Question about Zyxel IP Express IES-1000 (91004098002)
Cant access the Zyxel IES-1000
Iam using a Zyxel IES-1000 switch in the main office to connect to the remote offices. i have lost the settings log which i made when i set this up and so i have lost the IP address which i gave to access the switch. I have run several IP scanner softwares to find the IP and its not showing the IP addresss of the switch. I have even tried Net Atlas software which came with the CD and its still not showing the swith. The funny thing is when i scan the network the scscan software does not show any of the zyxel prestige swithes that i am using. So i am really confused now..does my switch has an IP? cos i remember accessing it previously using the web configurator. I am really confused and frustrated. Can anyone help me. Thanks in adavance
    Scholar:
  • 132 Answers
Just a suggestion...try to loop-back ping to make sure YOUR still on the network. If you are have you tried tracert? The IES-1000 is an IP-based DSLAM, so you should get something back. Here is a link that may help you a bit more http://www.computerhope.com/issues/ch000444.htm
Posted on Sep 21, 2007
SOURCE:
I cant find my quantum FX rem-1000 R D MANUALLY ON THE NET
download your manual from offical web site
Mar 17, 2016 | Televison & Video
No Wi-Fi access when we use an access point.
Its not that the router is windows comparable it is on and Operating system can access it .
You need to set up the router with your account info from the company that supplies your INTERNET access.
You need to have a physical connection to the router to set it up use a standard eithernet cable and go to the default address which it should be (192.168.0.1 or 192.168.1.1 ) either one of these is probility the default address and login in if it has never been changed should be ( user-admin password- admin or password )
hope it helps here is more info on how to set it up
http://setuprouter.com/router/linksys/befsr81/login.htm
Dale
Dec 29, 2017 | Linksys BEFSR81 Broadband Router with 8...
I cant log in to my zyxel!(zyxel ies 1248) cos of someone change the IP address so how can i reset default?
See the attached manual and look up page 42 where is shows how to reset your router to the default settings. The default ip is 192.168.1.1.
the link is: ftp://ftp.zyxel.com/P-660HW-D1_v2/user_guide/P-660HW-D1%20v2_3.40_Ed1.pdf
If this solves your problem, leave feedback please.
Feb 05, 2010 | Zyxel Prestige 660R Router (P660R)
Laptop does not detect wireless from Zyxel 660 router
Dear! You will have to enable wireless conection to access the router and internet. Check your adapter settings and enable wireless conection. Your problem will be solved.
Thanks
Jul 28, 2009 | Zyxel Prestige 660HW Wireless Router...
We recently experienced a power outage and unable to log ont
In most cases you just have to reset your modem and/or router, to do this just unplug the modem for the mains for 2 minutes, plug it back in and wait another 2 minutes for it to settle down, then you can try to reconnect to the server.
Regards.
Jul 14, 2009 | Microsoft Windows Server Standard 2003 for...
ZyXEL IES-1000 with AAM1212 ADSL 12 port module step-by-step guid
Going through the GUI would take too long, so use CLI to add the commands below. After that, check the GUI and see how those changes appear.
VLANs:
On all equipment use 802.1q tagging. The example below puts adsl ports 1 to 10 in vlan10 and ports 11-12 in vlan2. These vlans are 802.1q tagged on the ethernet ports.
switch vlan set 1 1~12:X enet1~enet2:FT DEFAULT
switch vlan set 2 1~10:X 11~12:FU enet1~enet2:FT VLAN2
switch vlan set 10 1~10:FU 11~12:X enet1~enet2:FT VLAN10
switch vlan set 17 1~12:X enet1~enet2:FT VLAN17
switch vlan pvid 1~10 10
switch vlan pvid 11~12 2
switch vlan pvid enet1~enet2 1
switch vlan priority * 0
switch vlan gvrp * disable
switch vlan frametype * all
switch vlan cpu set 1
ATM circuit:
Each port requires one or more VPI/VCI circuit. You could map different circuits to corresponding vlans. The config below creates a primary circuit 1/35 on each port. On ports 5 and 9 is another circuit 1/32 mapped to vlan10
adsl pvc set * 1 35 super DEFVAL
adsl pvc set 5,9 1 32 10 0 DEFVAL
Remember a dslam is just a switch, bridging packets from a VC onto a VLAN or straight onto ethernet.
Mar 27, 2009 | Zyxel IP Express IES-1000 (91004098002)
I could not log in to Gtalkn
please, check out your internet settings for google in your office
or
you can contact the system administrator, whether the google option is disabled or any server related issue for your pc.
bye,
Jan 27, 2009 | Google Talk
Gprs settings for airtel
Here is the Mobile Office, Airtel Live and Airtel MMS settings for ALL CHINA Mobiles ==>
1) Mobile Office
first click SERVICES icon in main menu==>DATA ACCOUNT==>GPRS==>EDIT any existing account==>
Account Name--> MO
APN-->airtelgprs.com
Auth. Type-->Normal
save all the settings.
Come back to SERVICES==>WAP==>SETTINGS==>EDIT PROFILE==>EDIT any existing account==>
Rename Profile==> Mobile Office
Homepage==>Google
data account==> MO (which we created previously)
Connection Type==>
Here u find three option
a) Connection-oriented
b) Connectionless
c) HTTP
choose a) Connection-oriented==>
IP Address==>202.056.231.117
Security==> off
Again save all the settings and click BACK button and choose "Activate Profile"
Come back to SERVICES==>WAP==>Homepage
and you r ready to use Mobile Office...
Nov 30, 2008 | Handmark Software MobileLists (950142) for...
How to configure in point-to-point
Dear,
To connect both offices you have to create a VPN between both end's so that you can make a safe data tunnel between these two office. for this you have to static IP's on both ends and a Third party VPN client software.
for more details you can mail me i'll provide you all the details for how to create a safe VPN between two points.
Cheerup
Mar 18, 2008 | Zyxel Prestige 660H Router
Zyxel IP Express IES-1000 (91004098002) Logo
447 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Ekse
Pamela Bates
Pamela Bates
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
