all which is the common for this to be turn off and also i like to make windows the wireless default control under the card configure properties.. but again the home edtion has some features that are not available compared to xp pro which is the best xp os of xp versions....
Dec 03, 2008 | NetGear RangeMax WPN824 Wireless Router...
Wanted to change os, from vista to xp, driver problem
its better not to change your os, try to work on vista its more user friendly than xp, though you will have difficulty in starting, but sooner you will overcome it
Oct 27, 2008 | Computers & Internet
Acer Scaner Pria 640P Flatbe -Driver needed for Vista home
Dear Sir
I have recently changed my windows vista operating system and my scanner which model number is 640P not working properly. the previous software under windows xp is not working. Please solve my prob. and a bundle of thanks for solving my prob. immediately.
zaheer babar
from lahore pakistan.
Aug 27, 2008 | Acer ScanPrisa 640P Flatbed Scanner
Change of os
when you go to install xp it will ask you to format the partition anyways so just make sure you're formatting the right partition and you should have no probs. good luck
Jul 31, 2008 | E-Machines eMachines Desktop PC
Hi--hantel usb drivers for vista
I have a hantel wireless phone (tarang) HTP-800A CDMA2000WLL. I want to connect highspeed internet. But I cannot install it. How I will install? can I download the driver from internet? Please send me reply for this.Please help me to solve. Jaya Madhu
May 25, 2008 | Computers & Internet
How to install driver of HANTEL USB Modem on vista operating system
I have a Garuda phone (CDMA-2000 1X Wireless Local loop Phone HTP-801). I want to connect internet by this but it can be only connect at Window98se,2000 and xp.It does not install on vista. Please help me and told me about how i can install it on vista os
Apr 15, 2008 | Computers & Internet
Computers & Internet Logo
22 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
