Question about Texas Instruments TI-86 Calculator
Ti 86 math problem
Hello, i am trying to do a binomial probavility distribution equasion. after entering my information in columbs x and y i press 2nd list and program, names, vinomi, enter. after this i am not getting the answer that should be numerous equasions showing probabilitys and mean and things of this sort but i am not. do you have any sugestions. if this web site is only for tech support pleas let me know and i will no longer bother you. if it is on how to use the calculator to do specif problems, thanks for the help. also if i could order an owners manual that woud be very helpful thank you, piper
  • pipey Sep 20, 2007
    no added comments needed
  • 5 Answers
Piper, You can download a manual: http://education.ti.com/educationportal/appsdelivery/download/download_eula.jsp?applicationId=6127&contentPaneId=17&cid=US courouge
Posted on Oct 05, 2007
6ya staff
SOURCE:
Where is the '!' button on the TI 84 plus calculator?
There is no such button. The factorial function is in the probability submenu of the math menu. Press MATH left-arrow 4 to access the factorial.
Jul 23, 2014 | Texas Instruments TI-84 Plus Calculator
How to calculate cube root on simple calculator
That depends on how simple a calculator. I'll give some examples below for calculating the cube root of 8.
On a TI-86, press 3 2nd [MATH] F5 MORE F4 8 ENTER
If the calculator has a "^" or "y^x" key, raise 8 to the 1/3 power. Again, on the TI-86, press 8 ^ ( 1 / 3 ) ENTER
If the calculator has a logarithm key, take the logarithm, divide it by three, then take the antilogarithm. Again, on the TI-86, press 2nd [e^x] ( ln 8 / 3 ) ENTER
On a slide rule, place the hairline over the number on the K scale and read the cube root on the D scale.
Jan 10, 2013 | Texas Instruments TI-86 Calculator
How do I reduce fractions on my TI 86
Enter the numerator, press the divide key, enter the denominator, press the ENTER key, then press 2nd [MATH] F5 NEXT F1 (to select the >Frac command).
Apr 20, 2012 | Texas Instruments TI-86 Calculator
TI-86 - how do i change a decimal to a fraction?
Use the >Frac command from the MATH MISC menu.
Press 2nd [MATH] to bring up the MATH menu, Press F5 for MISC. Press MORE for the second page. Press F1 to select >Frac.
Nov 18, 2010 | Texas Instruments TI-86 Calculator
I totally forgot how to do binomial pdf can you help on my TI-84
Press the yellow [2nd] key then [VARS] (DISTR) to access the distributions. Scroll Up or down to see 0:binompdf( . Press 0 |ENTER|. The command echoes on the screen as binompdf(. Complete the command by entering the number of trials, the probability of success, and the value expected. Number of trials, and the value expected are integers.
You can also run the command giving it a sequence of expected values. In that case the sequence of expected values must be enclosed in curly brackets
Hope it helps.
binompdf ( number of trials, p, { expec_value1, expec_value2, ...} ) [ENTER]
Oct 15, 2009 | Texas Instruments TI-84 Plus Calculator
I was told that, to do binomial distributions on a ti-86, I would need to hit 2nd Math, then More, and I should see something that says STAT and go from there to get to DIST and Binomi. I see nothing...
Sorry, but you information is wrong, to find the binomial distribution use the PROB menu not the STAT menu. Its name is randBi
[2nd][MATH][F2:PROB] scroll right.
Hope it helps.
Oct 10, 2009 | Texas Instruments TI-86 Calculator
TI 86
Press "2ND" "MATH" "F3" to invoke the Angle menu.
Enter the number of degrees, press "F3", enter the number of minutes, press "F3", enter the number of seconds, press "F3", then press "ENTER".
Feb 15, 2008 | Texas Instruments TI-86 Calculator
Texas Instruments TI-86 Calculator Logo
261 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Ekse
Gene Pitts
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
