AOC 771S monitor always appear "not support out of range even if i already set my resolution to lowest.
  • 526 Answers
The lowest resolution is not always supported. by the range maybe referring to the frequency. change that, that should work. if you are not sure, look at your monitors manual, it will tell you resolution as well as frequency optimal settings
Posted on Apr 20, 2009
Remove banner "input not support" in 19" wide LCD 917Vw monitor. i am working different operating systems development some i try to excute some work this banner will appear pls help me..
You PC video setting is too high for the monitor to support, you need to set the PC resolution to 1440 x 900 @60Hz, try that first. Here is the spec for your monitor: http://reviews.cnet.com/lcd-monitors/aoc-917sw-lcd-display/4507-3174_7-33109821.html?tag=mncolBtm;rnav
Unless there are problemswith the logic board in the monitor if the resolution is already set correctly.
Mar 17, 2010 | AOC 917Sw 19" LCD Monitor
I have aoc monitor the problem is out of range
Describe your AOC S7M51, 17 in. CRT Monitor Problem. with external TV Tuner card connected, Message shows "Warning, Not Support, Out of range" and with CPU connected, the same message shows from the booting... ??? are AOC monitors trusted for the efficiency ?
Dec 04, 2009 | AOC CT720G 17" CRT Monitor
AOC 771s vertical center not working
what i did, is place it to a new one.
Sep 21, 2009 | AOC CT720G 17" CRT Monitor
Pincushion and h size problem on aoc 17" 771s
one of the buttons on your monitor is partially shorted. trust me, ive encountered this problem many times.
Jan 03, 2009 | AOC CT720G 17" CRT Monitor
Hi...my AOC 17" CRT monitor display on the screen says NOT SUPPORTED OUT OF RANGE... i try to change the screen resolution by using other monitor but still nothings happen..
Change to the lowest settings you can on the other monitor, then connect the 17" CRT. If you can see anything, go to display settings and slowly bring the settings up. If you lose the display, press "n" (there is a dialog box asking if you want to keep the settings, y or n). Most likely it is a refresh rate that is set to high. Try setting this to 60 Hz for starters.
Hope this helps.
Dec 12, 2008 | AOC CT720G 17" CRT Monitor
"Not support Out of range"
You have to boot your PC in safe mode using press F8 key.
after that you decrease the resolution in the display setting section.
It will help you.
Nov 29, 2008 | AOC CT720G 17" CRT Monitor
The menu is always pop up
so what is the best solution guys?
Oct 30, 2008 | AOC CT720G 17" CRT Monitor
Monitor
This means that the signal from the computer can not be understood by the monitor. Have you changed the screen resolution recently? Try lowering the resolution. If you can not see the screen, boot the system in safe mode. That uses the lowest resolution and can be seen on all monitors and that should allow you to confirm that the monitor is working.
Dan
Apr 09, 2008 | AOC CRT Monitor
Computers & Internet Logo
599 people viewed this question
David Payne
David Payne
